click on image to sign up
 Forum index » Instruments and Equipment » Waldorf
Birthday Waldorf!
Page 3 of 4 [79 Posts]
Jyoti
PostPosted: Mon Sep 15, 2008 5:47 am    Post subject: Reply with quote  Mark this post and the followings unread
I know exactly what you mean...
Sad
My music: here!
rh2y
PostPosted: Mon Sep 15, 2008 7:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Jyoti wrote:
Both my units have been returned now. I think I shall spend my refund on modular synth bits! Cool
Jyoti,
So....
Did you get some modular synth bits?
Or have you decided to give the Blofeld another go, now that the firmware bugs are supposedly fixed? Or are you holding out for the keyboard version...
Inquiring minds want to know! Smile
Shameless plug: http://www.soundcloud.com/rh2y
Shameless-er plug: http://www.evatontechnologies.com/
Music: https://atomstomolecules.bandcamp.com/releases
Jyoti
PostPosted: Mon Sep 15, 2008 8:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, my Doepfer morphing filter was faulty so I've returned that to EMIS (UK dealer). Once that's back, I'm going to spend the £300 on some more modular stuff. Dunno what yet! Razz
I do wish my Blofeld had worked. You should have seen how happy I was when I opened up my pressie. Sad
My music: here!
BobTheDog
PostPosted: Mon Sep 15, 2008 9:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Well if mine is ok there is always Christmas.
BobTheDog
PostPosted: Tue Sep 16, 2008 4:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Well it has arrived, paint job looks ok.
Updated to 1.04 and all seems well at the moment, no distortion or crackling heard yet.
Only strange thing I have is that you cannot adjust the volume while the unit is receiving midi of the usb, have not tried a midi cable yet.
BobTheDog
PostPosted: Tue Sep 16, 2008 5:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok Volume doesn't work when receiving midi clock.
Also displays for envs, lfos do not work when receiving midi from usb, display is blank!
I am going to try a midi lead.....
BobTheDog
PostPosted: Tue Sep 16, 2008 5:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Everything seems fine with the midi lead, problem is with usb.
Not a great start this!
Jyoti
PostPosted: Tue Sep 16, 2008 7:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry, mate. I had hoped the recent upgrade(s) had solved all the existing issues. It appears you've found new ones! Sad
However, don't get glum. Seeing how pro-active Waldorf are, I bet they're working on these glitches right now.
And you've had none of the bizarre crackling / aliasing / distortion I had so that's a huge step up.
Apart from the problems you're having, what do you think of it?
My music: here!
BobTheDog
PostPosted: Tue Sep 16, 2008 8:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Well it seems to be working fine from midi just not usb. I have sent an email to support.
Just playing around with multi mode, presets and arps at the moment.
For a little device it can play a few parts, included mp3 is a live recording, 5 parts, three of which are the drums.
Andy
Output 1-2.mp3
 Filesize:  396.86 KB
 Duration: 0:10
 Viewed:  3345 Time(s)
Jyoti
PostPosted: Tue Sep 16, 2008 8:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds good! thumb up
My music: here!
rh2y
PostPosted: Tue Sep 16, 2008 8:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Andy
Nice! Very punchy and clean!
Is that a preset multi, or did you construct your own? (I'm not that familiar with the multi mode yet -- too busy lately to play with the toys... )
BobTheDog
PostPosted: Tue Sep 16, 2008 9:42 am    Post subject: Reply with quote  Mark this post and the followings unread
It is a multi made up of presets.
I cannot work out how to load or save multis yet, I need to read the manual a bit I think!
T7
PostPosted: Tue Sep 16, 2008 9:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Multis can't be saved. This will likely become available in a future firmware release.
I'd really like to see Waldorf add voice layering on the same MIDI channel, to the multi mode.
rh2y
PostPosted: Tue Sep 16, 2008 9:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm, that seems like a bit of a limitation. Any chance you can export them via sysex, so you can at least save them to your computer? (I don't have my manual handy).
Otherwise, I guess you need to get all your multi work done in one session, or make sure you don't lose power to your Blofeld between sessions!
BobTheDog
PostPosted: Tue Sep 16, 2008 10:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Maybe program changes will work on each channel when you set it to multi mode, I have not tried this yet.
BobTheDog
PostPosted: Tue Sep 16, 2008 10:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Well It always seems to be in multi mode and bank/progchange work fine for all channels.
BobTheDog
PostPosted: Wed Sep 17, 2008 1:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Got a reply from Waldorf, they say this behavior is normal. They use a "low-cost" dsp and the audio performance is at a high priority, with the screen update and volume at a low priority, if you send it loads of midi the screen will not be updated correctly.
I suppose the USB stuff takes up more cpu than the midi port.
Andy
Former site admin
Audio files: 353
PostPosted: Wed Sep 17, 2008 5:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Strange idea of "normal" there ...
View user's profile
BobTheDog
PostPosted: Wed Sep 17, 2008 5:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Its a normal bug I should think, probably will be fixed in some future version.
Former site admin
Audio files: 353
PostPosted: Wed Sep 17, 2008 6:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Likely just lazy programming sold as a feature Laughing
View user's profile
BobTheDog
PostPosted: Wed Sep 17, 2008 6:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Well its "Feature Rich", heres another one:
Changing volume of one of the patches in a multi seems to effect the other patch volumes even though the volume display stays the same.
Makes balancing volumes in multis a little tricky
Former site admin
Audio files: 353
PostPosted: Wed Sep 17, 2008 6:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Laughing
Sometimes the market has demands that can't be understood by techies.
View user's profile
BobTheDog
PostPosted: Wed Sep 17, 2008 6:18 am    Post subject: Reply with quote  Mark this post and the followings unread
I must admit it's a nice little synth though, I am willing to put up with a few teething issues until they are fixed.
Former site admin
Audio files: 353
PostPosted: Wed Sep 17, 2008 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Let's highlight that!
View user's profile
T7
PostPosted: Tue Dec 16, 2008 6:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, I gave it a few months in hopes Waldorf would work out the poor hardware quality, then went and bought another Blofeld today.
My third Blofeld has the same problems: flaking paint and noisy headphone amp.
I'm willing to accept that Waldorf just spec'd a really poor headphone amp, but the flaking paint is unacceptable.
I wonder if the $4000. Stromberg will have the same crappy paint? Confused
