M185 sequencer Project - NEW PCB VERSION
Page 3 of 46 [1139 Posts]
Goto page: Previous 1, 2, 3, 4, 5, ..., 44, 45, 46 Next
klo
PostPosted: Tue Jul 01, 2008 11:45 am    Post subject: Reply with quote  Mark this post and the followings unread
i 6...!
but the singel gate or trigger out.... was a very big feature..!!
newdendrite
PostPosted: Tue Jul 01, 2008 7:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks like a great project. I'm in for two boards.
Michael
ryktnk
PostPosted: Wed Jul 02, 2008 8:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
Klo
Can you explain more clearly, I don't understand your request.
-ryktnk
klo
PostPosted: Wed Jul 02, 2008 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
for all 8 steps a singel gate out. 8 singel gate out 1-8 and one mix gate out.
ryktnk
PostPosted: Sat Jul 05, 2008 2:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
Thanks, I understand now.
But I think I will keep the design with just the single "mixed" gate output.
-ryktnk
endif
PostPosted: Sat Jul 05, 2008 9:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yep, still in for one.
Would love to see the BOM and docs..
~ !J!
http://www.endif.org
http://www.crunchpod.com
http://www.myspace.com/endif
ryktnk
PostPosted: Mon Jul 07, 2008 3:55 pm    Post subject: BOM & PCB Work in progress Reply with quote  Mark this post and the followings unread
Hello
Here is a WIP of the BOM for the M185 sequencer, there
are also a handful of resistors and diodes that are hardwired
to the switches and pots.
-ryktnk
M185_V21_BOM.pdf
 Filename:  M185_V21_BOM.pdf
 Filesize:  22.56 KB
 Downloaded:  1719 Time(s)
slo
PostPosted: Mon Jul 07, 2008 5:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd be in for one of these, looks great.
George
bubblechamber
PostPosted: Mon Jul 07, 2008 9:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
it's looking really good. thanks for all the work you're putting into this.
Funky40
G2 patch files: 5
PostPosted: Wed Jul 09, 2008 3:23 am    Post subject: Reply with quote  Mark this post and the followings unread
yes, and thank you for keeping us updated.
asafnetzer
PostPosted: Wed Jul 09, 2008 7:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the update, looks great
ericcoleridge
PostPosted: Wed Jul 09, 2008 10:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow! This is really compact, considering all the functionality. I already have a sequencer, but I wouldn't pass up this PCB if it's offered. Really great work.
Level5
PostPosted: Thu Jul 10, 2008 7:08 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm in for 2 PCB's and PIC's Very Happy
funkyfarm
PostPosted: Thu Jul 10, 2008 9:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Ain't a 6-position slider switch "enough" for repeating mode ?
something like this : mouser 506-SLS260PC
3.84$
http://www.mouser.com/Search/Refine.aspx?Ntt=*506SLS260PC*&N=1323038&Ntx=mode%2bmatchall&Ns=P_SField&OriginalKeyword=506-SLS260PC&Ntk=Mouser_Wildcards
ryktnk
PostPosted: Thu Jul 10, 2008 10:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
Do you mean the counts per stage switches ?
This is currently working with 1-8 repeats, so you could use
this switch, but only getting 1-6 repeats.
The wiring on the SLS260PC switch would be a little fiddly as
it is not a straight 1pole 6way.
Probably using rotary switches is a good route as you can easily
find 1pole 8way.
The mode per stage switches needs to be 1pole 4way.
-ryk
funkyfarm
PostPosted: Fri Jul 11, 2008 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
ryktnk wrote:
Hello
yes !
rotative switches will take more space on the frontpanel...
a complete second row as for cv potentiometers.
farnell has cool cheap little boxes with aluminium panel (210mmx125mm/8.25x4.92)...
In fact I wonder if a 1pole 4way would be enough, same as for the mode per stage switches. I guess number of counts per stage often vary between one, two and three, maybe four sometimes in a sequence.
"this is how I usually see a bassline..."
can it be a real drawback ?
maybe higher counts per stage numbers are useful for longer note ? or "pause" in a pattern ?
ryktnk
PostPosted: Fri Jul 11, 2008 2:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello
It kind of depends at what beat-division your clock is running at.
If you're driving the seq. from 16ths [all the leds on a 606] then you
will definitely need 1-8 repeats.
I've set a jumper on the board, so you can divide-by-2 the clock pulses
which might help.
I guess count some clock pulses of your intended music, and
see if it's going to fit.
Hope that helps.
-ryk
funkyfarm
PostPosted: Fri Jul 11, 2008 2:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for pointing this.
i will find a bigger box and switch for rotative Smile
ryktnk
PostPosted: Mon Jul 28, 2008 2:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello
Here is an update on the project.
The design has been finalised, with two new features !
The CV stage control has been added, with a 0-10V buffered
input.
Also a switch selectable subdivision for gate repeat mode stages
which outputs gate pulses every 1, 2, 3, or 4 clock pulses
independently of the selected repeat amount.
The boards should hopefully be shipping in about 2 weeks.
There might be a possibility of including some 8way switches
with the kits, will let you know.
Here is an updated BOM including the panel components.
-ryk
M185_V23_BOM.pdf
 Filename:  M185_V23_BOM.pdf
 Filesize:  43.89 KB
 Downloaded:  1400 Time(s)
ringer
PostPosted: Mon Jul 28, 2008 3:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Ryktnk,
MUCHOS GRACIAS for the cv stage selection and the subdivision.
I am upping my order to 6 pcb's with switches please. Paypal is waiting for the go-ahead, thanks.
Regards,
Ringer
bubblechamber
PostPosted: Mon Jul 28, 2008 5:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Ryktnk, that's great. I'm really looking forward to this. i've got the feeling i'm going to regret only getting 2 of these. thanks for all the work you're put into this project.
david
You can check your anatomy all you want, and even though there may be normal variation, when it comes right down to it, this far inside the head it all looks the same.
Danno Gee Ray
PostPosted: Mon Jul 28, 2008 5:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would be interested in one board PIC combo if still available.
Thanks,
Dan
Luka
PostPosted: Mon Jul 28, 2008 6:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ohh, ok 2 kits for me please (+ switches)
problemchild
melbourne australia
mono-poly
PostPosted: Mon Jul 28, 2008 10:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd love to get 4 Smile
neandrewthal
PostPosted: Mon Jul 28, 2008 11:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
2 for me please Smile
