Coming up on Radio 1 at
M185 sequencer Project - NEW PCB VERSION
Page 9 of 46 [1139 Posts]
Goto page: Previous 1, 2, 3, ..., 7, 8, 9, 10, 11, ..., 44, 45, 46 Next
djthomaswhite
PostPosted: Fri Oct 03, 2008 4:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is a "work in Progress" version of my 8-space MOTM version. I want to tweak this mother so I am going with larger knob spacing and helping more than just my finger tips get on the knobs. Woot!
Thomas
8 Space MOTM Format.pdf
 Filename:  8 Space MOTM Format.pdf
 Filesize:  264.87 KB
 Downloaded:  831 Time(s)
Thomas
www.naturalrhythmmusic.com/diy.html
Luka
PostPosted: Fri Oct 03, 2008 4:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
nice thomas
i was thinking about my panel design today also
since i have 2 boards i was thinking of building them together in a similar fasion as my circular klee design. ill normalise the clock connection so you can operate them in a 1/16 or synced 2/8 or also allow the connection to be broken so they work of independant clocks.
once i get some time ill try get some ideas down in photoshop
problemchild
melbourne australia
ryktnk
PostPosted: Fri Oct 03, 2008 5:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
that looks really nice Thomas.
I was thinking of a horizontal layout for Euro format would
be good too.
Also if you prefer the "max stage" control can also be an 8way switch.
-ryk
ringer
PostPosted: Sat Oct 04, 2008 7:02 am    Post subject: Reply with quote  Mark this post and the followings unread
ryktnk wrote:
hello
PS Has anybody finished building one yet ?[/b]
-ryk
Hi Ryktnk,
The motherboard pcb, that will hold all the panel components, is done and will go to the pcb house and the front is going to FPE. So, it will be about a month before it is done. I will post pics when it is ready.
Regards,
Ringer
LektroiD
PostPosted: Sat Oct 04, 2008 11:57 am    Post subject: Reply with quote  Mark this post and the followings unread
henrikgo wrote:
If there's another run, I'm in for two kits/PCBs, prepay is no problem!
Me too! Especially if it's as a full kit (panel/switches, etc.)
303monkey
PostPosted: Wed Oct 08, 2008 1:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi there
Any news on any switshes?
I may want to up my order too for some spares. An extra set of each making 3 sets.
View user's profile
Appliancide*
PostPosted: Wed Oct 08, 2008 8:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Count me in for a couple if there's another run. This looks awesome!
pdman1
PostPosted: Thu Oct 16, 2008 10:14 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll take one or two if there is another run.
Also what is the cost for the PCB?
Thanks
lexvortex
PostPosted: Thu Oct 16, 2008 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
How close are we to another run? Also how hard would it be to connect two PCBs like Luka suggested,
Thanks,
ryktnk
PostPosted: Fri Oct 17, 2008 8:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
RE another run, will need a few more orders to get
a full run of pcbs, but I'll do some counting and see !
RE connecting two boards, should be pretty straightforward:-
use the clock from one board for both, and connect the RST, NXT & PRV
switches from one board to the other. [in theory]
-ryk
Appliancide*
PostPosted: Fri Oct 17, 2008 4:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
ryktnk wrote:
Hello
-ryk
Start a poll! Look at how fast the Klee boards sell out.
If there's not enough interest for another run, I would consider trading one set of Klee boards for one of these if anyone would be interested in that.
The Alison Project
PostPosted: Fri Oct 17, 2008 11:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thought I would throw this up.
Still working on a dual version panel design but I decided to throw one together in my old Klee panel to play around with it, and I am having a blast....
The Two LEDS on at once it due to the time the pic was taken,,, plan to throw a gate out LED on there and a attenuator for the stage cv....
 Filesize:  309.93 KB
 Viewed:  332 Time(s)
The Alison Project
www.thealisonproject.com
ryktnk
PostPosted: Sat Oct 18, 2008 11:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey that's great.
Someone has made one, I was getting worried !
-ryk
The Alison Project
PostPosted: Sat Oct 18, 2008 11:45 am    Post subject: Reply with quote  Mark this post and the followings unread
ryktnk wrote:
Hey that's great.
-ryk
HAHA, all good.
Everything worked perfectly on power up except that I wired the Gate Time and Tempo pots backwards which was my bad and I haven't tested changing the Stage CV voltage yet.
I finished it pretty late last night so I will get to that when I get home from work today...
It is pretty amazing what you can get out of changing the amount of stages and the gate on each step...
Glad I am making two.
The Alison Project
Peake
PostPosted: Sat Oct 18, 2008 3:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm sure that others have come up with their own answers, but for R68 I managed to get a combined value of 66.8K from a 60.4K and 6.8K resistors. Use what you've got.
LektroiD
PostPosted: Sun Oct 19, 2008 1:09 am    Post subject: Reply with quote  Mark this post and the followings unread
These have gone already?
You've got to be quick off the mark around here!
mono-poly
PostPosted: Sun Oct 19, 2008 2:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Any news about the knobs?
ryktnk
PostPosted: Sun Oct 19, 2008 2:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello
Large tolerance can be a useful sometimes !
R68 can also be made up from a 62K & 4.7K resistor in series = 66.9k
only 0.1 diff !
Switches ?
It seems there is plenty of interest, so I will
try and arrange to get some more, sorry for the
delay - have been away for a month.
-ryk
etaoin
PostPosted: Mon Oct 20, 2008 1:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Interesting calculation ryk... Wink
I have some 66.5k in stock which I assume will be fine?
http://www.casia.org/modular/
ryktnk
PostPosted: Mon Oct 20, 2008 2:46 am    Post subject: Reply with quote  Mark this post and the followings unread
oops sorry
66.7k
Embarassed
panele
PostPosted: Mon Oct 20, 2008 11:24 am    Post subject: Reply with quote  Mark this post and the followings unread
some points of the panel wiring are confusing for me.
at stage count switch 1, is p1 connected to p2?
does p1 at the stage gate mode switches have to be connected
to the poles (q)? same question for sequence mode and step subdivision switch.
i`m using 1p 12t rotary switches for all of them
hope someone can help me.
panele
ryktnk
PostPosted: Mon Oct 20, 2008 3:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello
No "P1" is un-connected - has no connection.
No, same again "P1" is un-connected.
Sorry for the confusion, the line from Q1 just
represents the switch wiper, in a possible switch position
Hope that helps
-ryk
panele
PostPosted: Tue Oct 21, 2008 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very Happy thank you for the tip,
i`ve corrected the wiring
and now it`s running.
makes fun to play around with this unit.
if there will be a second run i`ll take a second one!
thank you for this project
vtl5c3
PostPosted: Tue Oct 21, 2008 7:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked
Not sure if you have me in your headcount, but I definitely want in on one if you do another run.
Romeo
ryktnk wrote:
Hello
-ryk
del_poolp
PostPosted: Sat Nov 01, 2008 5:17 am    Post subject: Reply with quote  Mark this post and the followings unread
You have any news for the next run ? (i'm impatient Embarassed )
