Coming up on Radio 1 at
ScottG's Space Music
Page 1 of 1 [8 Posts]
Inventor
Audio files: 270
PostPosted: Thu Nov 12, 2009 2:33 pm    Post subject: ScottG's Space Music
Subject description: I coded it up in ChucK for him
Hey folks, I am in the chatroom now with ScottG and he had this cool idea for an additive synth that makes drones for space music. It's eight harmonics of sine wave amplitude modulated by a 1Hz filtered noise source every sample. It sounds really cool, though it is certainly a CPU hog.
Anyway I'm right now broadcasting the sound that it makes on my port of EM radio station, and Scott is listening. I can talk to him via the adc on top of the drone. If you don't have headphones, remove the adc => dac; line and you won't get a feedback squalch.
Enjoy the space music - it sounds like the mothership in flight!
Les
ScottGDrone2.ck
Scott's concept in ChucK form (with microphone) - use headphones please
 Filename:  ScottGDrone2.ck
 Filesize:  703 Bytes
 Downloaded:  851 Time(s)
Inventor
Audio files: 270
PostPosted: Thu Nov 12, 2009 2:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
This one is even better. It only uses prime harmonics.
Les
p.s. not a cpu hog anymore...
ScottGDrone4.ck
here it is, spacey...!!!
 Filename:  ScottGDrone4.ck
 Filesize:  739 Bytes
 Downloaded:  880 Time(s)
Inventor
Audio files: 270
PostPosted: Thu Nov 12, 2009 3:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Demo of the program - it records now! Too much of my cheezy voice over the music, but whatever.
Les
SpaceMusic.mp3
here you go! me talking over the space music...
 Filesize:  2.75 MB
 Duration: 3:00
 Viewed:  2308 Time(s)
Inventor
Audio files: 270
PostPosted: Thu Nov 12, 2009 3:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Scott had me add FM modulation in addition to the AM modulation, and it sounds even better. It's a real CPU hog though, maybe try uincreasing the update interval.
Les
ScottGDrone5.ck
now with FM modulation as well as AM modulation!
 Filename:  ScottGDrone5.ck
 Filesize:  1.15 KB
 Downloaded:  905 Time(s)
kijjaz
PostPosted: Thu Nov 12, 2009 3:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Got you two another drone I usually use in many shows. Easy to set up. FM-style with reverb.
Code:
48 => float BaseNote;
TriOsc a => Gain a_g => SinOsc b => BPF b_f => NRev rev => Dyno limiter => dac; // Main Generator
3 => a_g.op;
BaseNote => Std.mtof => b.freq;
2 => b.sync;
2 => rev.gain;
.9 => rev.mix;
limiter.limit();
999999 => limiter.ratio;
.25 => limiter.gain;
TriOsc c => a_g; // LFO
.04 => c.freq;
b.freq() * .25 => a.freq;
b.freq() * 1.5 => a.gain;
4 => b_f.Q;
while(true)
    (c.last() + 8) * b.freq() => b_f.freq;
    ms => now;
Inventor
Audio files: 270
PostPosted: Thu Nov 12, 2009 4:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks kij, sounds awesome!
Les
PostPosted: Fri Nov 13, 2009 3:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice refinements, Les; thanks for your chuck script, Kijjaz. They still still have unwanted noise on my XP, so I am interested to know from Scott if they will work on a 500MHz processor system. Thanks for starting this thread, guys. Steve
Inventor
Audio files: 270
PostPosted: Fri Nov 13, 2009 4:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Steve, to see if it is the cpu, try reducing the number of harmonics and increasing the udate rate. The noise should go away. It is possible the noise is due to clipping or CPU, could be either or both.
Les
