lunetta sound samples
Page 5 of 13 [311 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7, ..., 11, 12, 13 Next
RF
Audio files: 28
PostPosted: Fri Mar 20, 2009 8:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah - I kinda like that, Rych Smile Very interesting progression...
On my 4017's/4066 clip the frequency divisions are being switched in and out based on fairly random choices from other Lunetta circuits.
If you have a steady A (440) going in to the 4017's, the seven divisions you get out in notes are..
220 A
146.6666667 D
110 A
88 F
73.33333333 D
62.85714286 B
55 A
and from there the switching of the 4066's determines which of these you hear.
I was thinking of that old "Piaa Chord Egg" idea - but I guess filtering and VCA's were fairly important to that effect.... All I got was an Iron Butterfly organ solo wannabe.
I'll experiment a bit more tonight. That recording was literally the first thing I got out of it.
bruce
www.sdiy.org/rfeng
slacker
PostPosted: Fri Mar 20, 2009 10:22 am    Post subject: Reply with quote  Mark this post and the followings unread
I like the sounds from the 4017 thing, it's pretty musical which I guess is because it's playing a chord.
Like Rych I'm not too sure I'd like to hardwire that much stuff just to do one thing. I'd be tempted to patch it out a bit to allow the different 4017s to be clocked separately and maybe make some of the divisions switchable.
Cool idea though.
RF
Audio files: 28
PostPosted: Sat Mar 21, 2009 7:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Still with the 4017 dividers...
Using one of the audio divisions (/7) to clock a counter which in turn modifies the audio which clocks the counters. Confused
Also- audio rate divisions /2 /3 /4 /5 are switched in and out based on those same counters.
Just a short snip of hands off noodling ...
bruce
Luna6.mp3
 Filesize:  1.16 MB
 Duration: 1:16
 Viewed:  3828 Time(s)
www.sdiy.org/rfeng
Rykhaard
PostPosted: Sat Mar 21, 2009 8:55 am    Post subject: Reply with quote  Mark this post and the followings unread
bruce
Whilst there seems to be a great deal of change within seconds, listening to the track overall, there seems to be a great deal of repetition. Confused Could there be a greater amount of change, within this setup, or is it going to be limited to a lot of the same variations?
In another view point - I DO like possibilities of repetition but I far prefer them if they can be slightly changed for opening up new possibilities. Lemme try this as an example
The repeating theme for a hookup:
- ABCDABCDABCDABCD
Make a single change
- ABEDABEDABEDABAED
Back to the first for a portion and then a different change part way through
- ABCDABCDCGBCDCGBCD
(Note in the 2nd change within the phrase, the 'length' of repetition also changes.)
Before I type more and confuse my explanation all the more ..... Surprised
View user's profile
RF
Audio files: 28
PostPosted: Sat Mar 21, 2009 9:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Yep - I understand what you are saying...
The repetition is just the simple patch - For the pitch and pattern I'm using one shift register and a binary counter - so the repeating pattern could have certainly be lengthened - even to unrecognizable with a just few more counters involved.
Mainly on that patch I was experimenting with influencing the timings with the 4017's...being clocked by the audio.
BTW - I listened to your last clip again this morning Smile I like the minimalist thing - very enjoyable.
bruce
www.sdiy.org/rfeng
Rykhaard
PostPosted: Sat Mar 21, 2009 9:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Otay! Very Happy Thankee. (Glad that U understand me. My method of delivery in communication, seems usually, to confuse others. Confused Someday I have to learn how to properly communicate. Laughing )
So then - has your earlier jury debate, come back with a decision as to the usefulness of the module itself? Is it worth building, as far as you went with it? If you feel there's enough possibilities for variation, then I'll go ahead a do a PCB for it. Smile )
Right then. Yesterday, I was going to mount 2 x CD4029's (4 bit up / down counter, not using the JAM inputs; but USING the Preset Enable as an 'Inhibit' function) to 2 of my 14 / 16 pin templates that I made the previous day ...... I realized I didn't have a PCB for the LEDs required though and was tired. Left it for later. I'll get those done then, as I don't yet HAVE any such counters in my machine.
bruce
!! Very cool! I've got a very strong desire to do some multi-tracking WITH that clip to expand it into a 'tune' as well. Also, with different multitracked versions. 1, along the improv. noise ideas and another, along the more structured format - i.e. turning a lack OF structure inTO a structured piece. Shall see what happens. Smile (Also hope to start writing lyrics for it, to use it as my first lyric based noise piece that I've done, in YEARS.)
Totally off subject: I've started constructing the web page section for my Lunetta machine (url is below). Would you (or any other readers) by CHANCE, know of a good FREE (or shareware) web page editor that has WYSIWYG functionality??
(Just now considering dumping HTML-Kit's freeware one as there's no WYSIWYG functionality. Razz )
I'm hoping to eventually develop this page into something of an 'information center' for Lunetta machines, explaining as many things about as I can, along with audio and visual examples of as much as I can - with user / viewer / person-reading commenting abilities / etc. - overall, to help readers who are curious / etc. Smile
View user's profile
RF
Audio files: 28
PostPosted: Sat Mar 21, 2009 10:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Good idea on the web page! Sorry - I can't suggest an editor...
I think that minimalist bit deserves some multi tracking Smile It'll be fun to hear what you come up with.
Re: the Jury.
I'm thinking there is a lot of possibility for mayhem. The 7 divisions of any clock or audio you feed it seems to be useful, and being able to switch those divisions on and off with other counters or logic has potential. I like the odd divisions - /3 /5 /7 - those might be more difficult to generate other ways.
I'm not sure about clocking each 4017 differently - I 'spose you could also reset each 4017 using Lunetta clocks/counters, too.... I have not yet tried either of these.
Anyway - Without the 4066 switches on the output it's this bit of circuit. Someone else throw it together and see what you think.
 Filesize:  12.86 KB
 Viewed:  22857 Time(s)
www.sdiy.org/rfeng
Audio files: 267
PostPosted: Sat Mar 21, 2009 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
When I was very young, I went to a lecture from a music professor at UC Berkeley. He was very entertaining; a big fan of Nielsen, as I recall.
Anyway, he said that there is someone's, I don't remember the name, law of composition - "Always twice, never thrice."
There is great wisdom in that little expression.
Rykhaard
PostPosted: Sat Mar 21, 2009 12:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
The most immediate of which to my interpretation is: do it once then improv. upon it, but no more, as the original intent may be confused if not lost.
There're quite a few ways to take it, depending on application. Very cool. Smile
I shall keep that in mind when setting down to do something with my minimalist piece that I last posted then. In parallel:
I'll do 2 additional multitrackings to it, separate from each other - so that the results are 2 new 'pieces'. One of them with the 'live improv.' thought and the other with a more organized and planned addition.
Shall post the results here. Smile
View user's profile
Rykhaard
PostPosted: Sat Mar 21, 2009 12:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not a trouble. Smile In going back to my original search area (c-NET / Download), I again found n-VU which i'd originally found had been abandoned. (Liked it muchlee, but buggy). It'd appeared that there were a new version. (DL'd / reinstalled.) Barely any difference. In searching through it's Help - found confirmation that it HAD been abandoned due to bugs, but that it's OFFspring - Kompozer was the latest. Off to download that and try it out. Smile )
Read my adapted reply to Mosc, in relation. Shall see what happens. Very Happy
Re: the Jury.
Otay! That's all, good enough to me! Very Happy When I do the PCB, I'll leave the clocking connections for each of the 4017's, OPEN so that I can assign them the same clock, or individual. If the latter works well, then I will finalize the front panel, for the switches. If not, then I'll leave them all to the single clock input.
Thank you for your further analysis! Looking forward to trying it out! Very Happy
View user's profile
Rykhaard
PostPosted: Thu Apr 02, 2009 9:35 pm    Post subject:  A short dual Slacker 4017 / 4051 Melody Generator demo Reply with quote  Mark this post and the followings unread
I just finished recording this 3+ minute demo from the 2 Melody Generators that I built for my machine today.
It was recorded onto my Korg BR-600's stereo microphones. I hadn't expected that they would pick up the sound of me closing my metal cigarette case as well as Zippo lighter! Those are the first 2 click sounds in the tune. Sad The later ones, are me flicking the switches for modulation ON and OFF on the 2 Liquid Voices that the Mel. Gen.'s are playing. 1 voice is hard panned to each side. (Though it's not as clearly noticable in the stereo microphone recording.)
No effects were used.
The recording starts off playing the fun melody that I had left it at, earlier this evening. About 1/3 of the way through, I adjust the clock speed of each of the 2 x 4 Bit Shift Registers that are both being driven by the same CD40106 oscillator, for their timing.
Approximately 1/2 way through the tune I change the panning for each of the voices, to the opposite stereo side.
Somewhere after that (when you start hearing more sharp clicking) I'm changing the modulation switches on the Voices, turning them On and off on each oscillator and finally shortly before the tune ends (and I've changed stereo sides again) I switch off all of the modulation of the voices, back to their pure selves and fade out.
I hope you like the example of this dual Melody Generator! I shall be building more of them in the future! Very Happy
View user's profile
RF
Audio files: 28
PostPosted: Fri Apr 03, 2009 5:36 am    Post subject: Reply with quote  Mark this post and the followings unread
The sound of a Zippo is as distinctive as the lighter itself is functional. Much more pleasing to the ear than the rough grating and plastic click of a disposable. I was a bit thrown by the metal case, though.
Oh - about the clip....
Interesting listening to the different yet related voices moving. Then as you increased the clocks that thing begins to scream.
Good job! Thanks for posting it!
bruce
www.sdiy.org/rfeng
slacker
PostPosted: Sat Apr 11, 2009 11:31 am    Post subject: Reply with quote  Mark this post and the followings unread
I recently build some of Rych's 4023 oscillators, and finally got round to recording something using them this afternoon. It's just 3 of the 4023 oscillators clocked by 6 40106 oscillators, a bit of delay and a lot of knob twiddling. It gets a bit loud at the end so watch ya speakers Smile
flight_of_the_oscillator.mp3
It's my attempt at a Rykhaard style live noise piece, hope he doesn't mind a bit of plagiarism.
telstarmagikistferrari
Audio files: 43
PostPosted: Fri Apr 24, 2009 7:47 am    Post subject: Reply with quote  Mark this post and the followings unread
here's a bit of random fiddling, not nearly interesting as some others posted here, but what the hey, thanks to RF for the synthesizer.
random.mp3
 Filesize:  5.75 MB
 Duration: 3:09
 Viewed:  3438 Time(s)
View user's profile Send private message Visit poster's website Yahoo Messenger
slacker
PostPosted: Fri Apr 24, 2009 9:36 am    Post subject: Reply with quote  Mark this post and the followings unread
I like it, sounds like some sort of crazy robot insect swarm.
RF
Audio files: 28
PostPosted: Fri Apr 24, 2009 10:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Great to hear your machine! More!
I'm expecting part of that was the 4051 pattern generator? What else was involved there?
bruce
www.sdiy.org/rfeng
Rykhaard
PostPosted: Fri Apr 24, 2009 11:56 am    Post subject: Reply with quote  Mark this post and the followings unread
A great overall AD-VENTURE type of sound at the beginning!! Almost like a 'march'! Smile
Is the deep hum at the bottom of the track, a Ground looping problem? (Like I have.)
1/2 way through, almost like laser blasts in a video game. Wink Military equipment making noises, during a computer battle. Heh.
Great harmonics changes in the swept sounds! Very Happy (The CD4023's??) The sound wonderful!!
Why the hell didn't I see this message earlier?? (2 weeks ago. Surprised )
What a GREAT live / improv. track!! Very Happy
Haha! Plagiarize away! I was far by, more'n happy with THAT performance!! Very Happy
View user's profile
Rykhaard
PostPosted: Fri Apr 24, 2009 12:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
WOWCH! As soon as it started in my headphones, it just about ripped my ears off!! Laughing Startled the crap outta me. Haha.
RIPPING!! It's almost like a noise machine being tortured! Twisted Evil
Machine gun rippings ....... (1:55'ish)
Grinding the guts out! (2:20) GREAT SOUND!
The final grinding tears! (2:50)
Oh my friggin' gawd! Very Happy That's a great aural assault track! Very Happy
View user's profile
Audio files: 43
PostPosted: Fri Apr 24, 2009 1:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Rych, (and the rest) coming from you that all means a lot! Smile
slacker
PostPosted: Sat Apr 25, 2009 4:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the comments Rych. I love the different textures you can get with the 4023 oscs, thanks for posting the design.
Yeah the hum in the background is from the cheap old guitar amp I use. I think it needs some attention, probably new power supply filtering caps.
Audio files: 43
PostPosted: Sat Apr 25, 2009 6:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's a little melodic stream of blips created with the following modules:
R/2R ladder
4024 divider clocked with a 40106
i discovered the pattern generator still operates with all of its switches turned to off and got interesting results; the 'default' melodic mode you hear at the beginning of the sample.
telstarmelodies.mp3
 Filesize:  3.69 MB
 Duration: 2:01
 Viewed:  3426 Time(s)
Rykhaard
PostPosted: Sat Apr 25, 2009 8:47 am    Post subject: Reply with quote  Mark this post and the followings unread
R/2R ladder
Now I'm VERY curious about this one! Could you tell me:
- which pattern generator the 4051 is? Is it's Slacker's?
- if so, could you let me know how you patched it all together to see if I can emulate it on my machine?
(I love making melodies with my machine. Having different melodies playing against each other, works really well. Smile )
View user's profile
droffset
PostPosted: Sat Apr 25, 2009 9:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
This all sounds great ! Smile
Finally finished my WSG, so I'll upload some Lunetta/WSG mutant samples soon. Smile
RF
Audio files: 28
PostPosted: Sun Apr 26, 2009 4:30 am    Post subject: Reply with quote  Mark this post and the followings unread
That's nice, Mark!
Rich - I think that 4051 pattern Gen is based on this bit of circuit...
Snipped from...
http://www.milkcrate.com.au/_other/sea-moss/07_1_bit_small.gif
 Filename:  4051.bmp
 Filesize:  85.38 KB
 Downloaded:  554 Time(s)
www.sdiy.org/rfeng
Audio files: 43
PostPosted: Mon Apr 27, 2009 9:09 am    Post subject: Reply with quote  Mark this post and the followings unread
three more samples of me messing around with RF's box. I love this thing. It really can make a wealth of different sounds. All of these rely on the R/2R ladder for the magic.
higrind.mp3
 Filesize:  2.76 MB
 Duration: 1:31
 Viewed:  3409 Time(s)
higrind_0003.mp3
 Filesize:  1.86 MB
 Duration: 1:01
 Viewed:  3417 Time(s)
higrind_0005.mp3
 Filesize:  1.87 MB
 Duration: 1:01
 Viewed:  3386 Time(s)
