 Forum index » Online Music
Alien Spoonbending
Page 1 of 1 [5 Posts]
Audio files: 730
PostPosted: Tue Jan 28, 2014 11:11 am    Post subject: Alien Spoonbending
Subject description: improv with zero input alienator and other DIY devices
something I recorded last nite. I used the Alienator as a zero input mixing device, but I also had the simple sampler recording it's output and feeding
it back to the input (not sure if this still counts as zero input, although it's basically just a long delay Wink) I hooked up the Lun-A-Key to the Soundbender,
which is a modulator based on a XR2206 chip, and used the modulation source of that (triangle wave) to create a droning sound. This was then fed
into a weird UAA180 based waveshaper I breadboarded (a bit similar to the 5 pulser) and there was some extra (chorus + reverb) effects added to
the output of that. The waveshaper was modulated by a random voltage generator with an extra capacitor added to the CV input to create a gliding
effect. I also hooked up my RGB shroom synth for some pingy sounds. The Lun-A-Key was controlled by midi data I received from Blue Hell, which is
(partially) generated by the chat, and I used that to control the simple sampler and delay time on the alienator aswell.
I will post some longer bits later but here's a short section that also included some samples/loops. Cool
PHOBoS - Alien Spoonbending (Zontar radio mix).mp3
"although his name is untranslatable to any Earth language, it would sound something like Zontar"
 Filesize:  12.81 MB
 Duration: 14:00
 Viewed:  4224 Time(s)
Alien Spoonbending patch
 Filesize:  55.93 KB
 Viewed:  1009 Time(s)
The Golden Shrimp Guild
Audio files: 730
PostPosted: Thu Jan 30, 2014 11:16 am    Post subject: Blue Spoooooon! Reply with quote  Mark this post and the followings unread
Here's a longer part which was mixed with live generated music from Blue Hell.
PHOBoS feat. Blue Hell - Alien Spoonbending (Blue Spoons version).mp3
Blue Spoooooon!
 Filesize:  27.17 MB
 Duration: 29:41
 Viewed:  4132 Time(s)
PostPosted: Fri Jan 31, 2014 2:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Enjoying this, Phobos!
Audio files: 730
PostPosted: Fri Jan 31, 2014 2:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Kevin, glad you like it Very Happy
PostPosted: Fri Jan 31, 2014 10:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
That is really awesome. The Zontar mix vaguely reminds me of some droney bits from My Life in the Bush of Ghosts, though maybe that's just the distorted vocal samples Wink
