Coming up on Radio 1 at
Ring Modulator for the Sound Lab
Page 3 of 3 [70 Posts]
Goto page: Previous 1, 2, 3
shimshon
PostPosted: Thu Jan 22, 2009 10:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks
Audio files: 267
PostPosted: Fri Jan 23, 2009 2:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
shimshon wrote:
stolenfat wrote:
jameco sells them for 9 bucks a pop, is there a cheaper place to find them? 9 bux! I think thats whacky!
they're on "sale" for 7.75 now Confused
Considering there is no need for trimpots and it is much more stable, this is a pretty reasonable price, IMHO.
LektroiD
PostPosted: Fri Mar 27, 2009 7:48 pm    Post subject: Re: super simple ring modulator Reply with quote  Mark this post and the followings unread
dnny wrote:
Hi all there is one RM circuit from Aaron Cram
its analog and uses LM13700 (transconductance Amp) + 3 op amps , 8 resistors and 2 pots - thats all! so it´s really super simple
i havent try it yet but, you cant lose anything by breadboarding this
http://www.ori.org/~aaronc/synth/
and scroll down for ring modulator
daniel
did anyone save this schematic before the link was removed?
*Edit* I found it:
http://experimentalistsanonymous.com/diy/Schematics/Ring%20Modulators%20and%20Frequency%20Shifters/LM13700%20ring%20mod.pdf
Anyone know the pin numbers for the 13700? They're missing on this schematic. Also the 33KΩ resistor is going nowhere?
LektroiD
alieneYe
PostPosted: Mon Mar 30, 2009 5:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
hello
it looks like that 33K is going to +voltage
here is the pinout of the National Semiconductor LM13700 from the datasheet. i believe this is the usual pinout for this chip.
Posted Image
hope that helps Smile
Dego
PostPosted: Mon Jun 15, 2009 12:13 am    Post subject: Re: super simple ring modulator Reply with quote  Mark this post and the followings unread
daniel
*Edit* I found it:
The link is gone again... Sad
optigrab929
PostPosted: Thu Nov 19, 2009 6:02 pm    Post subject:  AD633 Ring Mod
Subject description: HELP!
Hey,
I am trying to build this circuit>
http://www.musicfromouterspace.com/analogsynth/RingModulator/RingModulator.html
I'm new at this stuff, and it's for a project for school...I was told that I could use two 9V batteries linked together with battery snaps to create the +9V and -9V. Is this ok?
Also, how does this all translate to the breadboard (is -9V going to the ground rail, or are the things going to ground separate)?
I bet you can tell that I'm a novice.
Please help!
Thanks,
Brandon
Audio files: 19
PostPosted: Fri Nov 20, 2009 4:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Brandon, welcome to electro-music.com Very Happy
Yes- two 9v batts will be fine. You need to read off the spec sheet how much of less the chip will take, voltage and current wise. But yes, you should be fine. Smile
ACHTUNG!
optigrab929
PostPosted: Fri Nov 20, 2009 6:54 am    Post subject: Ring Mod Reply with quote  Mark this post and the followings unread
But I am confused -- should the things in my schematic going to "ground" be going to the same rail as the things going to -12V? (i.e. things going to +12V to the red rail and ground and -12V going to the blue rail)
I am very new to all of these procedures--if you have a tutorial or a detailed description of how to do this properly, it would be extremely helpful!
Thanks again,
Brandon
Former site admin
Audio files: 353
PostPosted: Fri Nov 20, 2009 9:57 am    Post subject: Reply with quote  Mark this post and the followings unread
You'll need the + of one battery to go to the - of another, that junction will be your ground (and you could make the connection between the batteries on the ground terminal of your circuit).
Then you'll have another two battery terminals, one labeled - which will go to the -12V connection on your circuit and another labeled + going to the +12V on the circuit.
like this :
Code:
        +---------------> to +12V on circuit
      -----  9 Volt battery 1
        +---------------> to Ground on circuit
      -----  9 Volt battery 2
        +---------------> to -12V on circuit
View user's profile
optigrab929
PostPosted: Fri Nov 20, 2009 1:47 pm    Post subject: Power Supply Reply with quote  Mark this post and the followings unread
I have two 9V battery snaps (each with a red and a black wire). So I snapped the positive of one battery to the negative of another. So both the red and black wire from this side go to the ground rail on my breadboard? If yes, then do I put the battery snap on the other side also and connect the red (pos.) and black (neg.) to their respective places within the circuit?
AND..since the positive and negative voltages need to be applied to both the Analog Multiplier and the Op Amp, how do I bus the power (especially the negative voltage).
Am I missing something? Is the negative voltage also part of the red (power) rail?
Sorry I'm so slow, but you guys are really helpful!!
Thanks a lot,
Brandon
optigrab929
PostPosted: Fri Nov 20, 2009 1:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Also, my switch configuration is a little loopy. I realize that it is a 6-lead DPDT switch, and I know how it functions, but I am having trouble translating what pin goes where within my circuit. I have a drawing that I found (attached) of a DPDT setup and I was wondering if it is correct, and if so, which pin is which compared to my schematic (A=1, B=2, etc.)??
Thanks so much again!!
Brandon
 Filesize:  4.11 KB
 Viewed:  25722 Time(s)
MirlitronOne
PostPosted: Thu Nov 26, 2009 4:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
1. Look carefully at Blue Hell's diagram above. It explains all your connection questions.
2. Do not use your polarity-reversal switch circuit, as this is not what you want to do (unless you want to let the smoke out). Treat your DPDT switch as a DPST double on-off switch. Use one half to switch the +V supply line, and the other half to simultaneously switch the -V supply. The joint ground connection can stay connected all the time.
Life is like an analogue sequencer. Twiddle the knobs to avoid boredom.
skylab76
PostPosted: Sat Dec 19, 2009 1:19 am    Post subject: Reply with quote  Mark this post and the followings unread
If anyone is interested in building a stripboard version of the AD633 based ring modulator, here's my diagram:
Posted Image
The layout is based on the Ray's schematic , of course:
I added extra amplification on the mod and carrier inputs, and I've constructed one based on my diagram. It works like a charm.
Here's the PDF (easier on the eyes).
http://www.fileden.com/files/2009/2/22/2334311/AD633_RM_SBLayout.pdf
Note: each grid horizontal grid line represents a trace and the intersections represents holes. It may not look perfect since I used Graffle to create the layout.
I'll append some samples this weekend.
MirlitronOne
PostPosted: Sun Dec 20, 2009 5:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for that contribution!
A suggestion: cutting all the traces across the board will significantly weaken the board. Just cut the traces where you need to - i.e. between the pins on the ICs - and then you won't need those extra link wires, either.
skylab76
PostPosted: Sun Dec 20, 2009 4:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the tip. Yes, in the end, the board seemed a bit "flimsier." That was my first one. I'm working on a layout for René Schmitz's "VCA-2" and I'll definitely follow that advice. That one is tricky since there are numerous cuts for the transistors ,etc.
Regards,
MirlitronOne
PostPosted: Sun Dec 20, 2009 5:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
It comes with practice, but it's worth the effort. Once you've had a bit of experience, it's way easier than making PCBs. Rock on!
Audio files: 373
PostPosted: Mon Dec 21, 2009 4:44 am    Post subject: Reply with quote  Mark this post and the followings unread
skylab76 wrote:
If anyone is interested in building a stripboard version of the AD633 based ring modulator, here's my diagram: (...)
Wow, cool! Thanks for this! Smile I've been waiting to try out a stripboard design, and this looks like a great, simple project.
/Stefan
View user's profile
skylab76
PostPosted: Mon Dec 21, 2009 9:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Stefan. I'm glad to share.
MirlitronOne, yes, I'm really enjoying the strip board method. I've rebuilt a few of my modules I constructed on peg board which were horrendous ( I found another module still on breadboard Laughing ). That was worth the time and now I'm looking forward on finishing a couple of new stripboard-based modules. If they're up to par, I'll post them somewhere central in the forum.
sync24
PostPosted: Fri Dec 17, 2010 7:39 am    Post subject: Reply with quote  Mark this post and the followings unread
skylab76 wrote:
If anyone is interested in building a stripboard version of the AD633 based ring modulator, here's my...
i know this i from a year ago, but thanks!
it's just what i was looking for Smile
http://sync24.wordpress.com/
http://soundcloud.com/sync24
knutolai
PostPosted: Sun Feb 22, 2015 1:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
I know this thread is very old, but do you still have that project pdf? I think the link is dead
