Posted: Sun Jul 29, 2007 5:34 am Post subject:
Micro Modular Synced (?) to Engine? Subject description: Am i doing anything wrong?
Hi to everybody!
Here is the scenario:My Micro sends its sound to my engine.
My engine sends clock to Micro but these two doesn't quite seem to sync perfectly. The difference is audible, that is what i can hear after i connected the drum oscs and tried to stuck two drum sounds to test the setup?
Any ideas?
_____________
cyber-evolution
Hi G2Dream!
Did you try with the loop function OFF on the Micro?
Are you monitoring MIDI thru a DAW sequencer or is it (the G2 engine) directly connected to the Micro?
Thanks for your reply!
I tried it with the loop on and off but it had no result. The G2 sends directly its clock to the Micro.
Here is an example of the sonic result.
In this example i press multiple times the RUN button like Start/Stop but some times is on sync but other times...
G2 patch files: 49
Posted: Mon Jul 30, 2007 7:57 am Post subject:
I can't listen to your file right now so at the risk of typing complete nonsene: could it be that you need to use the "active" output from your midiglobal module (you probably can't connect it directly but need to patch a temporary high upon clock restart), to make sure that the micro sequencer always starts on the first beat after stopping/starting the clock? _________________ Spinning at ~0.0000115740740741 Hz
Joined: Jun 05, 2005 Posts: 473 Location: London, England
Audio files: 27
Posted: Thu Aug 02, 2007 5:37 am Post subject:
Hi mate,
I don't know anything about the original NM, but looking at your pictures, I'm guessing you need to patch the Active socket to the Reset socket to reset the squencer (NM) to the incoming clock, rather than just starting the internal clock... just a guess though. _________________ Sheridan
