Coming up on Radio 1 at
 Forum index » Instruments and Equipment » Cubase
How do i use alesis micron with cubase?!
Page 1 of 1 [11 Posts]
naw0r
PostPosted: Sat Mar 14, 2009 11:04 am    Post subject: How do i use alesis micron with cubase?!
Subject description: please help
Im using an alesis micron connected via a midi usb cable to a dell inspiron 6400 laptop.
the software im using is cubase essential 4.
when all plugged in no sound is created but the 'midi in activity' volume bar rises and falls as though there is.
cubase apperars to be recognising the keyboard as it shows it as an option for output routing. when selected no sound comes through. if i change it from 'usb audio device' to 'windows gs wavetable sw synth' i can use the keyboard to play a piano sound but it is incredibly delayed and incorrect.
i want to be able to record sounds made by my micron into cubase. how can i do this when the above is happening? how can i fix this?
i would really appreciate any help or advice.
thanks
Audio files: 19
PostPosted: Sat Mar 14, 2009 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Please do NOT double/ quadruple post! It is against forum rules. Thanks Very Happy
ACHTUNG!
BobTheDog
PostPosted: Sun Mar 15, 2009 4:30 am    Post subject: Reply with quote  Mark this post and the followings unread
How are you getting the audio from the micron into the laptop?
Andy
naw0r
PostPosted: Sun Mar 15, 2009 12:24 pm    Post subject: usb to midi in out Reply with quote  Mark this post and the followings unread
im using a midi to usb cable.
theres a midi in and a midi out cable that go into the back of the micron with both connect to a small black box. from the black box theres a usb cable. this is connected to my laptop.
the light on the box marked 'in' blinks when i play the micron, showing that signal is being communicated.
i hope this helps
Former site admin
Audio files: 353
PostPosted: Sun Mar 15, 2009 12:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
You'll need an audio cable too as MIDI is not for audio signals. Does your computer have an audio input?
naw0r
PostPosted: Mon Mar 16, 2009 4:57 am    Post subject: What does it look like ? Reply with quote  Mark this post and the followings unread
I may do but I'm not sure. What does it look like?
Audio files: 19
PostPosted: Mon Mar 16, 2009 5:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Have you looked at the manual yet?
http://www.alesis.com/micron
If not, try reading it. A manual is written to help you understand how something works. Idea
Alternatively, try Googling "jack plug +audio output". If reading is far too taxing for you, press the "images" button.
ACHTUNG!
naw0r
PostPosted: Mon Mar 16, 2009 12:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
i have a thing which will convert a large jack plug (guitar lead type thing) into the smaller kind (earphones etc), shall i plug that in the microphone input?
Audio files: 19
PostPosted: Mon Mar 16, 2009 1:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
I wouldn't bother using those adaptors- these things are quite unreliable. It would be best to read the manual and find exactly what you need to get. Get some proper leads A decent soundcard too (usb based) Very Happy
FWIW, you are going to get really stuck if you don't read the manual- especially when you get to working with Cubase!
ACHTUNG!
BobTheDog
PostPosted: Tue Mar 24, 2009 7:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Even after you have read the manual in fact!
Audio files: 19
PostPosted: Tue Mar 24, 2009 8:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Don't confuse the poor boy! Laughing
Yeah- while we're at it, Cubase sucks. Shocked Laughing Laughing
ACHTUNG!
