Brief maintenance shutdown at 10:00 PM EST - 0400 UTC
Voltage Controlled OpAmp RingMod (Modulator)
Page 7 of 9 [209 Posts]
LektroiD
PostPosted: Sun Oct 31, 2010 2:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
To my ear, it sounds more like it is mixing the signals, rather than multiplying them.. There is always a signal bleeding from both modulator and carrier inputs. My understanding of a ring modulator, is that both the carrier and modulator should remain silent until they are modulated by each other?
Also there's no calibration procedure in the docs, perhaps this is where I'm going wrong?
First I tried two square waves, and offset the modulator frequency. Secondly I used a drum machine for the carrier. It certainly modulates, but doesn't sound anything like a classic ring circuit. Maybe I'm doing something wrong here? I will do some more experimenting
LektroiD
adambee7
PostPosted: Mon Nov 01, 2010 11:44 am    Post subject: Reply with quote  Mark this post and the followings unread
pcbs arrived. cheers matthias. Very Happy Very Happy
numbertalk
PostPosted: Mon Nov 01, 2010 11:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Board made it to NYC, thanks!
emdot_ambient
PostPosted: Mon Nov 01, 2010 12:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
My wife tells me the boards have arrived. Thanks!
softfin
PostPosted: Mon Nov 01, 2010 12:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
A pair of red boards arrived today, salut
PostPosted: Mon Nov 01, 2010 2:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
If either of your signals has a DC offset, then you will get bleedthru.
You want to be sure that the CV input voltage is not causing a DC offset. Also, you want to be sure that your input signals have no DC offset.
A square wave that is 0v to 10v will have (in effect) a 5v DC offset.
PostPosted: Mon Nov 01, 2010 3:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
will follow.
for now:
if you don't have a scope - don't apply any signal to any input. turn all pots down. turn input 1 pot up (still no signal at the input!), use trimpot to get 0V at test point TP1. then same for 2nd input.
if you have a scope - apply a signal to channel 1, input pot all up. use trimpot to move signal centered around 0V.
Posted Image
Danno Gee Ray
PostPosted: Mon Nov 01, 2010 3:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Got my boards today as well.
PostPosted: Mon Nov 01, 2010 7:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Arrived! Thanks!!!
bugfight
PostPosted: Mon Nov 01, 2010 10:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
gots mine, thanks again again!
a100user
PostPosted: Tue Nov 02, 2010 12:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Boards arrived
Thanks Matthias
David
Luka
PostPosted: Thu Nov 04, 2010 3:03 am    Post subject: Reply with quote  Mark this post and the followings unread
boards arrived!
problemchild
melbourne australia
Dego
PostPosted: Thu Nov 04, 2010 4:28 am    Post subject: Reply with quote  Mark this post and the followings unread
got mine last week Smile
PostPosted: Thu Nov 04, 2010 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
My board arrived, too. Look forward to building this. Thanks!
diablojoy
PostPosted: Thu Nov 04, 2010 5:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
boards arrived in oz thanks mathias Smile
Adam-V
PostPosted: Mon Nov 08, 2010 7:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
My boards have arrived too Matthias. Thanks again.
Adam-V
slo
PostPosted: Wed Nov 10, 2010 6:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Board arrived in Canada
George
jumunius
PostPosted: Fri Nov 12, 2010 1:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
LektroiD wrote:
I'm now wondering how to do a 5U for this, If I do standard MOTM 1U, I'll have nowhere to put the extra socket, and it seems a little wasteful to use a 2U panel just to accommodate 1 extra socket. I may have to use smaller rotary knobs and place the sockets next to each of those
Any other 5U guys out there building this?
I'm going to do a 2u and fill out the space with either one of Nicolas' simple VCOs or simple LFOs, as either would be useful on its own, as well as in conjunction with a VC Ring.
PostPosted: Mon Nov 15, 2010 9:29 am    Post subject: Powered up the VC RingMod last night Reply with quote  Mark this post and the followings unread
Powered it up and got sound out of it! ** Hooray!! **
Both VCA's work ok. The Carrier signal is ok. The Modulator signal is clipped though ... so, I have some troubleshooting to do. I can already see that this will be a fine addition to my synthesizer.
I'll post a pic once it is finished -- as tempting as it is to post a pic, I wait until everything works to spec before I do the show 'n tell thing. Wink
emdot_ambient
PostPosted: Mon Nov 15, 2010 12:41 pm    Post subject: Re: Powered up the VC RingMod last night Reply with quote  Mark this post and the followings unread
And sound samples!
PostPosted: Mon Nov 15, 2010 3:40 pm    Post subject: Re: Powered up the VC RingMod last night Reply with quote  Mark this post and the followings unread
does it clip at the testpiont TP2, or does it clip at the output? latter would be the feature, not a bug.
Posted Image
mono-poly
PostPosted: Tue Nov 16, 2010 6:29 am    Post subject: Reply with quote  Mark this post and the followings unread
I still want the euro version Matthias Smile
PostPosted: Tue Nov 16, 2010 7:17 am    Post subject: Re: Powered up the VC RingMod last night Reply with quote  Mark this post and the followings unread
Thank you for your comment. The waveform is not clipped at TP2 and TP1.
I checked and re-checked the polarity of the diodes and verified that the op amp is working correctly. Thank you for verifying that the module is working to spec.
I will get some sound examples up soon. Stay tuned...
PostPosted: Thu Nov 18, 2010 9:30 pm    Post subject: VC Ring Modulator MP3 Demo Track Reply with quote  Mark this post and the followings unread
I just recorded a demo and a short improv with this module.
One adjusts the signal levels (the carrier and modulator -- X and Y) to null out the primary input signals.
Since the Voltage control varies the X and Y levels, external voltage can control the nulling effect ("bleed through") and effect some amplitude modulation, too.
I labeled the inputs X and Y to match the Aries labeling (used for the Aries Balanced Modulator).
VC Ring Modulator Demo.mp3
Demonstration and short improv with the Fonitronics mh31 Voltage Controlled Ring Modulator
 Filesize:  5.78 MB
 Duration: 6:19
 Viewed:  3437 Time(s)
The VC Ring Mod didn't utilize all of the Aries 9x3 panel, so I added a separate Gain/Bias function to the module.
 Filesize:  1.29 MB
 Viewed:  700 Time(s)
This view shows the VC Ring Mod PCB
 Filesize:  1.6 MB
 Viewed:  688 Time(s)
This view shows the Gain/Level Shifter PCB.
 Filesize:  1.56 MB
 Viewed:  664 Time(s)
PostPosted: Fri Nov 19, 2010 4:47 am    Post subject: Reply with quote  Mark this post and the followings unread
wow!
that demonstration is awesome!
BTW did you try the VCmodulator for control voltages as well?
Posted Image
