Coming up on Radio 1 at
40106 lunetta drone
Page 1 of 1 [5 Posts]
Deedalo12
PostPosted: Thu Jan 08, 2026 3:05 pm    Post subject: 40106 lunetta drone Reply with quote  Mark this post and the followings unread
Hi happy new year! im tryiing to do my first "lunetta machine" (im continue failing XD) and now i have this problem:
I have to cables soldered in to the pcb that goes to a 5v breadbord powersuply. I cant get sound when i plug some of the out of the 40106. In one out y have noise that modulates with one of the potenciometers.
I saw the conexion good, use a multimeter to chek it, maybe must have missed something.
[img]https://ibb.co/Kjpm9y6C[/img]
[img]https://ibb.co/gLGT9xsk[/img]
Former site admin
Audio files: 353
PostPosted: Fri Jan 09, 2026 3:05 am    Post subject: Reply with quote  Mark this post and the followings unread
I've added the images from the above post by using the first BB code mentioned ;
Posted Image
Posted Image
elektrouwe
PostPosted: Sun Jan 18, 2026 12:03 pm    Post subject: Re: 40106 lunetta drone Reply with quote  Mark this post and the followings unread
all your potentiometer connections are wrong. Please take your time to study the function of potentiometers. If you understand the difference between a potentiometer as variable resistor and as voltage divider, go back to the breadboard and fix your errors Smile Don't give up and have fun !
Audio files: 730
PostPosted: Tue Jan 20, 2026 10:36 am    Post subject: Re: 40106 lunetta drone Reply with quote  Mark this post and the followings unread
Those look correct to me, considering that the center pin (wiper) is connected to one of the outer pins.
If only the outer pins were connected it shouldn't really matter much anyway apart from not being able to increase the frequency.
but maybe there is something else I missed.
what I am curious about is:
How are you listening to it ?
what are the capacitor values ?
Those electrolytic ones are likely too large to produce anything in the audible range but could be used for modulation.
Also, did you test it on a breadboard first before soldering ?
The Golden Shrimp Guild
Audio files: 266
PostPosted: Sat Jan 24, 2026 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't see the center pins on the pots connected to anything. Of course, if you just use the outside pins you just have a non-variable resistor.
