click on image to sign up
 Forum index » Clavia Nord Modular » G2 Patches - Completed » Synth
Additive Wavetable Synthesizer
Page 1 of 1 [11 Posts]
Tim Kleinert
G2 patch files: 236
PostPosted: Thu Jan 15, 2009 8:30 am    Post subject: Additive Wavetable Synthesizer
Subject description: user-definable additive wavetables with 32 partials(!) at good polyphony
Hi folks,
Here's a patch with some new tricks, taking the G2 beyond its limits once again.
The problem with doing additive synthesis on the G2 is the sheer bulk of modules required to provide not only a decent amount of partials, but also a good control thereof. 16 partials is about the maximum you can get, if you also want to do something reasonable with those -and even so, a voice will quickly max out a single DSP. Also, it's no easy task to find an architecture which is flexible, but also easy to use. Not the right stuff.
This patch neatly works around both these issues. It provides 8 fully editable waveforms based on 32 (!) partials each. These are represented by two cascaded control-sequencers, which are easy to edit and give instant visual feedback about the harmonic content. These waveforms are then consecutively arranged into a wavetable, which can be smoothly scanned through (manually, and/or by LFO/ENV), providing interesting spectral motions unable to be achieved with any other synthesis approach. (It sounds very similar to some of the Waldorf stuff. In fact, it was inspired by that.)
...and all this at a voice count of 14 voices for expanded G2s. Laughing
Well... this has to be the most complex patching I have ever done. The wavetable is built on a 100ms delay-line, which is sample-accurately locked as to serve as sampling memory. This delayline (per voice) is "loaded" with the waveforms at patch startup or variation change by an intricate procedure which resides in the FX area and pipes back "stuff" to the voices via interslot busses. It works like this: Each of the 8 waveform is represented by two cascaded control sequencers (32 partial levels) which are scanned through consecutively -waveform by waveform, partial by partial. The retrieved values drive a sine oscillator at increasing fractional offsets (1:2:3:4 etc.), thereby gradually filling up the wavetable with the required spectral information. This takes 3.2 seconds to complete (sorry). Once this "building up" is complete, the delayline shuts off into 100% feedback and acts as wavetable memory from there on. This wavetable memory can now be "scanned" by sample-accurately calibrated DIY sawtooth oscillators, recreating the desired waveforms at a far lower DSP cost than having to generate each partial separately in the voice area. With 2 readout pointers and crossfading, smooth transition between those waveforms then is achieved.
...sort of... Laughing
Here are the controls:
WT Scan; Manual - Manual position in the wavetable. The wavetable has a range from 0- 63, with the 8 waveforms found at increments of 8 (0, 8, 16, 32 etc.). Waveforms are crossfaded inbetween those values.
WT Scan; ENV Amt, LFO Amt - Scan the wavetable with dedicated envelope and LFO.
WAVETABLE; Reload! - Hit this button to reload the wavetable (this takes 3.2 seconds). Note that the wavetable has to be reloaded after editing a waveform, in order to hear the change!
PARTIALS LOAD; Level - Sets the overall level of the partials being loaded into the wavetable. If you encounter clipping, lower this. If the voices have oveall low volume, raise it. (Again, you have to hit reload after changing this parameter.)
WT LFO (Parameters) - wavetable-scanning LFO controls
WT ENV (Parameters) - wavetable-scanning ENV controls
VOLUME ENV & Voice Level - loudness control
plus FX: Chorus and stereo delay (sorry, no DSP left for reverb).
The 8 waveforms can be neatly edited from the panel with the "patch edit function". The corresponding modules are found in the first 2 columns of the FX area. The waveforms are labeled A,B,C...H and the two control sequencers represent partials 1-16 or 17-32. The sliders/knobs determine the partial levels, and the buttons underneath neatly mute/unmute the partial. Remember to hit "Reload!" -sorry for the inconvenience.
Note 1: the tuning isn't 100% perfect due to the DIY oscillator drivers. But: NO ALIASING! Smile
Note 2: This patch uses 3 interslot busses to pipe information from the FX area into the voices!
Note 3: The wavetable will automatically reload at patch startup or variation change.
Haven't had time for variations yet. Just wanted to get this off my mind, so I stop spending so much time on it, for fucks sake! Laughing
best,
tim
Edit: As usual, this is a work in progress. Optimised version(s) below in the thread.
AdditWavetableTK.pch2
synthesizer model providing user-definable additive wavetables with 32 partials(!), at good polyphony
 Filename:  AdditWavetableTK.pch2
 Filesize:  10.78 KB
 Downloaded:  2432 Time(s)
iPassenger
G2 patch files: 78
PostPosted: Fri Jan 16, 2009 3:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Haven't loaded this yet (at work) but it reads very well. Love the concept of build the waveform first then sample and use. Very smart indeed. Smile
iP (Ross)
Wan
G2 patch files: 46
PostPosted: Fri Jan 16, 2009 5:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Also haven't loaded it yet, my G2X is not available here for me, but i'm thorougly impressed by your description and design. Hail the Master
I'm looking forward trying out this synth, thank you very much for providing these fantastic patches!
Grtz Wan
Tim Kleinert
G2 patch files: 236
PostPosted: Fri Jan 16, 2009 7:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Folks, I found a DSP optimisation in the wavetable generator. The controlsequencer readouts need not to be running at audiorate. This brings the DSP usage down considerably, so I could throw in better FX. I've always been a lover of modulated delays, so, after the chorus, there's a nice modulated stereo delay with allpass/damping. The obligatory reverb module fitted in too. Smile
I also could have stuck to simpler FX and throw in 16 user-definable waveforms instead of 8. It would have fitted. But who wants to draw 16 waveforms? Laughing
AddiWavetable2TK.pch2
DSP optimisation in the wavetable generator --> more and better FX
 Filename:  AddiWavetable2TK.pch2
 Filesize:  12.11 KB
 Downloaded:  2513 Time(s)
jima
PostPosted: Fri Jan 16, 2009 10:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Fantastic work, Tim, I love it already!
Looking forward to playing with it...
Jim
dorremifasol
G2 patch files: 49
PostPosted: Fri Jan 16, 2009 12:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Marvelous work! State of the art programing.
Albert
zynthetix
Audio files: 10
G2 patch files: 13
PostPosted: Fri Jan 16, 2009 8:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is impressive. Thanks and keep it up.
G2egory
PostPosted: Sat Jan 17, 2009 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Gorgeous sounding patch. The delayed harmonic ringing makes it sound like the sound is swirling around you. What an expertly programmed Big-Wow sound. Excellent work in the difficult additive synth area that shows off the huge capabilities of a G2/G2X. Thanks for sharing this patch with us.
xav
G2 patch files: 7
PostPosted: Wed Jan 21, 2009 5:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Congratulations Tim!
That's a fabulous patch... I'll try once more to understand step by step how do those DIY osc work. But the sounds are amazing.
mother misty
G2 patch files: 130
PostPosted: Tue Jan 27, 2009 10:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Hats off for that, nice patch tim!
misty.
http://www.myspace.com/mariodemeyer
Tim Kleinert
G2 patch files: 236
PostPosted: Tue Jan 27, 2009 12:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Glad you are enjoying it.
I need to point something out: I've discovered that the wavetable memory is subject to signal degradation if you leave the patch running for some time. It seems that the delay modules very sublty degrade the signal, and those accumulate over time in the closed feedback loop. I hear a subtle film of high frequency noise getting more and more prominent within 10 minutes or so. Maybe it is due to the 16/24 bit conversion going on. Gotta love Clavia. Rolling Eyes
Anyway, reloading the wavetable will obviously make it go away instantly, either by hitting "Reload!" or just switching variation forth and back again. Maybe it annoys you less if you look at it like having to retune your drifty vintage analog synth before a take. Laughing
