 Forum index » Clavia Nord Modular » G2 Patches - Completed » Synth
Nord Lead 2X Replica on the Nord Modular G2 - Bank
cybertribe
G2 patch files: 6
PostPosted: Sun Nov 08, 2026 9:28 pm    Post subject: Nord Lead 2X Replica on the Nord Modular G2 - Bank
Subject description: The NL2X Performances Replica Bank for the G2
The NL2X’s 4-slot performances rebuilt as G2 .prf2 files, on a G2 recreation of the NL2X engine, with knobs in panel order and the same MIDI CCs.
I rebuilt the Nord Lead 2X engine on the Nord Modular G2 and converted the NL2X’s 100 factory performances from its own sysex data. Each NL2X performance becomes a G2 performance: the NL2X’s four slots become the G2’s four slots, each running the NL2X engine with that slot’s program settings.
WHAT’S IN THE PACK
100 .prf2 files, one per factory performance, named after the original performance numbers.
Per performance, from the factory data: the program in each slot, which slots are active, keyboard splits and layers, bend range, unison detune, LFO clock sync, and the aftertouch and sustain pedal assignments (as G2 morphs).
HOW TO USE IT
Open a .prf2 in the G2 editor and send it to the G2, or store it in a performance location.
Play. Splits and layers are already set: the slots on the keyboard, and their key ranges, follow the original performance.
To hear one part on its own, select its slot (A to D). To mute a layer, take that slot off the keyboard in the performance settings.
Every slot has the same knob layout, in NL2X panel order (pages below), so tweaking feels the same on every part.
MIDI: each slot uses the NL2X’s CC numbers, so an NL2X editor template or controller map moves the same parameters. Slots on the keyboard follow the performance’s main MIDI channel.
The G2 effects (chorus, delay, reverb) are extras the NL2X doesn’t have. Set their mix to zero on page C2 for the dry sound.
WHAT’S INSIDE EACH SLOT
Every slot runs the same NL2X engine, laid out in labelled, colour-coded sections like the NL2X panel.
Oscillators
Osc 1 (OscB): saw, pulse with pulse width, triangle or sine.
Osc 2 (OscB): same waveforms, coarse and fine tune, keyboard tracking on/off; a Noise module replaces it when its waveform is noise.
Sync (switch): hard sync of Osc 2 to Osc 1.
FM (LevMult): Osc 2 frequency-modulates Osc 1.
Ring mod (LevMult): Osc 1 × Osc 2.
Mix (X-Fade): the Osc 1 / Osc 2 balance.
Unison (a detuned copy of Osc 1).
Pitch, Osc 2 pitch, pulse width and FM mixers: where the LFOs, mod envelope and mod wheel are summed into each destination.
Filter
Filter (FltNord): LP 12, LP 24, HP, BP and Notch+LP, with cutoff, resonance and keyboard tracking.
Filter Env (ModADSR) with amount and a velocity switch.
Distortion (Saturate).
Amplifier
Amp Env (EnvADSR) into the VCA, with velocity and LFO 2 tremolo.
Modulation
LFO 1 to pitch, filter, Osc 2 or pulse width; LFO 2 for vibrato, amp, filter or the arpeggiator.
Mod Env (EnvADR) to Osc 2 pitch, FM or pulse width, with amount and invert.
Arpeggiator: the G2’s built-in arp, set to the program’s range and mode.
Octave shift and mod wheel routing, as on the NL2X.
G2 effects (extra, in the FX area): Chorus → Delay → Reverb.
KNOB PAGES (NL2X panel order, the same in every slot)
A1: Osc 1 wave, Osc 2 wave, Osc 2 coarse and fine, FM amount, pulse width, Osc mix, sync
A2: Osc 2 keyboard tracking, noise, octave shift, unison, amp envelope ADSR
A3: filter type, slope, cutoff, resonance, envelope amount, velocity, keyboard tracking, distortion
B1: filter envelope ADSR, mod envelope attack, decay, amount and invert
B2: LFO 1 rate, waveform and amounts
B3: LFO 2 rate, vibrato and amp amounts, arpeggiator settings
C1: glide, volume, mod wheel destinations
C2: chorus, delay and reverb
C3: bend range, vibrato, octave shift and voicing
D1 to D3: the remaining controls (modes, ranges, curves, FX levels)
NL2X Performances.zip
Nord Lead 2X performances on the Nord Modular G2: all 100 factory performances
 Filename:  NL2X Performances.zip
 Filesize:  542.32 KB
 Downloaded:  15 Time(s)
NL2X F4 Moog Bass 1.prf2
Nord Lead 2X performances Demo - Bass
 Filename:  NL2X F4 Moog Bass 1.prf2
 Filesize:  22.11 KB
 Downloaded:  16 Time(s)
