rhdf
Posted: Tue Apr 04, 2017 1:50 pm Post subject:
correct way to calculate octave shift? |
I have a array with the frequencies for "all" midinotes.
To get the correct pitch I simply use f=notetable[midinote]. But if I want to shift one octave up/down? Just add/subtract 12 to/from midinote? (and check that I dont end upp below 0 or over 127)
I've seen examples where f is multiplied with 2 for one octave up.
that would work fine for A where A4=440.00 A5=880.00 etc. But for C where C4 =261.63 C5=523.25 you end up slightly out of tune
witch metod is recomended
(Later I will add control for +semitune and detune/fine-tune.) |
Former site admin
Joined: Apr 03, 2004 Posts: 24863 Location: The Netherlands, Enschede
Audio files: 353
Posted: Tue Apr 04, 2017 2:15 pm Post subject:
Should not matter .. one octave by definition is a factor of two in frequency .. and also by definition 12 semitones up or down.
The frequency values are rounded values, on those things may seem off, but the internal representation has more digits .. except for A being tuned to exactly 440 Hz ... also by definition.
C being four semitones up from A would then have a frequency of 2^(4/12)*440 or approximately 554.36525 Hz .. hmm .. not sure where your values for C come from ... they seem off.
Strictly speaking it depends on the actual tuning being used, there are many variations on the theme .. but this is what is mostly used. |
Joined: Jan 31, 2003 Posts: 18544 Location: Durham, NC
Audio files: 267
Audio files: 267
Posted: Tue Apr 04, 2017 3:48 pm Post subject:
I forgot something important though. Real life pianos are not tuned to exact octaves; octaves are "stretched". Good piano tuners do this. I don't know any electronic instruments tuned like this, but I'd like to know if there is.
Here's a nice link (scan down to the "Stretch" section):
https://en.wikipedia.org/wiki/Piano_tuning _________________ --Howard
my music and other stuff |
gdavis
Posted: Tue Apr 04, 2017 4:27 pm Post subject:
| Blue Hell wrote: |
C being four semitones up from A would then have a frequency of 2^(4/12)*440 or approximately 554.36525 Hz .. hmm .. not sure where your values for C come from ... they seem off. |
C is three semitones up from A. Your forgot that B# = C
As Blue Hell said, both methods produce essentially the same result. The trade off between the two methods is memory vs. computation, so the choice comes down to what platform you're on and how each of these two factors weigh against each other.
The issue you are noting about the values not "matching" is a matter of computational precision and round off error. This has to be taken into consideration regardless of the method you use.
While the "multiply by two" method may at first seem to give you a result that is "out of tune", it really doesn't.
Take your example of C4=261.63 and C5=523.25. As you noted, 261.63 * 2 is not 523.25. However, this is not because C5 does not equal 2*C4. The discrepancy is actually due to the fact that C4 does not equal 261.63, but has been rounded off. They're both slightly out of tune.
None of those values are exact based on the 2^(n/12)*440 relation, but they don't have to be. You need to decide how much precision is necessary to sound "in tune".
Once you have a suitable precision for your lowest frequency, the method for calculating higher frequencies won't matter.
Consider this:
65.41Hz +/- .005 (2 decimal point precision) is accurate to about .0076 percent.
4186.01Hz +/- .005 (again, 2 decimal point precision) is accurate to .00012 percent, way more accurate than 65.41.
What this is illustrating is that as you go up in frequency, you don't need as many decimal places to maintain the same level of accuracy. So, while the two calculations may not be mathematically equal, you don't loose any accuracy when you multiply to get higher octaves.
What this means is that if rounding off C4 to two decimal places is enough to sound "in tune", then C5 = 2*C4 will also be in tune. Even if the value isn't exactly the same as the 2^n/12 based calculation, it's "close enough" that you can't hear the difference, and will continue to be up through all the octaves.
| mosc wrote: | I forgot something important though. Real life pianos are not tuned to exact octaves; octaves are "stretched". Good piano tuners do this. I don't know any electronic instruments tuned like this, but I'd like to know if there is.
https://en.wikipedia.org/wiki/Piano_tuning |
This is due to how strings physically vibrate, not a factor in electronic synthesis. _________________ My synth build blog: http://gndsynth.blogspot.com/ |
Former site admin
Audio files: 353
Posted: Wed Apr 05, 2017 1:46 am Post subject:
| gdavis wrote: | C is three semitones up from A. Your forgot that B# = C  |
Worse .. counted the notes and not the intervals  |
Audio files: 267
Posted: Thu Apr 06, 2017 12:56 pm Post subject:
| Quote: |
This is due to how strings physically vibrate, not a factor in electronic synthesis. |
I agree about the physical strings differing from electronic circuits. I've noticed that guitars, ukuleles, and banjos that I play sound best when I tune only the lowest note by electronic tuner and tune the higher strings by ear. Plucked or struck strings play a little sharp at first and then drift down as they sustain.
Also, if one is going to play in one particular key, equal-temperament tuning is not going to sound as good as an alternative tuning, like just intonation, for example. That's another subject. but something to consider if you're deciding to use calculated values for equal-tempered tuning versus reading frequency values from a table.
We are lucky to have an alternative tuning master here on electro-music.com. Check out Seraph's artist forum.
http://electro-music.com/forum/forum-84.html _________________ --Howard
rolfs
Posted: Tue May 07, 2024 5:01 am Post subject:
| mosc wrote: |
In virtually all tuning systems an octave is exactly a factor of 2, one way or the other. |
The same way one can move the frequencies by N * ~1,06.... to shift note for note.
This refers to the tempered tuning as we know. Anybody uses pure tuning? One will have to define a tuning at all for the melody and then match this "grid". |
