Restoring/Modding Boss CE-300
Page 3 of 3 [72 Posts]
Goto page: Previous 1, 2, 3
germaniac
PostPosted: Wed Feb 13, 2008 11:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
germaniac wrote:
[...]he reaches for a portable music generator in his utility pack, and begins to improvise a tune to the wonderment of his hearers. . . .
I'm sure that would work, especially the treated organ pipe!
Very Happy Very Happy Very Happy
gavgomad
PostPosted: Thu Feb 14, 2008 5:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the WIDE selection of demos, Joe!
Wow is all I can say.... The "dimension" effect is very natural sounding, and with the variable settings, you can still get an amazing amount of movement when you want it (like your guitar example)....
Placing my parts order with Digikey this eve, so hopefully mine will be sounding as good as yours soon! Wink
Gavin.
germaniac
PostPosted: Thu Feb 14, 2008 11:30 am    Post subject: Reply with quote  Mark this post and the followings unread
My pleasure! Cool I'm glad those work for you, though it's hard to show everything. I should probably post something that shows all extremes, since a rather interesting Leslie-like sound can be had among others. The only thing I'm not quite satisfied with yet is the input/output level question, so I may still raise the output level. Good luck on your parts quest!
BTW, can I ask a small favor of you? Would you mind going back to Page 2 of this thread and editing out that EBAY link from your post so the page sizes right in the browser? Pet peeve, but it's my fault for posting it in the first place, and I've already edited mine down. Thanks!
Regards,
Joe
gavgomad
PostPosted: Thu Feb 14, 2008 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Those definitely worked for me! Wink
I think the key thing for me was to see how subtle the modded CE could be, while still sounding natural (rather than getting that reedy "flanger" sound)....
For my needs, I'm beginning to think I may upgrade the position of the CE in the studio if all goes well on the mod front, as the range of sounds runs nicely from a Dimension effect to a "Juno-esque" quality - will do for both tasks I need a chorus for, the stereo "widening" that the Dimension is famous for, and a more effected "warble".... ;-P
I'M EXCITED! Wink
As for the ebay post.... Is that one of Jim's? I don't think I quoted you on that bit.... Will triple check though....
Thanks again! Will keep all posted! Smile
Gav.
germaniac
PostPosted: Thu Feb 14, 2008 12:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oops . . . . You're right, sorry. Absent-minded Joe Strikes again. Embarassed
That editing request/favor goes out to you Jimbo. . . . Wink
Interesting about the Juno-esque quality you're hearing. I've never worked with one. Google doesn't bring up a schemo, but I wonder if anyone's ever done a clone? . . . .
gavgomad
PostPosted: Thu Feb 14, 2008 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
No worries Jim! I just started worrying that the ol' memory was giving out on me! (It does that sometimes!) ;-P
I confess that although I've played one, I don't own a Juno. If I recall from my experience, the chorus is somewhat similar to the Super JX, which I DO have (also have a JX-3P, but the chorus on that has a bit of a different quality). Someone may have both out there and could comment....
The second setting on the Super JX is still pretty mild (ie. the demon hordes aren't swirling overhead or anything like that, like you might get with the dedicated Boss pedals), but it definitely has more "movement", for lack of a better term. Buttery, but not too washy.... Many have said, probably correctly, that the chorus on the Super JX makes up for boring oscillators and slow envelopes....
Glad to see you cross posted to the CE-1 thread.... Would like to know what JH (the Guru of the "Dimensions"! ;-P) thinks of the demos if he's trolling about, particularly in light of all of the discussion about Dim-Ds, Junos, CE-1s and Behringers.... Wink
Gav.
germaniac
PostPosted: Mon Feb 18, 2008 1:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Quick Update: I did the output mod on the CE-300, similar to the one in the link Margus posted. Their mod indicates a 470K for R105/106, but I found 200K to be plenty of gain without increasing the noise much.
According to my crude tests, using the VU meters on my computer, the unmodded S/N with no effect is about 115dB, and with effect about 100dB. Subbing 200K metal films for R105/106 gives a gain increase of about 12db over stock. With the added gain, S/N is about 100dB with no effect, and about 85dB with effect. Frankly, the change in S/N wasn't audible to me, and I seriously doubt it will make any difference for my uses, whereas the increase in gain is absolutely useful. Now, with various input sources, it's easy to set a comfortable input level without having to worry about distortion and still have enough output that it doesn't require a mic pre or other additional gain stage. It's a keeper! Cool
EDIT: "Mods Schemo" has been updated!
Regards,
Joe
Scott Stites
Audio files: 97
PostPosted: Fri Feb 22, 2008 9:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Germy, those samples are the proof in the pudding. Man, you know your way around a BBD circuit these days. That SK1 sample made me want to pull my $1 garage sale SK-1 out of mothballs and toot a flute into it or something. Of course, I don't have that modded CE-300 though Sad .
Fantastic work!
Scott
My Site
germaniac
PostPosted: Fri Feb 22, 2008 11:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you kindly Dr. S--that means a lot to me coming from the original BBD/Dim C master!
And in case anyone hasn't done so yet, I urge everybody on this thread to check out the good stuff, the latest musical explorations of Dr. Stites here:
http://electro-music.com/forum/post-169768.html&highlight=woody+wilson#169768
Enjoy! Cool
johans121
PostPosted: Sun Feb 24, 2008 11:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Embarassed
Alright, parts are ordered! Can't wait to get these mods implemented. I will definitely follow up with my impressions.
Thanks for the excellent project documentation!
-Jim
germaniac
PostPosted: Mon Feb 25, 2008 11:36 am    Post subject: Reply with quote  Mark this post and the followings unread
johans121 wrote:
Embarassed
Not a bit of it Jim! It was my bonehead post in the first place, and my pet peeve too. Anyways, thanks for the fix!
Cool! May the DIY Force be with you!
Joe
wolzow
PostPosted: Wed Mar 12, 2008 6:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi germaniac,
I finally found time (finished some projects/cancelled some others) for my CE-300. I'm almost done, but have some open questions.
1. Bringing the BBD clock freq down to 30K, I'm a bit hesitant about the LPF filters after the BBD. Clock noise filetring LPFs are usually designed for 10K but how good are they? I mean, the designers assumed much higher (and safer) clock frequencies, do you get any clock noise after LPF? BTW, my CE-300 clock freq measures at only 65K with zero settings without touching the caps. Strange.
2. I copied your LFO symmetry adjustment trimmer idea, thanks. Could you tell me where did you take the oscope signals while adjusting LFO sweep. I don't mean LFO signal symmetry adjustment (RT8) but the signals going to mn3101.
3. The 'stock' LFO rates of Dim-D presets are 0.25 and 0.5 Hz. In factory CE-300 it's 0..4Hz. I was not that interested in typical 'swoosh' chorus sound and wanted to get closer to Dim-D specs and idea of 'motionless chorus', so I substituted the R55 15K resistor (in series with RATE pot) with a 68K resistor which gives me a nice 0.18..1 Hz LFO frequency range so that I have more playroom in the sweetspot area.
How exactly did you measure the S/N?
Thanks,
Margus
germaniac
PostPosted: Wed Mar 12, 2008 12:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Margus!
I didn't do a specific test for aliasing, but now you've got me curious and I just might. Smile With my CE-300, the clocks are set for about 33K, which puts the Nyquist Zone at about 15K for input signals. As it is, I didn't notice any aliasing, and of course there's always the option of backing-out the clock time if you run into trouble. As for our clock discrepancies, quite a number of components play into determining that, so the accumulated tolerances tend to add up I guess. (That's why I tried to qualify my findings with the reminder that such-and-such was the case on my particular unit.) Yes, that does seem like a pretty wide tolerance spread, but OTOH, I'm not convinced Boss considered the CE-300 one of their flagship items. Wink Anyway, a clock of 65K leaves you with about 8mS of delay, which is still a bit short for chorus IMHO. Let me know what you find if you decide on increasing the delay time.
Sorry if I wasn't clear on this before, but I never did find a satisfactory place to measure with a scope because of super-imposed clock frequencies on the LFO wave. Instead, with a 1M pot in place of R64/65 on the B side, I simply listened to a test tone from the B output with the DIRECT MUTE engaged. I tweaked the pot until the pitch variation sounded equal between sharp and flat. I now realize using a tuner (for guitar, etc.) would be the most accurate way to do this: send the CE-300 a A440hz tone and adjust for equal pitch variation according to the meter. Sorry for the crude methods, but let me know if you find a better way.
Ah, nice and slooooww. I like it pretty slow too, usually with the RATE control somewhere around 8 or 9 o'clock. Thanks, I'll keep your mod in mind!
Another (typically) crude test of mine. Rolling Eyes As I say, I used my computer and the VU meters on CoolEditPro software. The meter has a resolution of 120dB. With nothing plugged into the input of the audio interface (Delta 1010), there is dead silence, nothing on the meter. With the output of the CE-300 plugged directly in and nothing plugged into the input (automatically ground-terminated), I got the above readings. Probably not an accurate enough method for an AES paper, but good enough for a practical idea of whether the gain/noise is worth the trade-off. As I said, I couldn't actually hear a difference in noise level.
Keep us updated on what you find! (Include samples if the mood strikes you!)
Regards,
Joe
wolzow
PostPosted: Mon Mar 17, 2008 2:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I have already ordered the caps. I'll let you know in a couple of days.
Hmm, my method was probably even more crude. With both LFO RATE and DEPTH set to minimum I tweaked the RT5 pot until both clocks were exactly the same (on the opposite side naturally). Then I set the LFO DEPTH to max and watching the clock signals move on the scope tweaked the new pot (where R69 used to be) until the signals seemed to move equally (again, with the difference of 180 degrees). Not very scientific, sorry Smile
I actually added one more pot. I was quite intrigued by the idea of trapezoid LFO waveforms. Unlike yours, my LFO waveforms were not distorted so I did not have to attenuate the signal. Instead, I added a 100K pot in place of R58 that lets me actually overdrive the triangular LFO signal. Now, with the pot set to about 95K I get the maximum 'clean' LFO sweep (about 1.1V p-p) (ce-300-lfo1.jpg). With lower settings I get the trapezoid (ce-300-lfo2.jpg):
If you look carefully on the first picture you will notice that I actually cheated Smile. Although LFO signals seem to be perfectly in sync, base lines for both signals differ in about 70mV. Should I go looking for the reason, or is it not worth wasting the time?
I am not prepared to comment on the sound of the trapezoids yet but I talked a local studio owner (who owns an original Dim-D) into letting me open it up and poke around with the scope. So hopefully this week or the next one I can compare my CE-300 to the Dim-D. I'll post my findings.
Regards,
Margus
 Filesize:  29.58 KB
 Viewed:  19814 Time(s)
 Filesize:  25.6 KB
 Viewed:  19812 Time(s)
germaniac
PostPosted: Mon Mar 17, 2008 10:51 am    Post subject: Reply with quote  Mark this post and the followings unread
DIY = whatever works! Wink Just curious if you happened to measure the resistance on your adjusted trimmer and if so, what value you found. . . . (I got about 235K).
Excellent and thanks for the cool screen shots! I'll have a few questions on the use of the trap waveform shortly, but first. . . .
At some point the LFO distortion I had found in my CE-300 "disappeared," and I returned R58 to 100K again. I'm not sure what caused it in the first place, but one hypothesis is that I somehow loaded-down the LFO when I was measuring it. The CE-300 LFO has a rather high output impedance, which (I think) is what you are exploiting with your new LFO distortion control.
About the trap wave: is this the supposed waveform of the Dim D? I know Scott Stites has commented on something like a trap wave in his DIY DIM C, but when I looked at my Boss DIM C, I found a plain old triangle. I'm much intrigued and looking forward to what you find with this idea and your mod. . . .
I think the difference has to do with the combination of single-supply operation, DC coupling between the LFO inverter stages, and bipolar op amps. One way to minimise the offset might be to use FET op amps for the LFO and inverter stages, but good luck finding those in SIP packages. Sad In any case, I think also that this offset is what necessitates the extra trimmer (at R69) to equalize the sweep further downstream. So the trimmer already addresses the problem, but I'd always welcome a more elegant solution if you were so inclined to find one. . . .
Have fun! Mr. Green (totally envious!)
Thanks Margus!
Regards,
Joe
Scott Stites
Audio files: 97
PostPosted: Mon Mar 17, 2008 11:06 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm thinking the waveform on my Dim C is triangle (I never got it booking fast enough to scope it out), but the response to it sounds trapezoidal, if that makes any sense.
Cheerio,
Scott
My Site
germaniac
PostPosted: Mon Mar 17, 2008 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Ong Stites! sunny
Ah, makes sense indeed. The "One Hand Clapping" example on your DIM C page does have a sort of stop-and-go sound to it. . . .
On that line of thought, with your highly flexible-ized DIM C did you find any advantage to modulation waveforms other than the basic triangle, such as an actual trap wave, sine wave, hypertri wave?
Regards,
Joe
i c u
Scott Stites
Audio files: 97
PostPosted: Mon Mar 17, 2008 3:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm.....I still haven't tried a hypertri. I'm wondering how that would work. I mean, the way I set the Dim C up was with one input, which modulates one BBD and is inverted to modulate the other.
I do like the effect of hard edged waves - it renders a certain rhythmic stereo "knocking" kind of effect (for want of a better word). I posted a sample of the Dim C being modulated by the Klee a week or so at the bottom of this page here:
http://www.electro-music.com/forum/topic-19498-50.html
There's also a pic of the patch that made it. The Klee was set up to provide a series of pulse waves that were used to modulate the Dim C in that one, with the SH-201 running through the Dim C.
Another use that is decidedly counter to the original design is to use very fast, even audio rate modulation, the effect of which I like very much. It creates a very "chilly" type of sound, almost Buchla-like to my ears, though I don't think there many things further from the Buchla paradigm than dimension effects. Do you remember "I Saw Santa (Through the Scope of My Heckler and Koch)"? The icy feel of that one was imparted by rapidly modulated Dim C.
Cheesios,
Scott
My Site
germaniac
PostPosted: Mon Mar 17, 2008 4:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
I see what you mean. If the waves are symmetrical and flipped, one of them will be hyper the wrong way round. OTOH, if they're flipped and hyper/antihyper, they're no longer symmetrical. shakng2
Nice sounds! I never would have thought to do that with the DIM C!
Listening to it this very minute. Very Happy Reminds me of that creepy "squeaking hinge" sound in "Full Metal Jacket." Another unique application from the mind of Stites! Thanks!
Retards,
Joe
wolzow
PostPosted: Tue Mar 18, 2008 4:37 am    Post subject: Reply with quote  Mark this post and the followings unread
I think it was 208K. I used a 250K pot and it was almost at the max. Anyway, my trimming 'methodology' was so primitive that +-10K did not mean that much...
I see... so the experiments with trapezoids did not make much sense... besides it sounded pretty bad too that way Smile
If you have any special places of interest to take a snapshot (scopeshot?) from (besides the obvious ones) pls let me know.
Regards,
Margus
wolzow
PostPosted: Fri Mar 28, 2008 5:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm done with my CE-300. The final mod was the 100pf polypro caps that replaced C41 and C27. Base clock frequency came down from 64K to 33K as expected (with calculated delay of ab 15ms) and it really sounds nice that way. I retrimmed the LFO and also trimmed clock cancellation (by scope) and bbd bias voltage (by ear) but actually they were at the their best already. With RATE and DEPTH settings at 1/3 it now sounds not completely unlike Dim-D Smile
The next day I took my CE-300 to a studio where they have an original Dim-D and made some audio samples. The clip contains 5 samples of the same bass sound played on a Novation Bassstation (I didn't want to drag my Prophet-5 along, OK?). The first one is pure Novation. The next two are Novation through Dim-D, Presets 1 and 4, respectively. Fourth is Novation through my CE-300 with RATE and DEPTH at about 20% (most Dim-D-ish setting). The last one is CE-300 with RATE and DEPTH at max, just to have an idea how far it can go.
The file is an .mp3, sorry for that, I'll post the original .wav (12 megs) on my website in a couple of days so if anyone wants to take a closer look (eg. Spectral Phase display in Adobe Audition is quite revealing how the sound 'moves' between L and R) pls feel free to do so.
BTW, my friend who happens to be a sound recording engineer at the studio (and a pretty good one!) said that he preferred my CE-300-turned-to-fake-Dim-D to the original one, partly because it has knobs and can be tweaked. But he never liked the original anyway so maybe I shouldn't feel that good about it Smile
I also poked around with the scope in the guts of the Dim-D, so if those pictures would be of any interest I can post them here.
Margus
dim-d-vs-ce-300-bass.mp3
 Filesize:  2.87 MB
 Duration: 1:15
 Viewed:  1812 Time(s)
germaniac
PostPosted: Mon Mar 31, 2008 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Margus!
Sorry I'm late to reply, but I never got a Message Notification. Rolling Eyes (Thanks for the head's-up Scott!)
Excellent! Interesting how you have nearly half the cap value as me to arrive at the same clock of 33K. Very wide tolerances indeed. I'm glad you like the 15mS delay time. I guess that, rather than specifying a cap value, the object should be the proper delay time. So, aim for whatever cap value gets you into the 33K/15mS range, folks.
Thanks for the samples! Very close sounding, though a bit hard to tell with bass frequencies. And I may be biased, but the CE-300 sounds a bit wider stereo-wise. Very Happy
Wow! I admit this is very gratifying to hear! As for not feeling good about it: On the contrary, you converted him! (Now, get him to trade you one-for-one, sell the Dim D [going price around here is about $900] and buy yourself seven or eight CE-300s to mod. Wink
I'd love to see all this stuff when you have it on your site. And if I could make one small request for this thread here: could you provide a brief list of all your mods for others to refer to?
Thanks for your reportage and congratulations on all your mods--great work!
Regards,
Joe
