Joined: Jan 07, 2009 Posts: 1231 Location: Scottish Borders
Audio files: 163
Audio files: 19
Posted: Sun Oct 10, 2010 3:17 pm Post subject:
| Skrog Productions wrote: | and an eyebrow raising 1970's album sleeve from Mr Gorgio Moroder to cheer you up when soldering the M-185 , i hope i'll be sequencing like him when i finish building this heh.
And what a FAB LP that is too!! I've got a very rare copy of this very Giorgio LP on CD!
And when I've got the money, I'll be ordering my M-185 (or 3) too!  _________________ ACHTUNG!
Audio files: 19
Posted: Sun Oct 10, 2010 3:18 pm Post subject:
Forgot to mention, what a nice panel too!!  _________________ ACHTUNG!
Audio files: 163
Posted: Sun Oct 10, 2010 3:23 pm Post subject:
thanks , this is the perfect companion to my Klee sequencer , i'd better start doing some music again , too many hours with a soldering iron
Dave |
nerdware
Posted: Sun Oct 10, 2010 4:05 pm Post subject:
A very tasty panel, well up to your usual high standard. It's also good to see someone using the daughter board. Thanks for the pics! _________________ http://soundcloud.com/nerdware/
"render unto digital what is due to digital, render unto analogue what is due to analogue" |
Audio files: 163
Posted: Sun Oct 10, 2010 4:11 pm Post subject:
Thanks ,they look ok from a distance heh , yes , i did not want to loop all those resistors on the first switchs , easier to work with all the panel ladders & diodes on a bit of vero-board .
Dave. |
Audio files: 163
oozitron
Posted: Sun Oct 17, 2010 7:09 pm Post subject:
I *really* want to build this!!!
I have an enclosure (an old 8 channel mixer) that would make a beautiful table-top sequencer, and this would be the perfect match.
I would buy a kit (PCB & board mounted parts)...
I would buy a bare PCB... (with the PIC maybe?)
I would even build it on protoboard if the docs were available!
Is any of this available???
Sequencer Freak Drew |
tomcat
Posted: Wed Oct 20, 2010 11:38 am Post subject:
| Yes PCBs please! |
vtl5c3
Posted: Wed Oct 20, 2010 8:20 pm Post subject:
Wow. THat's a beauty!
| Skrog Productions wrote: | | front again |
patchdub
Posted: Wed Jan 12, 2011 6:57 pm Post subject:
are there still pcbs available for this? or does anyone have an extra?
pretty please! _________________ www.patchdub.com |
nerdware
Posted: Thu Jan 13, 2011 4:02 am Post subject:
I'm also interested in (more of) the PCB/PIC/Switches. _________________ http://soundcloud.com/nerdware/
ryktnk
Posted: Thu Jan 13, 2011 6:46 am Post subject:
Hello
Sorry.
All the PCBs and PICs are now sold out.
The switches I cannot obtain any more - they are no
longer manufactured by the supplier.
-ryk |
nerdware
Posted: Thu Jan 13, 2011 7:07 am Post subject:
So no chance of another run?  _________________ http://soundcloud.com/nerdware/
jcoplin
Posted: Sat Jan 15, 2011 8:46 pm Post subject:
PIC Source available? |
| ryktnk wrote: | | emdot_ambient wrote: | @ryktnk => Humble request...would you please post the latest documentation on the first page of this thread? It's rather difficult to locate as it is. Thanks!  |
Hello
It is now done - good idea.
-ryk |
Would it be possible to get the PIC image so we can burn or own chips? Seems to be the only thing missing to roll our own since you are probably completely sick of the unit by now. Unless I missed somewhere in the 25 pages. Thanks! |
oozitron
Posted: Tue Jan 25, 2011 6:47 pm Post subject:
Hey, if anyone is still here...
I'm about to start building this sequencer. It's going to be house in an old Tascam mixer case. Sliders for the voltage controls
I'd like to play with resistor values for R10, etc, which are the 8 resistors that "feed" the LEDs. Can anyone tell me what voltage would be present on the Transistor side of R10 ? (ie the voltage when the corresponding LED would be ON of course )
tanks!
Drew |
ericcoleridge
Posted: Wed Jan 26, 2011 1:37 pm Post subject:
I bought a pic chip and board when these were available, but I never had the money on hand to buy the switches.
I definitely want to get to this project, and so now I'm sort of just wondering what my options are for replacing the switches that were originally for sale?
I think I remember someone saying that the switches could be replaced with plain old potentiometers-- can anyone confirm that? So, as the pot is turned, the number of stages increases (decreases?). |
Danno Gee Ray
Joined: Sep 25, 2005 Posts: 1351 Location: Telford, PA USA
Posted: Wed Jan 26, 2011 2:53 pm Post subject:
| As I recall, the switches can be replaced by 50K pots. |
oozitron
ryktnk
Posted: Fri Jan 28, 2011 7:19 am Post subject:
| oozitron wrote: | Hey, if anyone is still here...
Drew |
Hello
Sounds fun.
The voltage from the transistors is
just under 5v, something like 4.9.
Beware though, there is a special LED
ground bus, that varies between two
voltages, to create a "cheap" brightness
change when the Gate Out is high.
-ryk |
ryktnk
Posted: Fri Jan 28, 2011 7:30 am Post subject:
| ericcoleridge wrote: |
Hello
Yes you can use pots, 50k Lin, not higher.
You will get a 180deg range on an
Alpha type pot.
Have a look at the STAGES control
on my panel, for a rough idea of the
markings :-
http://m.flickr.com/#/photos/ryktnk/3592814417/sizes/l/
Also using pots is much, much easier
to wire !
-ryk |
ericcoleridge
Posted: Sat Jan 29, 2011 3:36 pm Post subject:
Ryk,
Do you know of a wiring example anywhere for using pots instead of switches? How would this work?
| ryktnk wrote: | | ericcoleridge wrote: |
Hello
Alpha type pot.
markings :-
to wire !
-ryk |
ryktnk
Posted: Tue Feb 01, 2011 3:03 pm Post subject:
| ericcoleridge wrote: | Ryk,
Hello
Yes.
Wire the signal for the POT1-8 froms
the pcb, and connect to the CW side
of each 50k pot, the CCW sides
connect to GND.
The Centre Wiper of the 50k pots
should be summed via diodes to
the CT bus on the pcb.
It is the same as the Stage CV wiring
except the wiper diodes sum to the CT
bus.
( Have a look at the panel wiring
document to see the Stage CV )
hope this helps
-ryk |
blackcelcius
Joined: May 12, 2008 Posts: 12 Location: knokke(belgium)
Posted: Tue Feb 01, 2011 3:21 pm Post subject:
| ryktnk wrote: | Hello
Sorry.
-ryk |
Is it not possible to do another run of pcb's with pics for people who are willing to build the unit with linear pots.Im sure the demand is still high enough...
Or if you are tired of the project could you not do something like jurgen haible or ian fritz,putting the pcb's and so on on The bridechamber ?
Just a thought since there is still a high interest in the project.... |
ryktnk
Posted: Wed Feb 02, 2011 10:18 am Post subject:
| blackcelcius wrote: |
Hello
Yes it could be possible to do another PCB run.
Not sure how soon - it is not my day job.
PMs welcome for committed purchasers, who don't mind waiting a while.
Thanks
-ryk |
