Audio files: 28
Posted: Fri Jan 04, 2008 12:21 am Post subject:
I like that
I've never heard of this - What parts are involved? I see LSI mentioned - that does not sound promising to recreate it. Is there a schematic around?
bruce
And here's a pic of the PCB:
_________________ Sneak-Thief - raw electrofunk Last edited by sneakthief on Fri Jan 04, 2008 6:27 am; edited 1 time in total
Joined: Dec 26, 2006 Posts: 144 Location: United Kingdom
Posted: Fri Jan 04, 2008 6:26 am Post subject:
RF wrote:
I like that
bruce
The problem part is the obsolete MK50240 top octave synthesizer chip. This is a frightening price as NOS.
I'm looking aroung for an updated PIC design. Jim Patchell did one, but it's about 4 octaves down, due to processor speed. I've heard of an AVR version but can't find it. Best suggestion I've heard so far is a small CPLD or FPGA, though that means a lot of design work. _________________ Mike
Joined: Aug 02, 2007 Posts: 188 Location: Arlington, TX USA
Posted: Fri Jan 04, 2008 9:09 am Post subject:
Yes I remember that, it was marketed here under the Braun brand, but in the US as something else. Didn't have it myself, and it was a bit limited indeed, but I've always liked the concept; not building a circuit but drawing up schematics really.
i bet that's the one, i don't remember what it was called...
forgot to mention the schematic thing. the blocks had the symbol on top so at the end you had the circuit and the schematic in one, which was not a bad idea. some of the "components" were nothing but wire connecting the terminals. you had to have a lot of blocks to do anything interesting (which i didn't of course)...
Posted: Fri Jan 04, 2008 9:16 am Post subject:
[quote="State Machine"]
hehe i also remember making an arc lamp ..."top up a pot" ...
LOL.
i never pissed in mine, i think that would have killed me for sure. it was totally homebrew too, with the "electrodes" being just bare wire, which did indeed corrode badly...
i had a friend, though, who pissed on an electric fence once...
once!
Audio files: 25
Posted: Fri Jan 04, 2008 11:58 am Post subject:
I'm looking around for an updated PIC design. Jim Patchell did one, but it's about 4 octaves down, due to processor speed. I've heard of an AVR version but can't find it. Best suggestion I've heard so far is a small CPLD or FPGA, though that means a lot of design work.
Would this website help? They seem a bit expensive but a good alternative.
If forum members, or myself, wanted to roll their own "TOS" IC, that would be a fun learning experience. The topology of the design is quite simple actually as it is a series of redundant dividers with different feedback coefficients to provide the correct output frequency. Using an MCU's wide timers would work nicely or using a CPLD with redundant dividers would work equally well.
Usually it is desirable to output a square wave with 50% duty cycle on each of the note outputs. When designing the hardware counter method, the divider is usually decoding a specific count then resets a counter giving you 1 pulse per "N" counts. The output of such a decoder would thus not be a 50% duty cycle but some really narrow pulse equal to the period of the master clock if synchronously loadable/resettable counters are used . To get around this, using an example of the /426 output of the chip illustration, I would create a divide by 213 using the above method then then feed this to a toggle flip-flop to divide this by 2, thus a 50% duty square wave with a division of 426 would be created. I hope I did not go too far with this
Anyway, I will dig up my EGG and take a peek at the TOS chip and post some pictures of it as well ......
Audio files: 25
Posted: Fri Jan 04, 2008 12:00 pm Post subject:
Oh dude this is so funny man !!!!!!! Thanks for the humor ! Too bad you did not have pictures of this experiment of yours
Audio files: 25
Posted: Fri Jan 04, 2008 12:26 pm Post subject:
i'm not sure if that ks-87 will work as a drop-in replacement - compare that to the frequencies that the MK50240 uses:
Oh yes. Thanks. I was siting a design example for rolling your own but YES, I appreciate this clarification very much !!!!!! Good detective work there I hope I did not mislead anyone
Crystal sets (several), pentode audio preamp, #27 triode RF oscillator capable of transmitting, super-regenerative receiver (tube), game of "Nim" (also called Black Match) using relays, guitar driven UJT relaxation oscillator circuit for making weird synth sounds, transistor amplifiers. I'm sure there's more, but that was a very long time ago...
Audio files: 25
Posted: Sat Jan 05, 2008 4:42 pm Post subject:
OH yes, I had designed a UJT relaxation oscillator years ago but not to make any sound but as part of a PWM circuit in a DC motor controller to drive a radar antenna at various speeds I have not used UJT's since. Thats was many years ago also. Brought back memories from my old radar lab .......
I take it you have a radio operators license ?? The ARRL handbook was a goldmine of information. I currently just have a "TECH" class license because of my amateur rocketry efforts. I was more interested in ATV and DATA transmission (telemetry) rather than the VOX stuff on 2/6 meter ......
Bill
Sadly, I do not have a license. I was close to a Novice lic. back then, I had the code speed at the required 5+ wpm send and 7+ wpm receive. I knew the theory too, just never took the test. Got busted by the radio cops once for sending out a 60 Hz halfwave buzz on 1000 KHz. I had it on a horizontal longwire antenna that was 30 feet off the ground (normally used for crystal sets). I wanted to see how far it went as I rode my bike with a transistor radio. When I came home, there they were. They told me I didn't belong on that wavelength and that I should get a license... [sigh]. But I digress and go off thread a bit.
Joined: Dec 24, 2004 Posts: 2524 Location: San Jose, California
Posted: Sat Jan 05, 2008 6:05 pm Post subject:
State Machine wrote:
My favorite at age 9 Tandy corporation ... now vintage ....
Bill
While these aren't really DIY, I grew up with Radio Shack kits too.
I had a 10-in-1, then a 50-in-1 kit. Those solderless spring terminals were great.
I still have a Radio Shack Electronics dictionary from 1974-75, and many of the Engineers Notebooks from Forrest Mims.
Does anyone remember the free battery card radio shack gave out?
I must have had one from each store in the area. But their free batteries didn't last very long
_________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home. Last edited by cappy2112 on Sat Jan 05, 2008 6:38 pm; edited 2 times in total
Posted: Sat Jan 05, 2008 6:26 pm Post subject:
v-un-v wrote:
(Rockets were so much FUN!!). Rockets meant that you spent more time in the sunshine rather than the dark. However when I got into photography, 95% of the time was spent in the darkroom anyway!
Oh yes. Who could forget the rocket kits from Estes and what is the name of that other company?? There were two companies that I remember that sold model rocket kits when I was a kid.
I never saw my first rocket after the initial launch. The wind took it far far away. _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home.
Audio files: 25
Posted: Sat Jan 05, 2008 7:13 pm Post subject:
Oh the Mims books, yes !!! I loved them and built many of those circuits Those old catalogs from PAiA trigger some memory cells as well.
The other company was "Century Engineering" they made fantastic model rocket kits. There was also "Flight Systems Inc." and "Enerjet". I believe they made solid propellant motors also. "Cox" also made black powder motors and kits also.
Audio files: 25
Posted: Sat Jan 05, 2008 7:18 pm Post subject:
Oh but what a cool experiment. How else to learn but to take empirical data. I probably would have been just as curious as you were about how far that signal would travel. Nice .....
