RenSynthJp
Posted: Fri Aug 28, 2026 8:00 pm Post subject:
Two things nobody warns you about importing Japanese hi-fi: the 50/60Hz motor question, and why a turntable ships worse than a heavier amp |
Following on from the Hard Off and shipping-limits threads I posted earlier this month - I went and priced a couple of real parcels this week and hit two things that I had not seen written down anywhere, so here they are.
1. Voltage is the famous problem. Frequency is the quiet one.
Everyone knows Japanese domestic gear is 100V and that you need a step-down transformer. What gets skipped is that Japan runs two mains frequencies - 50Hz in the east (Tokyo, Tohoku) and 60Hz in the west (Nagoya, Kyoto, Osaka). The dividing line runs through Shizuoka and Niigata.
For most of what we buy this does not matter. Amps, tuners, CD players, anything with a switching or conventional PSU: frequency is irrelevant, voltage is everything.
Where it does matter is motors:
- A direct-drive turntable with quartz speed control regulates the platter electronically. Technics put quartz lock on the SL-1200MK2 in 1979 and it does not care what your grid does. Buy one of those and forget about it.
- A belt-drive deck running an AC synchronous motor derives its speed from the mains frequency. A 60Hz-market deck on a 50Hz supply runs slow, and no amount of transformer fixes that - a transformer changes volts, not hertz. Some designs have a swappable pulley or a switch for it; a lot of the cheap 70s stuff does not.
- Same principle applies to some open-reel and cassette transports with synchronous capstan motors.
So the question to ask a seller is not "is it 100V" (it is), it is "what kind of motor". Worth knowing before you bid rather than after.
2. The turntable ships worse than the amp, even though it weighs less
This one genuinely surprised me. I quoted two realistic boxed parcels out of Japan on 29 August:
| Code: |
14 kg amp 15 kg turntable
55x45x25 cm 60x50x25 cm
US economy air $102 COURIER ONLY $164
Australia sea mail $67 COURIER ONLY $156
UK sea mail $81 courier $139
Germany sea mail $67 courier $139
Singapore sea mail $58 courier $87
One kilo heavier and five centimetres wider, and to the US and Australia the economy and postal lanes simply refused it - only express courier would quote. Turntables are wide and flat, which is exactly the shape that hits dimensional limits before it hits weight limits. If you were budgeting a deck at amp money, do not.
Second surprise in the same test: on the 14kg amp to the UK, EMS quoted $279 against DHL's $129. The postal rate card stops being the cheap option well before it stops being available. I had been assuming EMS was always the budget lane and it is not, on anything heavy.
3. What the actual gear costs over there
For reference, live Japanese listings the same day: a Sansui AU-D607F Extra integrated at 14,000 yen (about $97), a Sansui T-alpha7 tuner at 15,600 yen (about $108), a Technics SL-1200MK3D graded "B" at 49,390 yen (about $341). Those are domestic secondhand prices for gear that goes through a restorer at several times that in the US or Europe. The arbitrage is real - the freight is what eats it.
Condition vocabulary is the other half of the job: 動作確認済 tested working, 現状品 sold as-is with no functional claim, ジャンク junk/for parts, 傷・汚れあり marks or staining. 現状品 and ジャンク are the two that should change your price, and shipping a 14kg parcel back is not a realistic remedy, so treat them as parts money.
I wrote the whole thing up with the full quote table, the transformer sizing bit and the customs situation here: Japanese vintage hi-fi: the 100V problem and what shipping actually costs
And if you just want to see what decks are listed in Japan right now as a price sanity check, this is the search I watch: turntables currently listed in Japan (full disclosure as before - that is the proxy service I use, so treat it as a price reference, not a recommendation).
Question back to the board: has anyone here actually been bitten by the synchronous-motor frequency thing, or is it more of a theoretical hazard these days? Every deck I have ended up with has been direct drive, so I have never had to solve it in practice. |
