Brief maintenance shutdown at 10:00 PM EST - 0400 UTC
Coming up on Radio 1 at
 Forum index » Clavia Nord Modular » G2 Patches - Completed » External Control
Behringer ULTRACURVE PRO DEQ2496
Page 1 of 1 [2 Posts]
Nodular
G2 patch files: 7
PostPosted: Mon Apr 19, 2010 6:25 pm    Post subject: Behringer ULTRACURVE PRO DEQ2496
Subject description: GEQ control Left, Right, L+R
from Behringer website...
- Ultra-high resolution processor for all EQ, RTA and dynamic applications, especially for PA and audiophile mastering
- 4 concurrently selectable EQ modules (31-band graphic EQ, 10-band parametric EQ, Feedback Destroyer plus 3 Dynamic EQs per stereo channel)
-Flexible compressor/expander function with peak limiter per stereo channel as well as additional stereo imager and stereo delay for delay line applications
- Unique VPQ (Virtual Paragraphic EQ) option allows parametric control of graphic EQs
- Ultra-high resolution 61-band real-time FFT analyzer with additional auto EQ function for room and loudspeaker equalization
- Multi-functional level meters (peak/RMS, VU and SPL meter with dBA/dBC weighting via RTA/Mic input)
- 64 user memories for complete setups and/or individual module configurations
- Separate RTA mic/line input with phantom power, professional Wordclock input and MIDI connections for full remote control, preset dumps and system updates
- Ultra-high resolution 24-bit/96 kHz A/D- and D/A converters (113 dB dynamic range)
- Open architecture allowing future software updates via MIDI
2 high-performance 32/40-bit floating-point DSPs for ultimate sonic resolution
- Balanced inputs and servo-balanced outputs with gold-plated XLR connectors, stereo aux output, AES/EBU and S/PDIF inputs and outputs (XLR and optical)
- Internal switch-mode power supply for maximum flexibility (100 - 240 V~), noise-free audio, superior transient response and lowest possible power consumption
- High-quality components and exceptionally rugged construction ensure long life
- Conceived and designed by BEHRINGER Germany
... a bit too much for the price (300€) and indeed some problems are there, but it's the only piece of gear that does all of that in 1 rack unit.
Anyway here are the patches I use to control its GEQ (the only module directly controllable via MIDI)
ciao
PS: the patch for both channel has a bug and last two bands of left channel can't be controlled. I couldn't figure out why !
Mad
DEQ2496 GEQ L.pch2
left channel
 Filename:  DEQ2496 GEQ L.pch2
 Filesize:  3.87 KB
 Downloaded:  2235 Time(s)
DEQ2496 GEQ R.pch2
right channel
 Filename:  DEQ2496 GEQ R.pch2
 Filesize:  3.87 KB
 Downloaded:  2179 Time(s)
DEQ2496 GEQ L+R.pch2
both channels
 Filename:  DEQ2496 GEQ L+R.pch2
 Filesize:  7.08 KB
 Downloaded:  2116 Time(s)
Nodular
G2 patch files: 7
PostPosted: Tue Mar 26, 2019 8:02 am    Post subject: Re: Behringer ULTRACURVE PRO DEQ2496
Nodular wrote:
...PS: the patch for both channel has a bug and last two bands of left channel can't be controlled. I couldn't figure out why !
Mad
Has anybody found this bug solution?
