New gear!
Page 21 of 74 [1832 Posts]
Goto page: Previous 1, 2, 3, ..., 19, 20, 21, 22, 23, ..., 72, 73, 74 Next
BobTheDog
PostPosted: Tue Sep 02, 2008 8:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Acoustic Interloper wrote:
Which Godin Multiac is that? Steel or nylon? 12-pin connector? I have an xtsa that was my first electric guitar in about 33 years, that I'm using for any guitar synth work that I do. I got it after playing Mosc's Nechville MIDI banjo.
Mine weighs a ton, and tuning takes a couple iterations across the strings, although once it's tuned, it stays tuned. I like playing it and like how it sounds. How do you like yours? Some day I may decide to learn to play Flamenco, and thought the Multiac might be good for that. What do you think?
It is the ACS-SA slim, nylon with 13 pin and I like it a lot. It is heavier than an acoustic, about the same weight as a medium size electric.
I also played the Grand Concert SA in the shop which sounded much nicer but was twice the price!
I have included a little snippit of mp3, everything apart from drums is from the Godin.
Andy
Output 1-2.mp3
 Filesize:  631.55 KB
 Duration: 0:16
 Viewed:  2543 Time(s)
BobTheDog
PostPosted: Tue Sep 02, 2008 8:08 am    Post subject: Reply with quote  Mark this post and the followings unread
elektro80 wrote:
And you still have some hair as well. Just like me. Laughing
I am afraid only just, it is doing its best to leave!
Acoustic Interloper
Audio files: 90
PostPosted: Tue Sep 02, 2008 8:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice snippet! Very expressive, it makes me want to get my hands on one. No place to try one out, I had to special order my xTSA.
BobTheDog wrote:
I'm really impressed how it works for conversion to midi via my Axon, far better than the rmc pickups on my Brian Moore or GK3 pickups.
I'm very surprised really as I did not expect this!
Given the fact that this is my first electric in many years, it almost goes without saying, that it's my first MIDI guitar, and I have been delighted with how well the MIDI conversion works. I have talked with a lot of people who have bad things to say about string pitch-to-MIDI conversion, but I think that Godin is doing it very well.
The first use for mine was a research project that was fairly exacting, and the MIDI did fine. The piece Opposing Force (here) is the Godin fed thru this software and hence to the StringStudio softsynth, with my son Jeremy on bass, and MIDIME supplying the explosions and sirens, triggered by its real-time analysis of my MIDI playing. I wrote this two days after George W. was reelected, it shows the mood I was in.
This 1 minute piece was also the Godin, strictly the MIDI, with time and octave information freeze-dried out of the stream, and then reinjected by software and fed to StringStudio running in a "not recommended" configuration. The spicy parts happen as the result of processing chromatic/dissonant notes from the MIDI stream against the arpeggiation of diatonic/consonant chords.
Jeremy has got his hair, and I've still got mine. Some days it feels like the only thing I've got!
When the stream is deep
my wild little dog frolics,
when shallow, she drinks.
BobTheDog
PostPosted: Tue Sep 02, 2008 9:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Thats good stuff, MIDIME looks very interesting.
I am printing the paper out to read.
Andy
Acoustic Interloper
Audio files: 90
PostPosted: Wed Sep 03, 2008 7:34 am    Post subject: Reply with quote  Mark this post and the followings unread
There is a related draft paper here and slides from an electro-music 2006 talk/demo that adds a little info, albeit not completely fleshed out. I wrote the latter draft after debugging MIDIME at 2 AM while in the throes of a fever back in February of 2006. I was reading a trace of chord matches for a file of my MIDI guitar playing. Rather than match exactly to the chord that I was thinking in my head as I played, the trace showed that the software would match a cluster of nearby, related chords, in addition to the target chord. The reason is that, playing arpeggios, the full chord might only be fleshed out some of the time; even with non-arpeggiated strums, the notes don't all sound or die simultaneously. Thus, in the fever, this looked to me like a "cloud of electrons," a probability space of what chord (or other structure) was being extracted from the MIDI stream. This inspired the notion of a "quantum composition" that is basically a superposition of various musical structures with associated probabilities, and you collapse the superposition into concrete, automatic accompaniment by collapsing the probabilities of the superpositions to either 0 or 1 via your playing. Variations in your MIDI playing binds the unbound variables and steers the superposition into potentially different concrete output every time you play.
I haven't had much time to work on this in the last year, but I am doing some work on "superpositional composition" related to networked jamming that may add some more flesh to this concept. I'd like to write another MIDIME composition -- I need to compose the back end accompaniment agent for the piece -- ready in time for the New Year's streaming event. Dewdrop_world started a thread on this a while back, but we didn't get too deeply into this.
Hopefully the papers are a little clearer than this post Very Happy
BobTheDog
PostPosted: Wed Sep 03, 2008 7:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Well I would like to say that I understand that but I would be lieing!
I understood the bit about not being able to determine the chord playing arpeggios as I daily look at Logics attempt to match chords when I play midi guitar into it but got lost at the "quantum composition" stage, rereading with a beer in my hand didn't help either Very Happy
I will have a look at the papers though, haven't got round to looking at the first one yet but its on my list.
Andy
Audio files: 21
PostPosted: Wed Sep 10, 2008 4:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Posted Image
Hmm... it will ship this week I think. Very Happy
http://www.kelaudio.com/hm7u.html
Flickr
BobTheDog
PostPosted: Thu Sep 11, 2008 12:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Reasonable price as well, in the states at least.
PostPosted: Thu Sep 11, 2008 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Just picked up a Roger Linn Adrenalinn III for my bass. Great sounds out of this little box, and the features just keep growing. I was also glad to see the tuner works well (& quickly!) with tuning a low B string!
Posted Image
diablojoy
PostPosted: Fri Sep 12, 2008 6:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Shocked I guess i may also have an addiction Laughing
a nice newish motu24 i/o i got on ebay half price
 Filesize:  548.61 KB
 Viewed:  309 Time(s)
diablojoy
PostPosted: Fri Sep 12, 2008 6:21 am    Post subject: Reply with quote  Mark this post and the followings unread
And---- a pair of desie're near fields and dex amp off a friend.
 Filesize:  400.69 KB
 Viewed:  279 Time(s)
seraph
Editor
Editor
Audio files: 33
PostPosted: Fri Sep 12, 2008 7:42 am    Post subject: Reply with quote  Mark this post and the followings unread
diablojoy
I don't see any computer, are you hiding it somewhere or you are an hardware-sequencer-type-of-guy?
Wink
diablojoy
PostPosted: Fri Sep 12, 2008 6:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes computer. not hiding it. just not in shot. a pentium D 3.2ghz running Ableton Live and now thats reminded me i do need to upgrade it Laughing
Inventor
Audio files: 270
PostPosted: Sat Sep 13, 2008 2:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Those stereo Marshall amps look awesome, but the speaker cabinets seem to be positioned on their sides (note the bevels on the front). Won't this rotate the sound waves by 90 degrees, possibly warping your mind or at least changing your political viewpoints from right to left or left to right?
Oskar
PostPosted: Sat Sep 13, 2008 5:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've ordered a "cajon" from SlapDrum, it's their smallest model called the LapDrum. It should be here in a week or two, God and import taxes willing.
http://www.slapdrum.com/drum11.asp
I've started a thread in the instrument discussion forum:
http://electro-music.com/forum/topic-28899.html
Where there are too many policemen, there is no liberty. Where there are too many soldiers, there is no peace. Where there are too many lawyers, there is no justice.
Lin Yutang (1895-1976)
diablojoy
PostPosted: Sat Sep 13, 2008 11:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
You might be correct my political viewpoint does seem to more or less stagger from left to right and as for my mind, that has been warped since the mid 70's but i am certainly not the first to run marshall cabs on their sides Laughing
seraph
Editor
Editor
Audio files: 33
PostPosted: Sun Sep 14, 2008 12:45 am    Post subject: Reply with quote  Mark this post and the followings unread
is there a dwarf in your band Question Shocked
Oskar
PostPosted: Sun Sep 14, 2008 1:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Weeelll, you could say I've got a tiny brain, but that would be casting aspersions on a whole group. No, I just thought it might be interesting to try that type of drum, as you don't have to sit ON the drum itself! Btw, I posted a question in another thread asking for advice on contact mikes or piezo mikes or whatnot on cajon drums.
seraph
Editor
Editor
Audio files: 33
PostPosted: Sun Sep 14, 2008 3:33 am    Post subject: Reply with quote  Mark this post and the followings unread
there would not be anything wrong with a nano-drummer (hobbit size, I mean) Cool
DrJustice
PostPosted: Wed Sep 17, 2008 1:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Finally got one of these:
Posted Image
It's going to be used in stand alone mode as a merge/split patch bay.
DJ
seraph
Editor
Editor
Audio files: 33
PostPosted: Wed Sep 17, 2008 2:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think the midisport 8X8 is out of production. did you find it on eBay?
DrJustice
PostPosted: Wed Sep 17, 2008 5:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, it has been out of prodution for quite a while, and yes, got it from eBay Very Happy Not terribly exciting gear I'm afraid, but hopefully very useful...
DJ
seraph
Editor
Editor
Audio files: 33
PostPosted: Wed Sep 17, 2008 11:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I had one of those for awhile, it had a different front panel.
Posted Image
Oskar
PostPosted: Sat Sep 20, 2008 11:50 am    Post subject: Reply with quote  Mark this post and the followings unread
And it's arrived already! Thar Chris Nissen od SlapDrum is really great, giving nice tips on how to mike it an'all. Had a good session with it it, but I have to get back to it later, as I'm off to do a gig at Oskar's (sic) in Levanger!
Audio files: 282
PostPosted: Thu Sep 25, 2008 5:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Xenyx 2442FX mixer for Awakenings/ Hampshire Jam Jam
Boss SX-700 effects processor for my new live rack
coming soon
Kawai K5m additive synth (from Bakis)
