 Forum index » Clavia Nord Modular » G2 Patches - Completed » Acoustic
Brass Ensemble
Page 1 of 1 [3 Posts]
Tim Kleinert
G2 patch files: 236
PostPosted: Sat Nov 03, 2007 10:52 am    Post subject: Brass Ensemble
Subject description: "Thinking out of the box" low-budget brass synthesis
Here's a quite cheap but effective approach to brass synthesis. Like waveguide-based physical modelling, it is based on an driver-resonator concept, but works entirely with "classic analog" synthesis components. It should be possible to patch this on any real-analog modular synth which has the required modules.
A lowpass filter in self-oscillation acts as a resonator and sound source. Just as it is, it only produces a sine wave when excitated. But if we remove the DC component of its output with a highpass filter and feed the result back into its linear FM input, it starts to produce even harmonics. What actually happens is that the filter phase-modulates itself, as removing the DC component from the FM signal turns it into phase modulation.
This filter is then driven (excitated) by a simple sine oscillator tuned to the same frequency and volume-contoured by a keyboard-gated envelope. The neat thing about this is that it is a cheap dynamic feedback system. So, depending on resonance and linear FM (now PM) input settings of the resonating filter, raising the amplitude of the driving oscillator makes the filter produce brass-like waveforms of increasing brightness. Pushed even further, it starts to break into quite "acoustic" sounding semi-chaotic animations. The trick is now to contour the driver input level in such way that the attack/decay stage is in the more chaotic range and then settles down into a more stable sustain oscillation stage, thus mimicing the typical flatulent (sorry Laughing) brass attack which locks into stability. Tweaking the DC-blocking highpass filter frequency additionally influences frequency content and response of the oscillation.
One word of caution though: It's a dynamic system, and therefore is capable of "locking up" into screeching high-frequency loops which are quite painful to the ears. It only snaps out of them by greatly reducing resonance. Hence, resonance isn't controlled by the reso knob but by the resonance modulation input to which a a max-sustain envelope is fed. So, if the sound locks up, just release the key and the filter snaps out of its resonance and misery. (It wouldn't otherwise.)
I could have added more bells&whistles, eg. adding a scaling to the linFM input do facilitate fine tuning since the linFM input knob has such a wide range, etc.. However, the whole thing was primarily a personal exercise at patch economy. Hence, it's below the 16.6% benchmark both in memory and cycles usage, fitting 6 voices on a DSP and thus giving full 32-voice polyphony on expanded G2s.
4 variations populated, demonstrating how different settings of resonance, linear FM and driver levels determine the overall flavor, from mellow frenchhorns to biting trumpets. The variations all respond well to dynamic keyboard playing. Actually they sound pretty boring without it. I've used a modified version of this patch with a Yamaha breath controller for even better results.
tim
BrassEnsemble TK.pch2
 Filename:  BrassEnsemble TK.pch2
 Filesize:  1.9 KB
 Downloaded:  2795 Time(s)
Former site admin
Audio files: 353
PostPosted: Sun Nov 04, 2007 4:49 pm    Post subject: Re: Brass Ensemble
Works pretty good Very Happy
Nice trick with filters.
View user's profile
Chet
G2 patch files: 35
PostPosted: Thu Nov 08, 2007 10:22 am    Post subject: Reply with quote  Mark this post and the followings unread
This is a really neat and clever idea, Tim, and it sounds great! Thanks for posting it!
