The DB60XG is basically
a DB50XG with the SW60XG's additional capabilities to add
(individually-programmable) effects processing to each mixer source
(wave, line-in, mic, cd, as well as midi). The SW60XG's AD Mixer
section is removed from the DB60XG, and instead connected (through the
waveblaster connector) to the 3D's mixer. That makes sense if you really
think about it, there is no need to have the SW60XG's AD mixer on the
daughtercard since all soundboards I know of already have a mixer.
i start to wonder if the daughterboard has an analogue audio input at all. maybe the A/D conversion is done on the motherboard (which provides the actual audio mixer for the PC)... could this be? _________________
The fact that pins 12 & 16 have identical connections and paths to the the AK-4510 IC still makes me think that they are left and right analog audio inputs. I have tried to get a datasheet on the AK-4510 but have been unsuccessful so far. Here is another box built around the DB60XG http://www.digsys.bg/eunetweb/lucho/ I tried sending him an email last night but it was kicked back.
OTOH what sense would make a second A/D converter on the daughterboard as there is one on the motherboard? we don't know yet.
me too. _________________
Posted: Thu Oct 30, 2008 4:50 pm Post subject:
DB60XG Demo
Hello All,
After all of the discussion about analog inputs I figured I would think about something else and upload a demo of the DB60XG with the GM Voice interface. The MIDI file is an XG specific file that I downloaded a number of years ago. The name of the file is Matrix01.mid, and I think it does a good job at highlighting the great sound of the DB50/60XG cards.
Also, I thought it might help to mention the current consumption of each one of the power supplies if you are interested in using the DB60XG.
Here are the currents that I measured for each supply including the GM Voice interface:
To test the card out I am using some bench power supplies and not the GM Voice regulator PCB. To use the GM Voice power supply board will probably require cutting a trace and inserting a 13 ohm 3 Watt resistor in between the +12V regulator output and the input to the +5V regulator. This will lower the input voltage to the +5V reg. to about 8 Volts and reduce the total power dissipation of the regulator.
great. thank you for these measurements. they will help me finding the appropriate PSU for my triple GM-voice... _________________
Posted: Mon Nov 03, 2008 1:53 am Post subject:
DB60XG Pinout Subject description: Old Player Schematics
Here I send you all, the schematics of an old commercial Midi player (I don't remember the name).
The good news is that it has the complete pinout of the wavetable, and curiously it works with -8 and +8 volts, instead of -12 and +12 volts. The proyect itself only needs 5 volts, and then converts to the desired voltages.
It has also a pream for the A/D ins, and a Midi out if the card supports it.
I hope it would help you all.
Gflorez
Filesize:
666.39 KB
Viewed:
2063 Time(s)
thank you very much for posting this. great. now we know the db60xg definetely provides analogue inputs.
funny, the db60xg is powered by +/-8V in this case (there are no 8V rails in a PC system, are they? _________________
Joined: Nov 09, 2006 Posts: 649 Location: Spring Lake, Mi, USA
Audio files: 21
Posted: Mon Nov 03, 2008 7:49 am Post subject:
So now we know that all pins but 2 and 13 are used on the db60xg. I thought the midi out on pin 8 was unnecessary, but if you want to do System, Part, etc bulk data dumps, you'd definitely need a midi out on these devices.
The choice for the +/-8Volts is a little curious to me. I mean, you need quite a bit of power in for the +5V line, so there's no way to run this off batteries. I suppose it makes the input wall wart requirements simpler: a common 9VDC/500mA one ought to do it.
When Thomas and I worked on this 10 years ago, we were wondering if we couldn't just use his standard +/-15V power supply requirements, but backed off to the prescribed +/-12V due to the number of daughterboard manufacturers. We played it safe.
Posted: Mon Nov 03, 2008 8:34 am Post subject:
more on DB60XG
antman49443 says:
" I thought the midi out on pin 8 was unnecessary, but if you want to do System, Part, etc bulk data dumps, you'd definitely need a midi out on these devices. "
Yes is unnecesary as in theory none of the Yamaha Wavetable boards supports Midi out, but is interesting to other makers boards that could own it. I don't have that information.
I believe I tried both of those SYSEX commands already, but I will try them again. The web site with these commands is confusing because it says that the Model ID for the DB60XG is 49. It's not clear whether the DB60XG with take all of the commands just by setting the ID to 49. The second command you listed shows 4C.
Posted: Mon Nov 03, 2008 10:08 am Post subject:
More about DB60XG
If you read the manual of the DB50XG you can see that the card accepts other IDs, begining from the TG300, QS300, Roland GS, XG native(4C) commands... It is four sintetizers in one. Its brother the DB60XG has to maintain some of the commands plus some more about the A/D parts.
Don't change the IDs to the messages as the board understands they good as they are.
The command are mapped inside the board to emulate other sints, but the XG module (4C) is native. (some messages are missing).
Try to download the "Yamaha XG format Specification".
XG is hard to understand at the begining.(I'm too at the begining!)
Audio files: 21
Posted: Mon Nov 03, 2008 8:56 pm Post subject:
Tim, gfloreza,
You guys are my heroes! This brings new life into this project! Even if folks out there aren't interested in the XG synth, the FX section will blow them away! I've used the amp simulator and overdrive to make some very good power guitar stuff and I love using the pitch shifter on my voice.
Our friend in Shanghai is still selling the db60xg clones on ebay for US$25+US$15 shipping to the US...I'm guessing it would be similarly priced to Canada, Europe or Australia.
There's seems to be a lot of misinformation floating around about the DB50XG and the DB60XG, as far as the capabilities of each. I'm even wondering if the DB50XG has analog inputs too. The MU10 is supposed to be a DB50XG in a module form factor and it has inputs. Someone with a DB50XG should try it and see.
Note: The DB comes up in mono mode so you need to send:
F0 43 10 4C 11 00 00 01 F7 - For stereo mode.
Correction: The commands below that I showed earlier should designate the Left channel since NN=00 (NN=01 - Right)
4.) F0 43 10 4C 10 00 12 64 F7 - (FULL CHORUS ON RIGHT CH.)
5.) F0 43 10 4C 10 00 13 64 F7 - (FULL REVERB ON RIGHT CH.)
I used XGEDIT95 for editing last night and it works very well. I downloaded it from the Megatrade web site. I want to try XGGold too but have not installed it yet.
Posted: Tue Nov 04, 2008 10:59 am Post subject:
DB60XG and others
Hello all.
In this link: (https://vsr.informatik.tu-chemnitz.de/twiki/bin/view/Sonstiges/WaveTableSoundCards) is a list of ISA or PCI cards or other things, that admits daugtherboards, and a list of them.
