sneakthief
Posted: Sat Jan 20, 2007 3:10 pm Post subject:
lack of interest - are you kidding? this thread is already 16 pages long with over 16636 views
as much fun as i had rigging an experimenter's pcb for my twin-sn, i'll gladly do a stripboard (or three).
i think it's safe to say that there are more than a few people who are waiting for superklee developments with great anticipation!
keep up the good work, uncle krunkus. _________________ Sneak-Thief - raw electrofunk |
Scott Stites
Audio files: 97
Posted: Sat Jan 20, 2007 7:31 pm Post subject:
To be honest, I'm really only interested in the music others might create with it. If anybody wants to make money with it, whether by selling boards, kits, or completed Klee, fine by me; I expect nothing in return. Besides, I think Uncle K put more work into it than I did (my part was the fun part).
Scott |
The Alison Project
Posted: Sat Jan 20, 2007 8:17 pm Post subject:
I would also buy pre-done stripboards for your Dimension C project hint hint, or full component kits.
chris |
Posted: Sun Jan 21, 2007 6:52 am Post subject:
I didn't mean there was a lack of interest in the topic! Just that I couldn't imagine a great many people getting interested in half populated stripboards.
I'll keep an eye on how many of you seem keen, but remember, I'm doing these layouts, then the next priority is to finish the Sorcerer, then I'm starting on the DimC and DM-2. So don't tell your Granny that her Super Klee will be finished for Easter just yet.  _________________ What makes a space ours, is what we put there, and what we do there. |
sneakthief
Posted: Sun Jan 21, 2007 7:06 am Post subject:
| Uncle Krunkus wrote: | I didn't mean there was a lack of interest in the topic! |
My good man, 'twas merely an inference based on the amount of interest
I think it's safe to say that not everyone wants to make their own PCB or stripboard and would jump at the chance of you providing some!
Might I add that most of us modular folk are a relatively patient bunch - so no big rush. _________________ Sneak-Thief - raw electrofunk |
Posted: Sun Jan 21, 2007 11:47 am Post subject:
| sneakthief wrote: | | Might I add that most of us modular folk are a relatively patient bunch - so no big rush. |
or always busy with a bunch of projects...  _________________
Tech Buddy at Random*Source |
Posted: Mon Jan 22, 2007 6:25 am Post subject:
Klee Stripboard Layouts Subject description: Last updated 25-1-07 |
Okay,
here are the three layouts as they stand at the moment.
If you're keen to get started on this I'd begin with board 1. It's been checked, double checked, and tweaked at least three times. So has board 2, but board 3 has not even been visually checked yet.
The designators reflect which schem the component can be found on, so: -
XX = Clock & Load
2XX = Stage Encoder
3XX = Step Decoder
4XX = Max Voltage Scaler (Option 2)
5XX = Voltage Output (Enhanced)
6XX = Gate Trigger Bus
Where XX is the original designator on the schem.
I'll update this post over the next week or two once board 3 gets checked. I'll also include how many links are on each board etc. and any other building hints and clarifications which are requested. I just wanted to post the set tonight so I could start bathing in the glory!
The attached zip has been updated as of 25-1-07. Board 3 checked, link details added.
 Download (listen) |
| Filename: |
Klee Stripboards.zip |
793.89 KB |
| Downloaded: |
546 Time(s) |
_________________ What makes a space ours, is what we put there, and what we do there. Last edited by Uncle Krunkus on Wed Jan 24, 2007 7:04 am; edited 2 times in total |
vtl5c3
Posted: Mon Jan 22, 2007 1:41 pm Post subject:
Hullo Unka Krunkus,
I'm not very familiar with the stripboard thing, so I wonder if you could answer a couple of questions.
1) Is the kind of board that you used for the Klee the same as what Mouser sells as the 854-ST3U ( http://www.mouser.com/catalog/628/1823.pdf )?
2) Are the cuts the spots marked in Yellow and Green on the Klee (cs) diagrams?
BTW, thanks for the work you've put into this. The thought of laying this one out myself was really intimidating.
Romeo
[Edit by Blue Hell : made link clickable by adding spaces around it] |
goodrevdoc
Joined: Sep 11, 2006 Posts: 288 Location: Philadelphia, PA
Posted: Mon Jan 22, 2007 10:25 pm Post subject:
Whoa ! Those are pricy. Does anyone know of a cheaper source for these sized boards? I've never stripboarded, but really want to try this project and figure It's a good excuse to give it a go. Also is there a special tool for making the track separations?
-justin |
Posted: Tue Jan 23, 2007 2:53 am Post subject:
I can't find what I'd call standard stripboard anywhere on the mouser site. Man that's weird! To me, an electronics supplier who doesn't have stock standard stripboard would be like a hardware shop that doesn't sell screwdrivers!
click here
That's where I get mine. Should be about US$7 for the 100*300mm one, or something similar. It has continuous strips that run the full length of the board.
vtl5c3 - The grey spots on the CS side are the solder points. They match up with the component leads going through from the other pic. The cuts are the yellow breaks in the "copper" coloured tracks. The only green parts on the drawings are 4 and 8 pin connectors for the ribbon cables which go between the boards, and the boards and the front panel.
goodrevdoc - There is a special tool for cutting the tracks, but I use a 3mm drill bit in a pin vice. Just give it one or two turns, and the track should be broken. Don't go right through! and check them as you go.
It's a good idea when you're starting off to cut the tracks between the IC sockets, and solder the IC sockets in, before continuing on with the track cutting. That gives you some solid landmarks to get your bearings from, make sure the board is up the right way, etc. _________________ What makes a space ours, is what we put there, and what we do there. |
Scott Stites
Audio files: 97
Posted: Tue Jan 23, 2007 8:07 am Post subject:
Unca K,
You'd be shocked. For some unexplained reason, in the US stripboard/Veroboard is an exotic commodity that ranks right up there with curdled cream and frogskin bikinis. It is very hard to locate. Google Stripboard or Veroboard, and you'll see a lot of UK/Aussie/Euro hits, but very few US hits.
Be that as it may, I've procured it from the following places:
http://www.futurlec.com/ProtoBoards.shtml
(Largest Futurlec too small?)
In Canada:
http://www.rpelectronics.com/
(Expensive).
I found some somewhere at some time here in the US, but can't remember where it was. Be that as it may, I've never tried this, but I've got a feeling it just may work:
http://www.allelectronics.com/cgi-bin/item/ECS-4/455/SOLDERABLE_PERF_BOARD,_LINE_PATTERN_.html
I'll try to recall where I got the other stuff - it was an opportunistic "I wonder if that stuff is any good" purchase along with some other stuff, now I've totally forgotten where I got it.
Scott |
Posted: Tue Jan 23, 2007 8:20 am Post subject:
Bizarre, truly bizarre!
It's like looking into a time machine set for the 1800's! Next thing you'll be telling me the USA still use imperial measurements, or some other crazy talk!!  _________________ What makes a space ours, is what we put there, and what we do there. |
Scott Stites
Audio files: 97
Posted: Tue Jan 23, 2007 8:54 am Post subject:
| Quote: | | Next thing you'll be telling me the USA still use imperial measurements, or some other crazy talk!! |
That is entirely due to the political power of the foot long hot dog consortium.
Edit: And would "Pulp Fiction" be "Pulp Fiction" without the "quarter pounder with cheese" conversation? ("Hey, check out the brain on Brad").
Cheerios,
Scott |
Fidgit
Posted: Mon Jan 29, 2007 8:24 am Post subject:
uncle: is there a parts list which is alligned to your stripboards (or vice versa)? maybe somewhere else on these 16 pages...
tnx |
Audio files: 19
Posted: Mon Jan 29, 2007 10:27 am Post subject:
| Fidgit wrote: | maybe somewhere else on these 16 pages...
Try right at the beginning?!  |
Posted: Mon Jan 29, 2007 1:39 pm Post subject:
I kind of agree with Tom, in that, for a project of this size you really need to study the schematics and know them well to improve your chances of putting together the stripboard versions successfully.
However,.....
I know there are a lot of people out there who are interested in the Super Klee, there is currently no enormous silk screened PCB and kit of parts for it, and I'll do what I can to make it easier for you. Of course you'll have to nominate me for a Nobel Peace Prize. (Or at least donate the next Jupiter8 you get your hands on to my firstborn!! )
Here it comes. _________________ What makes a space ours, is what we put there, and what we do there. |
Fidgit
Posted: Mon Jan 29, 2007 2:28 pm Post subject:
i promise  |
mono-poly
Joined: Jul 07, 2004 Posts: 937 Location: Rotterdam, Netherlands
Posted: Tue Jan 30, 2007 9:38 am Post subject:
Lol no one crazy enough to do a pcb layout?
I might organize a run off boards if Scott is fine with that.
I just aint such a great designer. |
Posted: Tue Jan 30, 2007 1:06 pm Post subject:
| mono-poly wrote: | Lol no one crazy enough to do a pcb layout?
do you think i should do a design for doublesided PCB(s) in expressPCB? _________________
Posted: Tue Jan 30, 2007 3:40 pm Post subject:
Hey Matthias,
How would you suggest I go about getting into ExpressPCB. Is ExpressPCB what State Machine used for that SN VCO layout?
I love stripboard, and will always enjoy designing for it, but there are some projects for which stripboard becomes a bit of a link-fest, and those links need to be put in by everybody who puts one together. Not to mention the cuts.
PCB design would be more about just that, design, and I think my background in stripboard could carry me a long way. _________________ What makes a space ours, is what we put there, and what we do there. |
Posted: Tue Jan 30, 2007 4:38 pm Post subject:
| Uncle Krunkus wrote: | Hey Matthias,
How would you suggest I go about getting into ExpressPCB. Is ExpressPCB what State Machine used for that SN VCO layout? |
yes, bill used expressPCB, AFAIK. the PCB service is not that cheap IMO, especially for small runs.
what i love expressPCB for is that it is very easy to use. it consists of both a schematic editor and a pcb designer and both are linkable: you draw the schematic first and then link it to the design file (no autorouter), then you're able to check all connections - the net.
you can easily create your own symbols, parts...
just download the editors and start! it's almost self explaining. _________________
Posted: Tue Jan 30, 2007 4:48 pm Post subject:
Could you print off what you've done and etch it yourself rather that use their service? _________________ What makes a space ours, is what we put there, and what we do there. |
Posted: Tue Jan 30, 2007 11:44 pm Post subject:
| Uncle Krunkus wrote: | | Could you print off what you've done and etch it yourself rather that use their service? |
you can but with drawbacks. first you have to set the colors in the view options and then you'll get a "positive" printout: it will be the view from the components side of the board (as if the board were transparent - which is fairly fine for press'n'peel blue).
furthermore you can export the BOM, the schematic and the silkscreen.
with a little effort you can do a good documentation, i.e: waspVCF _________________
mono-poly
Posted: Wed Jan 31, 2007 4:08 am Post subject:
I am not sure what everybody want's
Single or double.
I think single might be better but what do other people think? |
