Posted: Sun Feb 24, 2008 3:45 pm Post subject:
The Thomas Henry Mega Percussive Synthesizer
bugbrand wrote:
Cool! & very happy to be able to help a little.
You're certainly gonna need a few Frac cases - you're going for 8 modules if I remember right! (enjoy the wiring!)
By the way, I'd forgotten to mention that my layout depends on using 16mm Alpha pots (or something of similar size) - being so tight, any bigger won't fit and I did have to bend all the legs up through 90degrees (actually makes it easier to make connections anyway).
A battery of 8 of these modules would be truly awesome! (though I'm sure I'll be perfectly happy just with two!)
Hint: 12mm Alpha pots. Good feel, D shaft, lots of values available. Readily available from Mouser. Although delivery in the UK might be more troublesome.
Tim (Mister 12mm, luckily that's not what my wife calls me) Servo
i would be in for four PCBs. is it too late? i did'nt follow this thread entirely, but your samples made me wanting these PCBs, tom. _________________
Joined: Nov 18, 2006 Posts: 236 Location: San Francisco, CA bay area
Posted: Wed Feb 27, 2008 11:15 am Post subject:
Ok you know, I haven't been following this thread much but now that I heard T Bugs demo I want one of these now. Where is the shop by the way? I cant find it.
Audio files: 97
Posted: Wed Feb 27, 2008 12:01 pm Post subject:
Hit "front page" at the top, you'll find it. It'll be a while yet before these things hit the store - we're still going through the proto measurements with a fine-toothed Studs comb.... _________________ My Site
Joined: Nov 08, 2006 Posts: 137 Location: new jersey, usa
Posted: Fri Feb 29, 2008 12:51 pm Post subject:
I'm thinking in terms of 6 or 8! I would like to have an entire "kit" of MPS's, all driven from either a Midi interface, or some type of Roland-esque percussion pad. Now, imagine the setup that we would have if we could convince TH to update the clangora to a design that doesn't require those impossible to find 566 chips .....!
Hello! Sorry, I can't find the schematics for this (niiice) project. Anyone can tell me please? I don't even know if and where I can buy a pcb.
Thanks! _________________ http://soundcloud.com/mister-vommi http://tideofsound.net
Posted: Wed Mar 05, 2008 11:45 am Post subject:
Hi Tommi,
We're still beta-testing the PCBs - should get that done soon(ish) and then the project will be released through the electro-music.com store (up top - same as the Klee project). _________________ http://www.bugbrand.co.uk http://www.bugbrand.blogspot.com
No, you can't find a BOM. You can find just a list of the ICs (just six!) on page one of this thread... I think its the third post or so..
Anyway, thanks for finding the suppliers for me! _________________ http://soundcloud.com/mister-vommi http://tideofsound.net
Posted: Fri Mar 07, 2008 5:24 am Post subject:
Yeah, no BOM yet - but there's absolutely nothing hard to get (other than the slightly hard XR2206) - just standard resistors, caps, diodes and transistors (2n3904 & 2N3906 - ie standard NPN and PNP) -- all credit to TH for this!
Yes! I found the xr2206 (ordered two of them from my local reseller), i got six lm13700, two 4046, two tl074 and a batch of 100 2n3904 and 3906. So now I got all active components for the mps. I think I'll do on a wooden case and plexiglass panel like i 've done with the Soundlab!
I just have to wait for pcbs... I need those sounds! _________________ http://soundcloud.com/mister-vommi http://tideofsound.net
Well, I have good news!
After spending waaaaaaay tooo loooong getting my prototype together, I finished it this morning and fired it up. It worked beautifully first try, so we are not far away from a run of boards. Just a couple of test measurements to make, and we should be ready to Rock & Roll! (Ah, maybe that should be Kling & Klang!!) _________________ What makes a space ours, is what we put there, and what we do there.
Here's a quick sample of my MPS supplying the kick drum with my Sorcerer doing a bass line. Both run from the Klee. There's a bit of shell CV modding the MPS to break it up a bit. I've only been playing with it for 15 mins or so, but it is proving to be very versatile, and a lot of fun. There are no dead spots on the pots, and the optional CV ins work quite well.
MPS kick.mp3
Filesize:
280.61 KB
Duration:
0:14
Viewed:
3474 Time(s)
