Audio files: 730
Posted: Sat Apr 21, 2018 1:48 pm Post subject:
PHOBoS & Blue Hell - apples & bananas Subject description: Live improvisation, recorded april 20th, 2018
apples from Blue Hell and bananas from the Moon Base.
a bit droney
a bit dark
a bit psychedelic
PHOBoS & Blue Hell - apples & bananas (part I).mp3
Filesize:
40.63 MB
Duration:
44:23
Viewed:
3834 Time(s)
PHOBoS & Blue Hell - apples & bananas (part II).mp3
Filesize:
41.32 MB
Duration:
45:08
Viewed:
3839 Time(s)
Filesize:
1.46 MB
Viewed:
934 Time(s)
I think you may be mixing up your fruit photos, but the mixing of your fruit sounds is really nice! I like it a lot! Thanks for sharing.
.:james:.
P.S. I feel a little sheepish mentioning this, since I don't want to take focus away from this great music, but the high-pitched drone at the beginning of Part I reminds me a bit of an old drone piece I did using VFD's... it can be listened to for free here: http://squint.press/00v_james-schidlowsky_ringen/ .
Vacuum Fluorescent Displays. One can feed sound through them, and pick up the vibrations of the filaments. It sounds a bit like ring modulation, and pretty high-pitched. I got the idea from The Electronic Peasant ( http://www.electronicpeasant.com/projects/ringmod/trmod.html ).
My piece is based on an improvisation I did using 4 of them, then I took the recording and made 3 copies, each slowed down (affecting pitch) to different speeds. As the piece progresses, I mixed in one of the slowed copies until at its peak, all 4 copies/octaves are heard.
Audio files: 730
Posted: Sun Apr 29, 2018 4:27 am Post subject:
thanks for listening and commenting james, much appreciated
Ringen was a nice listen and now the videotapes and display photos make more sense too. (I still have a lot of old videotapes myself.
not sure what to do with them,. I thought about putting NANDulators in it for a bit but after opening one up I discovered that there is
less space in there than expected because of all the reinforcements that keep the tape from falling apart) _________________ "My perf, it's full of holes!" SoundCloudBandCampMixCloudTwitchYouTube The Golden Shrimp Guild
