DIY Vocoder projects?
Page 3 of 6 [138 Posts]
goodrevdoc
PostPosted: Thu Nov 08, 2007 8:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Those look to be close if not closer. (21 pins obv, not 13) I'm sure the layout could be modded if not... Not familiar with Conrad. Do they ship stateside? Reasonable prices? Min order? Thanks for posting this btw...
-justin
goodrevdoc
PostPosted: Fri Nov 09, 2007 6:33 pm    Post subject:   Reply with quote  Mark this post and the followings unread
So here's a picture of my completed vocoder. Sorry for the blur, I'm not much with cameras...
Posted Image
I used a sheet of clear laser decal paper for the marking. Not bad, but if I do it again it will be better. It is shown functional, but I'm gonna rip it apart and tweak the ensemble (actually a Tonepad Small Clone Stereo w/ CD4053 switching). Not bad I guess considering this is the first rack mount thing I've ever made/owned (now I need to buy a rack!!!). Anyway enjoy...
-justin
Audio files: 267
PostPosted: Sun Nov 11, 2007 11:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks great, Justin. Looking forward to some music. Or, should the be "hearing forward"?
23isgood
PostPosted: Sun Nov 11, 2007 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow it looks great! Can you direct me to where you got the clear laser decal paper? Thats what I need to label my Klee panel.
thanks
pete
Check out my music
goodrevdoc
PostPosted: Sun Nov 11, 2007 6:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey thanks Howard and Pete! In the US, smallbear sells the decal stock, but I got mine from MIcro-Mark. They have several varieties to choose from, I opted for the "starter pack" that has a few sheets of clear and a few of white. It's item #82711 for laser. Funny, I actually got the Idea from Bugbrand Tom's Klee panel. Doing a 19" panel was daunting, especially for it being the first time I used this stuff, but anything smaller than 8.5x11 I can see being relatively simple.
-justin
synthmonger
PostPosted: Wed Jul 02, 2008 12:20 am    Post subject: okita problems Reply with quote  Mark this post and the followings unread
I'm getting a couple weird issues with my okita.
A couple things I should mention are:
I used 100nf decop caps instead of the 10n on the voice board
I used SA571Ns
I am getting a low buzz from the voice board
I let my friend put it together which was one of his first projects so the soldering isn't too great. I went over it and found a couple bad joints but it looks ok.
The i/o board works great but the instrument op-amp gets too hot to touch right off the bat, it hasn't burned out...yet
I noticed the wiring on the diagram was a little off, but to be safe 15 on the pot should be 13 right?
Any suggestions?
synthmonger
PostPosted: Thu Jul 03, 2008 3:29 am    Post subject: meh Reply with quote  Mark this post and the followings unread
Couple new things...
Switching to a 12v psu eliminates the hum and there seems to be no difference in the performance.
I noticed on the i/o board point "B" (leading to a polarized 10uf cap going into pin 13) is not on the schematic and the 4.7uF cap from pin 7's compander is non existant and should be going to the voice board. Does this sound right?
Also, I just found out that pin 7 should have a 10k resistor going to the close 10uF and 10K connection. This makes everything work sorta right. Razz Razz
Though I am getting a little bit of mic bleedthru but it's hard to tell when the instrument gain is up.
For synths the instrument input seems to work dandy, but guitar sounds like crackly garbage. The op-amp is still getting a bit too hot.
The signal level doesn't follow the audio levels as I expected -the led is constantly on. Shouldn't it fade in and out like a normal signal indicator does? The peak acts the same way, but only when the gain is up or the signal is obviously peaking but it doesn't fade out.
Sorry for grammatical errors I've been up far too long... Crying or Very sad
synthmonger
PostPosted: Thu Jul 03, 2008 12:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
wave !!!!! I think I figured out what's wrong. In Justin's design there is a +1uF that is next to the diode and 2n3904 signal/peak indicator should actually be a .33uf as the original design lists. I guess that's why the signal indicator was always on and didn't fade out like it should.
Do you guys think this is why the instrument op-amp was getting hot? Hard to tell since the microphone op-amp was running cool.
Too bad I'm at work right now and will be here for another hour before I can go home and verify this. I was wondering why I didn't use the two .33uf caps that I ordered from the BOM list. jackson dancing
synthmonger
PostPosted: Sun Jul 06, 2008 1:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Swapping the cap made the response only better. The indicator is whats causing it to get hot. I'm sure of this because I bent pins 1-3 up and made sure they didn't fit in the socket and it caused the heat to go away. I put them back in and desoldered the 47k resistor going to ground and left the pin floating which allowed the signal indicator to work and the op-amp to remain cool.
Any idear why?
goodrevdoc
PostPosted: Sun Jul 06, 2008 9:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
wave Cool! Somebody built one. Way to go, synthmonger. thumright thumleft I actually haven't been around for quite some time. (travel and work, of course) But I am so jazzed to hear someone actually finished one. I only glimpsed over your corrections, but I will crack open the beast tomorrow and confirm your findings. Many moons later, I can say that my Okita is still functioning well and never had any noise issues at all. I used 5 SA571's in the voice board and an NE570 for the actual compander. My Instrument op-amp (TL072) got hot when I first built fired it up, but then went away randomly. I assumed it was a bad solder joint as I had found a few others...(3 or 4 out of 1200 ain't bad Wink ) Hey synthmonger, what are yr thoughts/impressions of this beast? IMHO, it does the "vocoder effect very well, and is pretty capable for general use. Congrats again, and PICS!!! SAMPLES!!!
-justin
synthmonger
PostPosted: Mon Jul 07, 2008 2:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Well this is my first vocoder ever. I've played with a microkorg for about 2 seconds and I don't really remember how it sounded. I do realllly love the sound of it and I was playing it for about an hour each day for the past couple weeks just saying random things into it. It's like a childs toy hehe!
The only beef I have with it are the signal indicators, I do wish they would fade in and out like one would expect them too. I'm 100 billion % sure everything is in it's right place, according to the schematic and board itself, but of course, I could be wrong...I just would be unbelievably surprised to find something amiss since I spent a good 10+ hours staring and tracing the board for any faults.
I do need to build a better PSU, in fact I need to build one period. I was using a crummy one I built years ago for testing things out and I think it's going kaput. I'm focused on finishing a few designs right now before I even touch the vocoder again, cos if I do I'll waste alot of time just playing with it ;D
goodrevdoc
PostPosted: Mon Jul 07, 2008 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
synthmonger,
Just gave my Okita a once over and checked it agianst yr findings. Here is what I've found:
Yes, this seems to make sense. This pertains to the headphone amp, right?
If I am reading correctly, the 10uF cap is a decoupling cap. The pin 7 fiasco is a small error in the layout. Just run a jumper from where the 4.7uF Tant and the 10K resistor meet to the trace connected to pin 7 on the compander. This was done on my unit, I just overlooked it when revising the layout. Does this make sense?
This is an error in my labeling. Thanks for finding it. On my unit, I have always had the .33uF Tant. caps installed. Which is sort of a pity because I too had secretly hoped to improve the indicator function.
This was my first vocoder as well. Like yourself, I had had only limited practical experience with vocoders, so the child's toy definately applies!!! Some of my favorite things to say are:
Freeze Humans!
All your base, base, base...
Voltron, defender of the universe!!!
I built a dedicated power supply for this one. it uses a Tamura PCB-mount transformer and is very compact and reliable. I wouldn't run a modular on it but I've used this design several times for stand alone units with great success. I can send you the layout if you like.
As for those pesky signal indicators, I definitely feel yr pain. They seem to serve a very basic utilitarian function, but very little else beyond that. If I were to do it all again, I would definitely hack in some sort of 10 LED bar graph display. (or good old VU meters, panel space willing Very Happy ) The 4558's are just set up as dual comparators being fed from the input op amps. Hacking in some sort of LM3914 daughterboard would seem to make the most sense. I would do it myself if I hadn't already finished my panel. Also, putting square holes in metal scares the heck out of me. Laughing
Let me know if all of this makes sense and if there's anything else I can help you with. Till then, Happy Vocoding!!
-justin
synthmonger
PostPosted: Mon Jul 07, 2008 7:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah the headphone amp.
Makes sense. That's all I did after looking over it again.
I think I may redo the entire signal section or just use one of CGS led indicator pcbs to monitor the signal input. I hate how they just turn on or off, it's pretty much useless.
So is your instrument op-amp getting hot at all still?
The PSU layout would be great, thanks!
Ganzha
Audio files: 29
PostPosted: Mon Sep 15, 2008 10:56 pm    Post subject: I am going to assemle! Reply with quote  Mark this post and the followings unread
Hi!
I have a schematics diagramm of vocoder from 1980. The source Sovyet (USSR) magazine.
http://ziart.kz
andrewF
PostPosted: Tue Sep 16, 2008 1:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Ganzha
does it contain any unusual USSR chips?
would you be able to upload the files?
Ganzha
Audio files: 29
PostPosted: Thu Sep 18, 2008 12:17 am    Post subject: USSR vocoder Reply with quote  Mark this post and the followings unread
Hi!
It includes analog of CA3045 for VCA's
how to share scans here? Just to attache?
Thanks for interest!
http://ziart.kz
PostPosted: Thu Sep 18, 2008 12:35 am    Post subject: Reply with quote  Mark this post and the followings unread
hi,
if you have access to webspace post just the link.
you can even email me the scans. i will upload them and post the url.
or just upload it to flickR?
hallo,
wenn du webspace hast, dann kannst du einfach den link posten.
du kannst mir die scans auch schicken (email) und ich lade sie dann hoch und poste den link.
oder einfack auf flickR hochladen?
Posted Image
Ganzha
Audio files: 29
PostPosted: Thu Sep 18, 2008 12:36 am    Post subject: SOviet's vocoder Reply with quote  Mark this post and the followings unread
It qwite simple, very close to Okita vocoder, it includes VCA's on K159NT1D - 2 matched transistors
nothing special at all
 Filesize:  152.79 KB
 Viewed:  842 Time(s)
 Filesize:  186.02 KB
 Viewed:  796 Time(s)
http://ziart.kz
e-grad
PostPosted: Thu Sep 18, 2008 1:16 am    Post subject: Re: USSR vocoder Reply with quote  Mark this post and the followings unread
Is it a subsititute for K140UD20 or K140UD7?
Ganzha
Audio files: 29
PostPosted: Thu Sep 18, 2008 1:49 am    Post subject: About components Reply with quote  Mark this post and the followings unread
Hi!
K140 UD 7 is full analog 741 U could excnage for any tipe like TL072,TL 074
k140 Ud 20 - simple double 741 - TL 072 completely fits!
If you examinate this schematic U find that it is clone of Okita vocoder without NE570
and little bit simple
http://ziart.kz
austrohungaro
PostPosted: Thu Sep 18, 2008 1:53 am    Post subject: Re: USSR vocoder Reply with quote  Mark this post and the followings unread
e-grad wrote:
Is it a substitute for K140UD20 or K140UD7?
I think K159NT1A is the transistor array .
K140UD... are Op Amps
Look at this site. It's quite obscure for me, it's not in english, the cyrillic to latin transport is confusing sometimes... but it's useful:
http://www.xs4all.nl/~ganswijk/chipdir/soviet/latin/data.htm
I found this site because I have some soviet synths and wanted to repair one of them...
BTW, you can have schematics for EM26 soviet vocoder here:
http://filters.muziq.be/model/elektronika/em26
I have this vocoder twice. First one has some issues, so I decided to buy another. Maybe in the future I will try to repair it, but I'm too ignorant right now.
e-grad
PostPosted: Thu Sep 18, 2008 2:05 am    Post subject: Re: USSR vocoder Reply with quote  Mark this post and the followings unread
Yes, since it's not handled uniformly (e.g. Ж becomes: sh or j) I usually prefer the cyrrilc original.
austrohungaro
PostPosted: Thu Sep 18, 2008 2:11 am    Post subject: Re: USSR vocoder Reply with quote  Mark this post and the followings unread
Then you could try this:
http://www.xs4all.nl/~ganswijk/chipdir/soviet/chips.htm
e-grad
PostPosted: Thu Sep 18, 2008 2:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool site, thanks!
Ganzha
Audio files: 29
PostPosted: Sat Sep 20, 2008 4:27 am    Post subject: NE570N and SA571 Reply with quote  Mark this post and the followings unread
Hi!
here on EU the price for NE570 and Sa571 - around 5EUR,
that is too expensive to me I am going to build an Okita with VCA in CA3080
that is only solution
http://ziart.kz
