Brief maintenance shutdown at 10:00 PM EST - 0400 UTC
Coming up on Radio 1 at
Injured Steinway
Page 1 of 1 [4 Posts]
ocp
Audio files: 9
PostPosted: Sun Nov 14, 2010 2:56 pm    Post subject: Injured Steinway
Subject description: piano
This is a raw recording of an "injured" Steinway grand piano.
It was made back when I worked in a casino as a sound engineer.
The Steinway piano had been lying backstage on it's side since forever.
It was then put in a trolley on stage as the hall was being dismantled and a solution had to be found for the piano.
An expert was called in and the verdict was not a favorable one: the metal frame was cracked, and it was not the first time a repair had been made; too expensive to fix.
So it was decided to dump it in the casino's warehouse.
I grabbed the opportunity and made the possible recordings, of which this is a sample.
Some casino backstage noise is present too.
injured Steinway.wav
Steinway & Sons grand piano recorded with Sony mic and minidisc.
The piano was lying on it's side with the lid removed as well as the fall.
What you hear is direct intervention on the strings with nails and plastic cup.
 Filesize:  4.97 MB
 Duration: 0:30
 Viewed:  2053 Time(s)
https://opcabpol.bandcamp.com | https://www.mixcloud.com/Boiar | http://editoradoporto.blogspot.com |
ocp
Audio files: 9
PostPosted: Sun Nov 14, 2010 3:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's another clip of some abusive action on the poor piano.
You can hear rocks hitting the bottom of the piano - thrown by fellow musicians - as I hid behind it.
I must highlight the fact that this was a once in a life time opportunity to cannibalize a Steinway piano which was about to be dumped - for all eternity - in a warehouse.
BTW, the cement rocks were all around this hall which was going through serious remodeling.
beating a dead piano.wav
stoned piano
 Filesize:  8.7 MB
 Duration: 0:52
 Viewed:  2013 Time(s)
shanemorris
Audio files: 102
PostPosted: Mon Nov 15, 2010 8:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Love the titles and sounds ! Razz
ElectroCasa
ocp
Audio files: 9
PostPosted: Sun Nov 21, 2010 7:40 am    Post subject: Reply with quote  Mark this post and the followings unread
