Er, is this piece really 1 minute, 35 seconds? Just asking, because a lot of your pieces are much much longer... like the epic & fun "Flubber Dubber" at 2 hours 16 minutes! Anyway, it's cool. _________________ .: james :.
Audio files: 730
Posted: Mon May 17, 2021 1:51 pm Post subject:
some background info on how this piece was created:
I started with a self playing patch which also made use of my recently coded midi looper.
While this patch was playing I recorded a part of it and using ACID music studio I played it back as a short loop.
Oh and I also added a looped sound of a closing door with some effects.
So now I had the live patch and a looped section of it playing together and I recorded another part of that.
This was also added in ACID music studio as a loop so now I had the live patch and 2 loops playing.
It was recorded again, added, recorded again added, for a total of 4 or 5 times. I'm not sure if the 5th one got
in because that's when ACID became unresponsive (of course I also hadn't saved it yet). Luckely it did keep
playing so I recorded some of it and that was cut into a looping section and posted here.
I also did some things with the different loops, one was reversed, one was pitched down, there is shorter loop
in there and I also added some delay and made panning and EQ adjustments. _________________ "My perf, it's full of holes!" SoundCloudBandCampMixCloudTwitchYouTube The Golden Shrimp Guild
