Coming up on Radio 1 at
YUSYNTH EMS-diode ladder filter
Page 3 of 6 [137 Posts]
yusynth
PostPosted: Mon Dec 22, 2008 3:49 am    Post subject: Reply with quote  Mark this post and the followings unread
OK 220K Wink Then the voltage swing is weird it should stay below 0V and at least go down to -2.4V. Is some kind of voltage fed at the resonance CV input ?
Question : which version are you using the CA3096 version (U5) or the tranny version.
Yves
stijn
PostPosted: Mon Dec 22, 2008 8:42 am    Post subject: Reply with quote  Mark this post and the followings unread
I have the descrete version. (bridechamber kit)
there is no voltage at the cv control for the resonance
stijn
PostPosted: Tue Dec 30, 2008 7:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Ives, it turned out that the bridechamber kit has a PN4391 insted of a 2N3819 jfet, wich has a different pin out. So I desolderded it (wich was quite a hasle, are there any tricks fot this besides a solder sucker?) and flipped it but now I have no resonance at all, so I guess it's broken?
yusynth
PostPosted: Tue Dec 30, 2008 7:48 am    Post subject: Reply with quote  Mark this post and the followings unread
I see, you should let know this to Scott Deyo because he provided you with a component that is not pin to pin compatible with the 2N3819...
It may not be broken but have a different pinch voltage than expected. As I explained on my page the characteristics of the pinch voltage of a JFET brand are very dispersed. JFETs are not as reliable in terms of charateristics as can be BJT transistors and picking two JFETs from the same batch may give very different results. Here it's even more different because you have a different brand of JFET...
What you can do is to take a 47K resistor and connect it in parallel with R41, and see if there is an improvement of the resonance control. If you recover the resonance control then try using other values in order to find the one that gives you full range. Otherwise, that is if with the 47K resistor you don't recover the resonance control, then your JFET is dead and replace it (preferably with a 2N3819 Wink )
Yves
chaorta
PostPosted: Wed Jan 21, 2009 10:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's a dumb question from a new DIY'er...i'd like to purchase this and build it. I do have building experience, and can SORT of read a schematic. My question is more mechanical...is the PCB small enough to fit in a Doepfer A100 case and will it run at +/- 12v, and if so, how would i go about making this happen?
Time is an illusion. Lunchtime doubly so.
yusynth
PostPosted: Wed Jan 21, 2009 12:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Chaorta and welcome
Concerning the PCB I can't tell you because I have no Doepfer case to check it. But may be if give the size of the PCB you can make yourself an idea. The PCB is 10 cm per 7.5 cm and has four fixation holes.
Concerning the power supply, yes it will run at +12V/-12V, for this you just need to remove some components : remove R3 (82ohm) and bypass its pads with a wire, remove U2 (78L12/7812) bypass with an insulated wire the left and rigth pads (leave the middle pad unconnected) and that's it (see the diagram below : left before mod, right : after mod, bypass wires shown in red)
 Filesize:  43.57 KB
 Viewed:  1022 Time(s)
Yves
chaorta
PostPosted: Wed Jan 21, 2009 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well that was easy, thanks Smile
softfin
PostPosted: Sat Feb 07, 2009 10:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Finished my pair of diode ladders. I put them in my +-12V case, so I did the suggested modifications, but found the -9V was only about -7.25V, so I exchanged R4 with a 120ohm resistor and also replaced R50 with 5k trimmer as a voltage divider. I didn't measure the resistance of the trimmer when I achieved precise -9V, but it is probably around 2k.
These long awaited filters have this excellent spiky but pleasing character. The only downside seems to be CV bleedthrough which is louder than on my other filters. Is there any simple way to reduce it?
Btw, six diodes are reversed on the overlay with the color coded resistors.
Big thanks to Yves for this module!
yusynth
PostPosted: Sat Feb 07, 2009 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Did you match thorougly your diodes ? This is important to reduce the CV bleedthrough.
Concerning, the overlay error, this has been corrected on my site at least two months ago Wink
Yves
softfin
PostPosted: Sat Feb 07, 2009 1:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
I used the layouts I had archived some time ago, so I didn't notice the layout was already corrected. Shocked
Regarding the diodes, I took a strip of factory packed diodes and measured them simply by putting +9V across each one and measured the voltage drop. All diodes had almost exactly the same amount of voltage drop, the difference in drop between diodes being 0.01-0.02V. That was also pretty much as precise a measurement as possible on my multimeter.
Should I match them more carefully, and if so, is there a more precise method you could recommend?
yusynth
PostPosted: Sat Feb 07, 2009 2:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes you should... as a matter of fact they must be matched by pair within 2mV. The bleedthrough mostly comes for the unbalance between each side of the ladder. The principle of this kind of ladder is that the CV is canceled out by subtracting the left and right side of te ladder while the audio passes through because it is differentially transmitted by the input transistors.
Yves
softfin
PostPosted: Sun Feb 08, 2009 9:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the explanation, it makes perfect sense.
Since I couldn't get enough precision using my 'better' multimeter, I tried matching the diodes again with a lower voltage (1.6V) and using my old, cheapish DVM which actually allowed me to measure the voltage drop more precisely in millivolts.
So I matched diodes to 1mv and replaced all diodes in the ladders of both of my units. It seems cv bleedthru decreased considerably, but it is still audible.
I suppose I should get a better quality multimeter, if I want to have more precise and stable readings.
yusynth
PostPosted: Sun Feb 08, 2009 9:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Well as a matter of fact it would be difficult to get better with the matching of diodes. Now the next points to take care of are :
1°) try using different CA3046 (the matching of the differential transistor pair may vary from a chip to another : by the way avoid Thailand labelled brand they are very bad)
2°) if you are using the discrete version check the match of the BC557 pair and of BC547 pair, if you are using the CA3096 try different ICs.
Yves
softfin
PostPosted: Sun Feb 08, 2009 3:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
I tested if different transistor arrays would lower the cv bleedthru. There was no noticeable difference between Harris, Intersil or RCA 3046s and 3086s I tested.
I matched the BC557s and BC547 to very small difference in hfe, so I think they're ok.
I don't know is it my ears or is it for real, but the bleedthru seems to increase when I lower the resonance. I attached a clip to illustrate this.
kleeems.mp3
 Filesize:  2.9 MB
 Duration: 1:16
 Viewed:  3251 Time(s)
yusynth
PostPosted: Sun Feb 08, 2009 4:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
from your sample I'd say that you won't get a better result. As a matter of fact you could add a 100pF to 1nf cap in parallel with R22 to create just enough slew to attenuate the bump on fast attacks (this trick was used in the Minimoog filter).
Yves
softfin
PostPosted: Sun Feb 08, 2009 4:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok. I'll add the cap and perhaps a switch too, so I'll have the possibility to add just a bit of thump/click to the sound when I need it.
Thanks for your help.
numbertalk
PostPosted: Mon Feb 09, 2009 8:54 am    Post subject: Reply with quote  Mark this post and the followings unread
What a great sounding filter! This has been in my build queue for a while but think I need to bump up its priority a bit Smile
stijn
PostPosted: Wed Apr 08, 2009 1:32 am    Post subject: Reply with quote  Mark this post and the followings unread
ok Yves, I finally got the right jfet , I put it in but in all my exitement
hooked up the power in the wrong way Embarassed
so something got fried. can u tell me wich parts I should replace to make it work again?
yusynth
PostPosted: Wed Apr 08, 2009 10:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Ouch... This is a great classic and it also happened to me a couple of time... Embarassed
The following ICs and trannies may have fried (ordered from most certain death to may have survived) :
the 7812/78L12 regulator has probably been fried
the BC327 is also probably dead
the other ICs (TL074) and trannies have probably survived because the regulator died first, but I would replace the TL074 which doesn't like reverse power !
Did you see a fume ?
Yves
stijn
PostPosted: Thu Apr 09, 2009 12:04 am    Post subject: Reply with quote  Mark this post and the followings unread
tnx for the fast reply Yves.
ooh and yes there was a fume!
numbertalk
PostPosted: Thu Oct 08, 2009 7:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
yusynth wrote:
Here is a tip : for those of you who want to obtain a genuine EMS sound while using DOTCOM or YUSYNTH VCOs it is recommended to change the value of R8 to 27K. The output levels of these VCOs are much higher than those of an AKS and this makes a big difference in sound.
Hi Yves,
I notice on the schematic you also flag R9 as being changed in addition to R8. What value would you suggest changing R9 to? I don't have dotcom or yusynth vcos but my vcos are 10Vp-p, so I'm guessing I'd want to change these 2 resistors as well.
yusynth
PostPosted: Thu Oct 08, 2009 11:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
numbertalk wrote:
Hi Yves,
Hi if you have 10Vpp VCOs then it's the same as for YUSYNTH or DOTCOM VCOS, use 27K for R8 and leave R9 unchanged.
What is shown on the schematic is that one may modify either R8 or R9, or both to achieve the desired attenuation of the signal.
In your case you only need to change R8 as mentioned in the quote above.
Yves
ndkent
PostPosted: Fri Oct 09, 2009 2:20 am    Post subject: Reply with quote  Mark this post and the followings unread
I could see doing that if for practical purposes all your VCOs had every waveform ranged +-10v, but considering the original EMS has level pots out of the VCO I'd think an variable attenuator would be more ideal than adding more fixed attenuation.
yusynth
PostPosted: Fri Oct 09, 2009 2:33 am    Post subject: Reply with quote  Mark this post and the followings unread
As a matter of fact the yusynth EFM-filter already has such INPUT LEVEL pots in order to be able to process signal from a wide range of VCOs :
 Filesize:  105.62 KB
 Viewed:  41515 Time(s)
Yves
Scot Solida
PostPosted: Thu Oct 29, 2009 6:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just finished building this one tonight. At first, it didn't work properly, but using the 220 resistor as described above did the trick. It sounds terrific! I am using it in my Dotcom system, but I left R8 alone. for now. The input control knob should be enough for my needs. It won't do any harm will it?
In any event, I still need to mount the PCB to the panel. After that, I will do some A/B comparisons with my VCS3. I'll post the results in another thread.
