 Forum index » Clavia Nord Modular » G2 Patches - Completed » Acoustic
PM resonator
Page 1 of 1 [4 Posts]
Christophe Duquesne
G2 patch files: 6
PostPosted: Sun Feb 04, 2007 1:29 pm    Post subject: PM resonator
Subject description: PM resonator derived from Chet and Robby's patch
This patch is based on a PM resonator derived from Chet and Robby's patch but with one main improvement: a compress/expand mechanism has been added in the loop of the resonator in order to maintain the signal level (raise or lower it depending of its evolution).
The main goal was to be able to add some processing inside the loop without killing the signal.
I although added a "voice filter" on the Noise used to start the resonator, and a larsen control on AT.
So this is the first result of this work (I'm quite happy with the result for this first step Laughing ): my aim is not really to "rebuilt" existing instruments (just use a Piano if you need a Piano...), but to create new ones with an accoustic like sound....
You can experiment it with the 8 variations... or try naything else you want...
There is still some work to do:
* add much more expressiveness (wich is the key point in PM, in my mind)
* experiment several processing in the resonator loop
Nb: I will be out (abroad) for a couple of days, so I may answer quite late to you comments, if there are some....
HoldupResonator.pch2
Hod up PM resonator derived from Chet and Robby's patch
 Filename:  HoldupResonator.pch2
 Filesize:  3.34 KB
 Downloaded:  2514 Time(s)
Christophe Duquesne
Audio files: 267
PostPosted: Sun Feb 04, 2007 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is already pretty interesting. Very organic sounds to be sure. I look forward to seeing your improvements. Thanks for sharing.
Former site admin
Audio files: 353
PostPosted: Thu Feb 08, 2007 4:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, that makes some really nice low tones !
View user's profile
Christophe Duquesne
G2 patch files: 6
PostPosted: Fri Feb 23, 2007 11:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
Here is the promised update of the first "Holdup resonator"...
It has 8 very different variations to give some ideas of different uses you can get from it.
I guess I can do some thematic work on the vairations now... hope to find some time to work on it... but feel free to add your own variations ..and to share them of course ...
HoldupResonator3.pch2
update of the "Holdup resonator" & 8 very different viriations
 Filename:  HoldupResonator3.pch2
 Filesize:  4.06 KB
 Downloaded:  2283 Time(s)
Christophe Duquesne
