 Forum index » Online Music
A Saturday Mix
Page 1 of 1 [13 Posts]
EdisonRex
Audio files: 172
PostPosted: Sun Mar 18, 2007 12:00 pm    Post subject: A Saturday Mix
Subject description: So I could use another ear or two.
I've been busy in the studio trying to get used to some of my newer kit. So I put together another study. I've made three separate mixes, and I'd like some comments, if anybody would be kind enough to comment. I've chosen the last mix I did.
This was produced using:
Pad - Hartmann Neuron (modified Fatpad 2)
Bass - Moog Voyager
Bass 2 - Poly Evolver (it goes with the pad)
Arpeggiated - Studio Electronics SE1-X
"lead" - Metasonix S-1000
Percussion - Akai S-6000 with some sampled percussion
I played the arpeggios, and the drums are sequenced but not programmed either. So there's some imperfection in both. I haven't hunted it all down yet. The Wretch is very cantankerous, and will drift during a mix, so you kind of have to pay attention to it if you are trying to stay melodic. The SE1-X tends to drift a lot, but not like the S-1000.
Anyway, I tried to make it all sound kind of dark, like a rainy saturday.
153-Saturday-Mix.mp3
 Filesize:  7.01 MB
 Duration: 5:06
 Viewed:  6037 Time(s)
Garret: It's so retro.
Audio files: 267
PostPosted: Sun Mar 18, 2007 12:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sounds good to me. You are off to a good start. Very Happy
EdisonRex
Audio files: 172
PostPosted: Sun May 20, 2007 9:56 am    Post subject:
Subject description: Another Saturday, another tune
This was going through my head all week. I sat down at the piano and modeled what I wanted to sound like, then started over in the studio.
Still rough, but I think it's worth posting. I need more dynamics in it. I didn't automix it yet.
155_May_2007.mp3
 Filesize:  7.38 MB
 Duration: 5:23
 Viewed:  6000 Time(s)
Dovdimus Prime
Audio files: 6
PostPosted: Sun May 20, 2007 1:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
First one does sound good - rainy day description is apt.
Second one is a bit daytime TV for my liking to be honest. But still way better music than I can write!
This message was brought to you from Beyond The Grave.
EdisonRex
Audio files: 172
PostPosted: Sun May 20, 2007 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Daytime TV? Laughing Laughing Laughing
I don't watch TV. But I think I know what you're getting at. I was more aiming for Lyle Mays than Oprah. Well that gives me something to think about for the next mix! Thanks, truly, for the comment. Very Happy
Oh and thanks about the first Saturday mix. I didn't actually change the mix since then. I had a lot of positive responses. Just not as responses in this thread Rolling Eyes
Audio files: 267
PostPosted: Mon May 21, 2007 12:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes the second one sounds very professional. It could well be the theme for a daytime soap. Good job. Very Happy
seraph
Audio files: 33
PostPosted: Mon May 21, 2007 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
nice mood but the timing could be tighter (at least for my taste).
I think you also need a bridge to move somewhere else. you can not stay too long on that chord progression (at least for my taste).
EdisonRex
Audio files: 172
PostPosted: Mon May 21, 2007 2:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Why, thank you! (why not thank you?)
I forgot to say what I used.
The piano is from, of all things, my P-55 Sound Canvas. With some close echo and reverb to make a room sound I think it sounds just fine. It's some Euro Piano patch. Patch 09 if you're wondering. I think the close room echo is about 50ms or so, and the reverb is "Large Room", but fairly dry in the mix.
Drums are a sampled set from the Akai S-6k. I am finding myself using the Procussion less and less now. I used a jazz set. It is tapped in, each part, for the length of the piece. I tend to do my drums that way, I tap in the parts. There is a set of shakers from the TS-12, I like them for their stereo goodness, for a 90s workstation there are still good sounds from that keyboard. Although it's my master keyboard anyway, these piano velocity recordings are from the keyboard of the TS-12.
The bass is a manual patch on the SE-1X. I really like this instrument, but it is pretty unstable. I think I am going to open it up and figure out why the oscillators can work their way whole semitones apart in the course of a day. It worked out okay on the mix, but I had to readjust it big time about 3 times during the session. We're on 3 oscillators for bass, lots of low saw and triangles doing the 3rd harmonic. Filter was at 24db. Heavily influenced by envelope.
The "ethereal" arpeggio is the Nord in manual mode, played with liberal Effectron, to get me the echo. I played the arpeggio myself thank you. Many times. I do not like cut and paste, I find it tends to homogenate the production.
The pad is the Neuron, one of the weirder patches, which I have modified anyway, its a evolutionary thing (it changes as you play it). I used it sparingly, because you should use all strongly odd patches sparingly. It's one of my rules.
First solo is a manual patch on the Voyager. VCO1 is in the squarer region, the other two are in the more triangular region. Dual Lowpass, chocked down but with envelope goosing it, they are all 4' voices, so we're tuned on some higher harmonics.
Second solo is the Poly Evolver. Mostly triangular and overdriven.
The Moogerfoogers got used for effects, at least the phaser did.
I think that's most of it. No quantizing, very little clam editing right now, and as I said, I need to do some dynamic editing still. Mostly that's the mixing, which I did not automate for this take.
So I had this piano riff going through my head all week at work. I sat down with my M-Audio 24/96 and did a raw capture on Thursday off the piano/Pianobar downstairs to listen to, listened Thursday and Friday, actually laid down tracks on Sunday. So the production was mostly a Sunday. We were all dragged out Sunday in the house, so it was a good time to go for it. We sieze our days.
I don't see a lot of people talking about how they do things. I thought it might be nice to share. If I'm in the wrong place, as I am good at, let me know.
EdisonRex
Audio files: 172
PostPosted: Mon May 21, 2007 2:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
You missed the "bridge" at the end of the second solo? I should have taken it out of the progression Embarassed
yeah I am thinking about that. And the timing has a LOT of work to do. It's what you get when you manually play something - as I said, it's a work in progress, no excuses, and you are right. Thanks for listening, actually Very Happy
This one will get more work. It's hardly done. My saturday one earlier in the thread, I should work on, too, but my head is in this one.
Dovdimus Prime
Audio files: 6
PostPosted: Tue May 22, 2007 3:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Clam editing? Laughing Laughing
Does such a thing exist? Say it ain't so!
Not the bearded variety I trust?
EdisonRex
Audio files: 172
PostPosted: Tue May 22, 2007 10:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Perhaps an English vs. American thing... definitely not the bearded variety Laughing
A "clam" would be a bad note. like when I hit two notes instead of one. I tend to edit those out of a track when I hear them.
Dovdimus Prime
Audio files: 6
PostPosted: Wed May 23, 2007 4:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Are we not both staunch Englishmen, true to our teacakes and warm beer?
EdisonRex
Audio files: 172
PostPosted: Wed May 23, 2007 5:27 am    Post subject: Reply with quote  Mark this post and the followings unread
I like teacakes, and warm ale, but not warm lager.
As I said once, in my introduction, I'm an American expat, enjoying paying more taxes and NI, now 9 years here in London. So I usually just say I'm an ethnic American to those who ask. My friends all make fun of my accent. Considering I'm originally from New England, though, my accent was weird to begin with. So I also usually say I am bi-lingual, I speak both English and American. That way nobody can figure out what I'm talking about.
Wink
