Coming up on Radio 1 at
A collection of Klee musics
Page 4 of 13 [314 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, ..., 11, 12, 13 Next
Scott Stites
Audio files: 97
PostPosted: Fri Mar 21, 2008 10:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks guys Very Happy
Yeah Jan, what passes for news here is astounding. Scratch that, it's maddening.
Cheerios,
Scott
My Site
Audio files: 25
PostPosted: Sat Mar 29, 2008 12:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Scott,
I really like this tune also. Very nice composition Wink
Bill
Scott Stites
Audio files: 97
PostPosted: Mon Mar 31, 2008 1:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Why, tanks Bill!
My Site
loopcycle
PostPosted: Wed Apr 30, 2008 1:52 am    Post subject: Reply with quote  Mark this post and the followings unread
well, i wanted to set up the most simple sequence i could, in order to suss some of this mad functionality. so the klee is driving two oscillators feeding a lowpass filter. the klee is running in 16x1 mode (mostly) and just one bit is active (mostly). the pattern changes are simply my flipping another bit and tapping the manual load button between the 16th and 1st stage, making two (or very rarely, three or more) stages active simultaneously. i set up bus 3 to trigger an auxiliary envelope that opens up the lowpass filter slowly. i create the high frequency fills by toggling the invert b, throwing bits into the mix. bus 1 is the 'discard' bus when i want to silence a step. i could probably stand to do that more in this patch.
http://www.twango.com/media/consumed.sound/consumed.10025
anyway, all changes are klee manipulation only. no programming pots were touched whatsoever.
so what did i learn today? small changes are big. simple is good. its all in the switch. and that manual load button is key! when i design my next klee interface, that button will be the closest control to me. also, creatively flipping into 8x2 mode when multiple bits are active can 'break' the order of the bits up, providing a brand new sequence.
oh yeah. im glad i got good switches, because they will be getting worked out.
Scott Stites
Audio files: 97
PostPosted: Wed Apr 30, 2008 10:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Loopcycle, that piece is simply beautiful! You've certainly got some great Klee technique going on there. Thanks for sharing it. What filter did you use for this?
More! Very Happy
Take care,
Scott
My Site
loopcycle
PostPosted: Wed Apr 30, 2008 10:55 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks scott!
the filter is a motm-440.
oh yes, i will have lots more to klee about.
Peake
PostPosted: Wed Apr 30, 2008 7:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have to say, I was going to ask what filter that is as well. Jurgen's design sounds good. As does the Klee!
PostPosted: Mon May 05, 2008 11:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
just my first KLEE sequence.
audiopath:
EFM dual VCO -> MFOS 12db VCOs (BP/HP) -> LPG -> fonitronik digiFX
klee controls (2x8, pattern, B-invert):
A -> VCO1, A+B -> VCO2
Gate 1 -> ADSR -> VCF
Gate 2 -> ADSR -> VCF
Master Gate -> LPG
the klee itself is controlled by a LFO. LFO is fed into divider as well and triggers a baby10 which controlls the footage of the patch.
klee_01.mp3
 Filesize:  677.58 KB
 Duration: 0:43
 Viewed:  3669 Time(s)
Posted Image
Scott Stites
Audio files: 97
PostPosted: Wed May 07, 2008 10:32 am    Post subject: Reply with quote  Mark this post and the followings unread
A sumptuous field of clover........
I downloaded this yesterday morning, Matthias - I listened to it all afternoon at work while working on a training presentation. Man, you really nailed it. I sure as hell didn't get such luscious patterns out of the Klee when I first had it in my hands. More!
Cheerio,
Scott
My Site
a.b.o.z.
G2 patch files: 4
PostPosted: Thu May 08, 2008 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
hei people.
finaly I got more than 15 minutes to play with my toys and here what I found out.
klee->soudlab
a to vco1
b to vco2 wich is synced to vco1 and driven by s&h
there are triggers fired from s&h to ar generator.
fun fun fun
Ivan
glina.mp3
 Filesize:  1.31 MB
 Duration: 1:26
 Viewed:  3202 Time(s)
Pehr
PostPosted: Wed May 14, 2008 1:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm testing youtube... Pardon the sound quality and the light, it is filmed with a small digital camera.
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
Scott Stites
Audio files: 97
PostPosted: Wed May 14, 2008 3:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm really enjoying this! Ivan - groovy Kleelian anarchy! And Pehr - that's an excellent vid, IMHO, and that sequence you built up is one I'd like to steal...er, love to listen to, I mean..... Very Happy
My Site
23isgood
PostPosted: Thu May 22, 2008 11:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Folks. I just put up a tune I made with my Klee on myspace. Check it out, its called "bumper". All the sequence loops are my modular sequenced by the Klee. It wasn't in real time. I bounced a few tracks down to individual tracks in Ableton Live. The synth pads and one of the lead sounds are coming from my C64. I also put up some new pics of my Klee up there too. I finally labeled it.
pete
http://www.myspace.com/23isgood
Check out my music
Scott Stites
Audio files: 97
PostPosted: Thu May 22, 2008 1:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked Cool
wave
Man! That's scary good.....
I'm digging your other music, too - I'm listening to "Warp Zone" right now. Beautiful...... Cool
My Site
23isgood
PostPosted: Thu May 22, 2008 5:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Coolness. Thanks. I'm also using the Tau 20 pole phaser in there too. You can hear it in the hats, and on all the pads. I love that sound!
Check out my music
Pehr
PostPosted: Sat May 24, 2008 10:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool
YouTube channel
flickr photostream
Kartoshka
PostPosted: Sat May 24, 2008 8:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
@pehr:
very cool, man! very very cool chilled motive, so much joy listening to it over and over again. Embarassed
will start making it together asap for sure! Cool
Got kleed accidentally, but seems like it was god's message — and now, after getting only deeper and deeper into rehearsing, keeping in mind demonstrated ability of building creative one-off patterns, it's being placed beyond any logical excuse of time or effort investments in it.
For me, 'Modern Classic' is the most correct term when trying to describe it's logic. Not many instruments are considered truly belonging to this niche, but Scott Stites Klee is the one for sure.
I'm proud of owning in very close future this history-making instrument.
Former site admin
Audio files: 353
PostPosted: Sun May 25, 2008 9:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Pehr wrote:
Cool
Laughing but you are right, I love that mp3.
Scott Stites
Audio files: 97
PostPosted: Wed May 28, 2008 7:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Smashing, Pehr! I downloaded this Sunday between thunderstorms (you would not believe the weather we've been having here). Therefore, now every time I hear it, it reminds me of a menacing storm brewing.
I really like the structure of this one - especially when that first bass note kicks in at around 1:20. That's the thunderhead breaking over the trees. Very Happy
As usual, thanks for posting. More, please!
Cheerio,
Scott
My Site
Pehr
PostPosted: Thu May 29, 2008 6:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! Very Happy I'm really satisfied with this one. It was actually a bit longer track from the beginning, but I only liked this first part with the build up of the voices. Twisted Evil
YouTube channel
flickr photostream
Junk Rhythm
PostPosted: Sat May 31, 2008 11:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Digging it Pehr! Very Happy I like when the bouncy sonar sound comes in.
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger
Scott Stites
Audio files: 97
PostPosted: Wed Jun 04, 2008 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's a laid-back one I recorded back on May first or second. It uses three oscillators and the DSC2000. I kinda like the way the DSC2000 patch came out - I was running it through the CGS Grinder and wave multiplier, and it came out sounding like a frog-pond, which inspired the half of the name of the tune.
Besides the pitch of the DSC2000, the pitch of only one of the oscillators is controlled by the Klee. Two oscillators are controlled by the keyboard voltage but are passing through a filter that is controlled by the Klee, which I thought was kind of a neat effect. It's the "bass" VCO that has its pitch controlled by the Klee. It's all one take (no overdubbing) mixed to a mono signal and made stereo through the Dim C
The "Indigo" comes from a little gal in Oz.
Indigo_Fish.mp3
Klee piece with fishies
 Filesize:  8.51 MB
 Duration: 4:39
 Viewed:  3087 Time(s)
My Site
Former site admin
Audio files: 353
PostPosted: Wed Jun 04, 2008 11:29 am    Post subject: Reply with quote  Mark this post and the followings unread
thumright
Scott Stites
Audio files: 97
PostPosted: Sat Jun 07, 2008 7:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's one I recorded a couple of weeks ago. It's fairly long so I encoded it at a lower MP3 bitrate.
It has three synth voices and a drum voice. One synth voice is a VCO3 through 2040 clone filter and VCA. The second synth voice is one of the Late MS-20 clones going through the CGS wavemultiplier, then CGS grinder, then through the second half of the Late MS-20 module (set for low pass filter). The third voice is the DSC2000. The drum voice is the reason I set up the patch - I was wanting to record a demo for a web page I'm doing on a new TH drum voice design - the Bass++, which, incidentally, is a ludricously easy circuit that uses only two ICs.
The first voice is triggered from gate bus 1, the second voice is triggered from gate bus 2, and the Bass++ is triggered from gate bus 3. The DSC2000 "freewheels".
Anyway, I had the patch set up, and I decided to just punch record and start adjusting the Klee. I adjusted the merge/unmerge and range controls, as well as 16X1/8X2 and InvertB and Gate Bus 1 Load. I also adjusted the time constant switches on the EGs (I used EGs on the first and second voices). I let it run until I was out of space. When mixing to computer, I just put in a fadeout instead of the abrupt "out of space" lurch to a stop one gets when one is out of space.
This def gives the drum voice a workout.
Cheerio,
Scott
klee_thang.mp3
It's a Klee thang.....
 Filesize:  5.51 MB
 Duration: 6:01
 Viewed:  4646 Time(s)
My Site
mark_olson
PostPosted: Sat Jun 07, 2008 3:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Really nice, Scott.
You could definitely hold your own on stage with this stuff.
Mark
