Another short maintenance shutdown at 10:30 PM (0330 UTC)
Filter 2 Display Page Activation
Page 1 of 1 [7 Posts]
pfrancq
PostPosted: Sun May 15, 2016 12:25 pm    Post subject: Filter 2 Display Page Activation Reply with quote  Mark this post and the followings unread
My Andromeda has a strange behavior. Very often, the Filter 2 display page is activated even if I am currently manipulating parameters of other parts of A6. This can be annoying when I program it. Any idea ? Is it a hardware problem ?
Thanks.
SynthasaurusRex
PostPosted: Fri May 20, 2016 10:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've never had this problem myself, but others have reported interface problems that were corrected by re-seating the ribbon cables.
-Stephen
sunny pedaal
Audio files: 12
PostPosted: Sat May 21, 2016 9:02 am    Post subject: Reply with quote  Mark this post and the followings unread
isn't it maybe some dust in one of the knobs or pots around filter 2, therby giving of a signal as if you uturn one of them and showing the corresponding page?
try moving all the buttons some times gently, maybe carefully use some air or vacuumcleaner with a sock/panty around it ( to avod sucking up parts) to get dust out etc?
would be strange to be a big central problem as it always comes to that little page ...
( dustcover especially important with so many buttons/ knobs and pots, and don't smoke )
SynthasaurusRex
PostPosted: Sat May 21, 2016 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, Sunny. pfrancq, listen to Sunny - he knows this beast better than most of us Very Happy
sunny pedaal
Audio files: 12
PostPosted: Wed May 25, 2016 7:42 am    Post subject: Reply with quote  Mark this post and the followings unread
already tried?
if not the effect , i would suggest to let a tecniciancheck the filterpot itself , the servicemanual can be loaded from this side ( first topic , see attachments)
pfrancq
PostPosted: Sun May 29, 2016 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks. I will try this in the next days.
RETRIVOX
PostPosted: Fri Jul 01, 2016 2:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
If this doesn't help, you could also check the biggest cord and its plugs, inside of your Andy .
