Another short maintenance shutdown at 10:30 PM (0330 UTC)
"Card Error or Uninitialized hit Store to Init Card"
Page 1 of 1 [6 Posts]
Synthbrass
PostPosted: Tue Oct 18, 2016 1:26 am    Post subject: "Card Error or Uninitialized hit Store to Init Card"
Subject description: Memory Card doesn´t work anymore
I have been using an SRAM card for storing the sounds I made on the Andromeda and everything worked fine until one day when powering it up it said "Card Error or Uninitialized hit Store to Init Card". I was unable to access my card. I tried to hit store and I tried to change battery but both didn´t help.
Did anyone have the same problem and knows what i should try to do to fix it? I don´t just want to buy a new card to just find out that it isn´t the cards fault.
Thanks for any help!
sunny pedaal
Audio files: 12
PostPosted: Wed Oct 26, 2016 2:54 am    Post subject: Reply with quote  Mark this post and the followings unread
had the same problem once with a roland memorycard.
simpy died due to age ...
Synthbrass
PostPosted: Sat Oct 29, 2016 8:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm I have it since around 2012 or 2013 I think, don´t know if they become old so fast.. would you recommend buying a new one?
Btw it happened when i switched it on after leaving it it for about 2 months unpowered.
sunny pedaal
Audio files: 12
PostPosted: Sat Oct 29, 2016 11:39 am    Post subject: Reply with quote  Mark this post and the followings unread
i see
did you replace the battery inside the card ?
and if so , tried tp format it again ( by which you'll lose your sounds anyway )
only after these two you can say the card is broken or not tmho
Synthbrass
PostPosted: Sun Oct 30, 2016 1:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
sunny pedaal wrote:
i see
I tried exchanging the battery but it didn´t help. I also tried hitting INIT on the andromeda but it didn´ help either. Btw what do you mean with tp formatting, how do I go about it? Would of course have been cool to access the old sounds but I would be already happy if I could store new patches onto the card.
sunny pedaal
Audio files: 12
PostPosted: Fri Nov 04, 2016 6:18 am    Post subject: Reply with quote  Mark this post and the followings unread
you have to format any ( new, or deleted) card once
in the manual stands what softbuttons to press etc, to long ago to exactly remember the procedure.
the manual can be found in the first topic on this page.
fr.gr. leo
