PatchHamster – G1 patch manager (Linux), testers wanted
Page 1 of 1 [3 Posts]
alfnot
PostPosted: Tue Oct 27, 2026 11:08 am    Post subject: PatchHamster – G1 patch manager (Linux), testers wanted Reply with quote  Mark this post and the followings unread
Hi all,
As a G1 owner, I always felt overwhelmed by the huge number of patches in the archive on this website. I rarely found the sound I was looking for. That's how I got the idea for PatchHamster, a program that Claude and I have been working on for the last few months. It is now close to a first release.
What it is:
PatchHamster is a free program (GPL-3.0) for managing large collections of G1 patches (.pch, versions 2.10 and 3.0). It reads your folders and sorts the patches into categories (Bass, Lead, Pad, Keys, Drum, …). You can add your own tags and create your own categories, too. You can browse, search and filter them, see at a glance which modules a patch uses, and send a patch straight to a slot of your G1 to listen to it – directly via MIDI, the same way an editor does, or through Animatek NME.
First version: Linux. macOS and Windows will follow.
Before the release, I'd like to ask two things:
1) A question about the sorted collections:
PatchHamster knows the categories of many well-known patches because it learned them from two sorted collections in the archive: CategoriesArchive, made by Kristof Middendorf and edited by Wout Blommers, and the collection sorted by Tony Smyth. It ships a table that says which patch content was sorted into which category – no patches, only this assignment. Their names appear as the source in the program. If you are one of them, or can speak for them: are you okay with that? If not, I'll leave that part out.
2) Testers wanted (Linux):
If you run Linux and have a G1 (or Javier's G1-Emu) and would like to try PatchHamster before the release, please reply here or send me a PM. I'll send you the program (a small archive, about 2 MB) with a short guide – you unpack it and run one install script. I'm mainly interested in: does the installation work, and what was unclear when you used it for the first time?
Thanks for reading,
Fredi (alfnot)
PatchHamster main window
 Filesize:  286.26 KB
 Viewed:  30 Time(s)
cappy2112
PostPosted: Tue Nov 24, 2026 11:51 pm    Post subject: Re: PatchHamster – G1 patch manager (Linux), testers wanted Reply with quote  Mark this post and the followings unread
alfnot wrote:
Hi all,
What it is:
Fredi (alfnot)
Hello,
Thanks for making this available.
How does it determine the type of patch category?
alfnot
PostPosted: Wed Nov 25, 2026 10:14 am    Post subject: Re: PatchHamster – G1 patch manager (Linux), testers wanted Reply with quote  Mark this post and the followings unread
cappy2112 wrote:
alfnot wrote:
Hi all,
What it is:
Fredi (alfnot)
Hello,
Hi cappy2112,
thanks for your interest, you're the first one to reply Wink
good question. PatchHamster checks a few things for every patch it reads in, in this order, and stops at the first one that works:
1. If the patch is part of one of the two hand-sorted collections in the Nord Modular Classic Archive (CategoriesArchive by Kristof Middendorf, edited by Wout Blommers, and Tony Smyth's collection), it takes the category from the folder it's in.
2. If you have one of these collections in your read folders, it looks there for the exact same patch (same modules, cables, knob values, morphs, assignments and so on, only the file name or location can be different) and uses its category.
3. If you don't have the collections, there's a reference table built into PatchHamster. It holds no patches, just a fingerprint of each patch from the two collections plus the category the sorters gave it. So an identical patch still gets sorted.
4. If none of that works, it tries to guess from the file name. "DeepBass01" ends up in Bass, "TR909Kick" in Drum. If the name doesn't help either, it looks at the modules: audio input but no oscillator means effect.
5. Otherwise the patch stays under "no category".
Every automatic category also shows how sure PatchHamster is (high, medium or low). The first three steps give high or medium, a guess is always low and often wrong. You can change any category, add your own tags and authors, or make your own categories, and your changes are kept.
The first public version for Linux, Mac and Windows is nearly ready, I'll post here when it can be downloaded.
Fredi (alfnot)
