Coming up on Radio 1 at
The Karplus Strong eChucK DIY Project
Page 2 of 24 [577 Posts]
Goto page: Previous 1, 2, 3, 4, ..., 22, 23, 24 Next
Inventor
Audio files: 270
PostPosted: Mon Aug 24, 2009 2:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is a photo of the mysterious chopsticks. It is a proto board with a notch cut out of it and when seen from that angle it looks like chopsticks. Sorry photo is blurry.
Actually I'm surprised that you guys were distracted by the chopsticks so much that you missed the reflection of the UFO in the background! Laughing
The mysterious chopsticks
 Filesize:  148.47 KB
 Viewed:  1056 Time(s)
Inventor
Audio files: 270
PostPosted: Mon Aug 24, 2009 4:19 am    Post subject: Reply with quote  Mark this post and the followings unread
As a sort of test-fit, I did a board placement this morning, shown below. While the BS part of the BSG fits nicely, there is little room left for the G part (KS). So what I'm thinking of doing is simplifying the LEDIL logic somehow. I'll let you know how that goes.
Les
bsg board layout
 Filesize:  199.16 KB
 Viewed:  1034 Time(s)
Inventor
Audio files: 270
PostPosted: Mon Aug 24, 2009 5:15 am    Post subject: Reply with quote  Mark this post and the followings unread
I simplified the LEDIL to make more room on the board, and now there is plenty of space. You can see two sections of LEDIL in the attached schematic. There are no series resistors with the LEDs and no transistor buffer stages either. I may have to adjust the bias and gain of the output, but at least I think the output will be correct.
The performance difference here is that the input LEDs will get dimmer when there are more of them on at the same time, but that saves on battery life and makes for a more interesting display perhaps, so it's not really a negative.
LEDIL Schematic, simplified
 Filesize:  46.88 KB
 Viewed:  1070 Time(s)
droffset
PostPosted: Mon Aug 24, 2009 4:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looking great, you're really cranking on this , go, go, go, go.
Edit: Spelling mistakes.
Inventor
Audio files: 270
PostPosted: Mon Aug 24, 2009 9:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ty droffset, i need motivation like that. Shown is a layout with simplified LEDIL and two opamp chips on the output. Should be enough room for a KS circuit, should I ever get to testing that. Bet I should huh? Anyways ty and best wishes droffset.
Les
getting there
 Filesize:  170.87 KB
 Viewed:  1037 Time(s)
Inventor
Audio files: 270
PostPosted: Tue Aug 25, 2009 3:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK folks, I'm ready for a design review. The attached files are the schematic and board files for the BSG board, or BSKS as I've been calling it. I'd appreciate if anyone could review them and let me know what you think.
Thanks,
Les
BSKS4.sch
Schematic
 Filename:  BSKS4.sch
 Filesize:  154.67 KB
 Downloaded:  1122 Time(s)
BSKS4.brd
Board
 Filename:  BSKS4.brd
 Filesize:  56.36 KB
 Downloaded:  1106 Time(s)
Dan Lavin
Audio files: 21
PostPosted: Wed Aug 26, 2009 5:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Les,
these are Eagle files? Just checking.
regards, Dan
Inventor
Audio files: 270
PostPosted: Wed Aug 26, 2009 5:54 am    Post subject: Reply with quote  Mark this post and the followings unread
antman49443 wrote:
Les,
regards, Dan
Yes they are Eagle CAD files.
Les
toad008
PostPosted: Wed Aug 26, 2009 6:56 pm    Post subject: yo inventor Reply with quote  Mark this post and the followings unread
dude i like the pictures! Smile Where do i apply to be your lab studio slave? haha serious ... droooollllll
Toadie Shocked Shocked Shocked
Dan Lavin
Audio files: 21
PostPosted: Wed Aug 26, 2009 7:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Les,
If you can wait until the weekend, I'll see what I can do to review. Too many pushy customers are driving me crazy right now. State Machine can vouch for my pcb work.
regards, Dan
Audio files: 267
PostPosted: Wed Aug 26, 2009 9:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
On your boolean sequencer, what effect would using binary counters instead of decimal counters?
Inventor
Audio files: 270
PostPosted: Thu Aug 27, 2009 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
antman, sure I'm happy to wait for the weekend, I'm a little burned out after all that work.
Howard, This thing needs a binary counter, yes. I changed the counter from a 4017 decade counter to a 4040 binary counter for just that reason, it's what I need for the job. I had misunderstood and thought that a 4017 was a 10-bit binary counter, but now that I've seen it used in the baby 10, I realize my mistake.
To all, some issues I am concerned with are: will the new LEDIL really work? I have just thought it out and not constructed it. Also will the Karplus-Strong circuit work with this very simple implementation? I'm concerned about the HF pulsed input burst not doing the job and also the AC and DC bias are tied together. Maybe we can work out these details somehow and make this thing the DIY project it really should be!
Les
Inventor
Audio files: 270
PostPosted: Thu Aug 27, 2009 10:11 am    Post subject: Re: yo inventor Reply with quote  Mark this post and the followings unread
Toad, you are so funny, great sense of humor!
Les
Audio files: 267
PostPosted: Thu Aug 27, 2009 5:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
I usually drive LEDs with a buffer chip of some sort. It looks like your circuit can present some very large and quite variable loads on the counter. It's been a while since I worked with CMOS, but if I remember correctly, most logic devices aren't designed to drive loads. They look to drive very hi Z lines.
Inventor
Audio files: 270
PostPosted: Thu Aug 27, 2009 7:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Howard, you're right, and Dan noticed it too (sent me a message in pm). So now I need a work-around or else I go to surface mount or else get a new CAD tool. Good thing I asked for a design review!
Les
wmonk
Audio files: 15
PostPosted: Fri Aug 28, 2009 3:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Isn't panel mounting the LEDs and switches an option? You save a lot of space on the PCB if you do so. Or make 2 PCBs, one for the LEDs and switches, and one for the other parts, en connect them with a few ribbon cables.
Inventor
Audio files: 270
PostPosted: Fri Aug 28, 2009 4:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I had thought of making the single board as a panel mount dealie, but your idea of two boards with one as a panel mount seems more interesting now. The idea is to make it a stand-alone board or panel mount, your choice. If I have to add buffers for LEDs and more parts for Karplus-Strong, then I'll definitely need two boards. Thanks for the suggestion, wmonk.
Les
Inventor
Audio files: 270
PostPosted: Sat Aug 29, 2009 1:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Actually, another option is to do separate Boolean Sequencer and Karplus-Strong boards. This alternative makes some sense because modular synthesis folks might want to make only a K-S or only a BS board for panel mounting.
Certainly a K-S board does not seem to exist and with a whole board for K-S, we could have lots of features like pseudo-random noise burst and other input styles, filter options, etc. Besides, I do like the idea of an extended board pair for the stand-alone version rather than a sandwich board pair.
Just tossing ideas around. Clearly the board needs major revisions and I'm looking forward to reading more design review comments.
Les
Inventor
Audio files: 270
PostPosted: Sat Aug 29, 2009 2:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Also, another thing I'm not too hot about with the LEDIL is that it shows inverted bits. You see blinky lights according to your switch selections, but the lights are "on" when the logic is "off", so you only get a note when nothing blinks. This is counter-intuitive, though it still makes for a nice light show.
I'd prefer to just do it with standard LED outputs on resistors, and with a dual board approach that would work.
Les
droffset
PostPosted: Sat Aug 29, 2009 2:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Is the 4049 hex inverting buffer useful here?
wmonk
Audio files: 15
PostPosted: Sat Aug 29, 2009 3:43 am    Post subject: Reply with quote  Mark this post and the followings unread
I like the idea of a separate K-S board. You can easily add an interesting option for the modular guys: filter replacement. You add a standard 1-pole low pass filter to the board, and one can 'replace' this filter with switching sockets. I think there are many possibilities here to get all kinds of crazy sounds using different filters.
Inverters are the solution. Or use LED bargraph displays. (http://futurlec.com/LED/LEDBARRED.shtml) They're easy to fit and save a lot of space.
PostPosted: Sat Aug 29, 2009 4:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Jesus H Christ Les!!@!
Are you criminially insane or what?!?! Laughing
Love your work dude.
It's gonna be a week or two before I work out what the hell is goin on here!!
Inventor
Audio files: 270
PostPosted: Sun Aug 30, 2009 2:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks wmonk, that's just the LED bargraph part I've been looking for!
I also like the notion of a separate KS board, and with a filter option - whoot! This will go into the plans for sue!
Les
JovianPyx
Audio files: 237
PostPosted: Sun Aug 30, 2009 3:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
How many strings will the KS board support? Is it polyphonic?
Time flies like a banana.
corruptio optimi pessima
View user's profile
Inventor
Audio files: 270
PostPosted: Sun Aug 30, 2009 4:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey ScottG, actually it's monophonic. It only does one string.
Les
