Another short maintenance shutdown at 10:30 PM (0330 UTC)
Links to the "A6 Tips and Tricks"
Page 1 of 1 [17 Posts]
Peake
PostPosted: Mon Oct 01, 2007 12:01 am    Post subject:  Links to the "A6 Tips and Tricks" Reply with quote  Mark this post and the followings unread
document, and for the "Using_A6_Public2" document? They are items that every Andromeda user should both know about and make use of. They include the factory reset procedures, tutorials, and hints for getting more from the sound engine.
http://www.wohmart.com/a6/
They're found here, and in the other A6 comunities as well. Might there be space on electro-music for them as well, and a sticky for them here?
Thanks for the great site.
-Mike
Former site admin
Audio files: 353
PostPosted: Mon Oct 01, 2007 4:38 am    Post subject: Re: Mosc, may I request a sticky for the "A6 Tips and Tricks Reply with quote  Mark this post and the followings unread
-Mike
I made this post into a sticky, so if you edit the text and message title I guess you've got what you want?
sunny pedaal
Audio files: 12
PostPosted: Mon Oct 01, 2007 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
direct hit:
htlm:
http://www.wohmart.com/a6/tandt/A6TipsAndTricks.html
pdf:
http://www.wohmart.com/a6/tandt/A6TipsAndTricks.pdf
or download from here ( although good idea to check the wohmart site out, as it's loaded with good info regarding the a6/andromeda)
A6TipsAndTricks.pdf
tips and tricks version 2
 Filename:  A6TipsAndTricks.pdf
 Filesize:  1.62 MB
 Downloaded:  4186 Time(s)
Audio files: 267
PostPosted: Mon Oct 01, 2007 12:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, Jan. I changed the subject of this topic.
Peake
PostPosted: Mon Oct 01, 2007 12:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you very much! There are new users popping up and they'll find it of great benefit.
Regards,
-Mike
sunny pedaal
Audio files: 12
PostPosted: Mon Oct 01, 2007 12:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
to complete , a link to ( Immediate download of ! ) the reference /a6 manual from alesis:
http://www.alesis.com/downloads/manuals/A6_Manual.pdf
(size ca 6,8mb)
so....... and now : tv off and go on reading !
Peake
PostPosted: Mon Oct 01, 2007 10:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is the Alesis page for the last official OS 1.4.12, the factory soundset, and some free soundsets from those who helped to test and voice the unit.
http://www.alesis.com/forums.html?id=58,36,0,0,1,0
(Edit: Sorry, page is no longer current.)
sunny pedaal
Audio files: 12
PostPosted: Tue Oct 02, 2007 12:47 am    Post subject: Reply with quote  Mark this post and the followings unread
oke , now for real, to complete:
1. the general overview artikel in the sound on sound:
http://www.soundonsound.com/sos/apr01/articles/alesis.asp
2. interesting link:
http://launch.groups.yahoo.com/group/Andromeda_A6-ION/files/service%20manual/
( also down to download / 1-11-10 on this threat )
3. mike's smaller, previous, version of a tips andtricks on the a6:
so.... and now tv off, and reading !!
The Extension 'htm' was deactivated by an board admin, therefore this Attachment is not displayed.
sunny pedaal
Audio files: 12
PostPosted: Fri Feb 29, 2008 4:32 am    Post subject: Reply with quote  Mark this post and the followings unread
for those with a lot of time and interest: a txtfile containing the code404conversations. best used with find/search function
a6code404.zip
texts of a6code404 community 2003-2007 (now chronological)
 Filename:  a6code404.zip
 Filesize:  1.8 MB
 Downloaded:  1826 Time(s)
sunny pedaal
Audio files: 12
PostPosted: Wed Oct 20, 2010 2:57 am    Post subject:   Reply with quote  Mark this post and the followings unread
as the a6 andromeda is discontinued, it might be a good idea to share the knowledge regarding this beast . just to get it going also in future, and maybe even to modify/ improve the thing.
hereby , i found it on the net, the a6 service manual for download:
tweak-on !, your sunny
a6 service manual.zip
 Filename:  a6 service manual.zip
 Filesize:  14.94 MB
 Downloaded:  1881 Time(s)
liderdon
PostPosted: Fri Jan 07, 2011 5:18 pm    Post subject: Alesis Andromeda A6 Reply with quote  Mark this post and the followings unread
sunny pedaal
Audio files: 12
PostPosted: Sat Sep 08, 2012 6:16 am    Post subject: Reply with quote  Mark this post and the followings unread
some more needed:
a6syx.pdf
 Filename:  a6syx.pdf
 Filesize:  981.93 KB
 Downloaded:  1734 Time(s)
a6v14012.zip
 Filename:  a6v14012.zip
 Filesize:  1.01 MB
 Downloaded:  1336 Time(s)
a6v14012.hqx.zip
for mac
 Filename:  a6v14012.hqx.zip
 Filesize:  1.05 MB
 Downloaded:  1247 Time(s)
sunny pedaal
Audio files: 12
PostPosted: Sat Sep 08, 2012 6:19 am    Post subject: Reply with quote  Mark this post and the followings unread
and this:
Here is the official legacy Alesis page for the last official OS 1.4.12 ( as above ), the factory soundset, and some free soundsets from those who helped to test and voice the unit.
http://www.alesis.com/andromeda
Audio files: 267
PostPosted: Sat Sep 22, 2012 8:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Good idea to preserve that printed matter here on electro-music.com. Even though this is discontinued, I'm sure it will be a favorite synth for many years to come.
sunny pedaal
Audio files: 12
PostPosted: Sat Sep 22, 2012 11:21 am    Post subject:   Reply with quote  Mark this post and the followings unread
yes certainly,
i think the a6 users are grateful to the electroc-music.com for the opportunity,
thanks !
ps is the info being backup regulary also , on the site ?
Audio files: 267
PostPosted: Sat Sep 22, 2012 4:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, but shit happens. We try to avoid that substance, but... Rolling Eyes
happyham
PostPosted: Mon Sep 21, 2015 12:50 am    Post subject: new user thanks Reply with quote  Mark this post and the followings unread
I've had an Andromeda for two weeks now, and love it. Thanks a million for the tips and tricks compilation. It's been a great help.
