2010 Build Pictures
Page 8 of 24 [576 Posts]
Goto page: Previous 1, 2, 3, ..., 6, 7, 8, 9, 10, ..., 22, 23, 24 Next
PostPosted: Sat Apr 24, 2010 1:31 am    Post subject: Reply with quote  Mark this post and the followings unread
great module, sduck! i have one joystick here in my workshop waiting for some circuitry. what PCB did you use?
Posted Image
sduck
PostPosted: Sat Apr 24, 2010 7:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! It's from Flight of Harmony - http://www.flightofharmony.com/product-lines/choices/choices-joystick-module/ - he also sells "barebones" packs, which are just about everything but without a panel. Contact him about this - I may have bought the last 2 he had (at the time).
sduck
PostPosted: Sun Apr 25, 2010 8:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's a little quickie project I finished tonight -
DarkStarChaos repaneled front
DarkStarChaos repaneled back
DarkStarChaos repaneled profile
I built this one years ago from a kit 6-7 years ago, and it was one of the first things I ever built. I didn't really know what I was doing, and wasn't too surprised when it didn't work. I put it away, but worked on it again a few years later, but didn't get it going completely then either. Finally took it out again a few weeks ago, and looked it over, reflowed all the solder joints, and it worked! To celebrate, I designed this 1U motm format panel for it.
TekniK
PostPosted: Tue Apr 27, 2010 8:10 am    Post subject: Reply with quote  Mark this post and the followings unread
haibleJ flanger modul :
View user's profile
adambee7
PostPosted: Tue Apr 27, 2010 8:31 am    Post subject: Reply with quote  Mark this post and the followings unread
teknik you're the man. Razz Razz
TekniK
PostPosted: Tue Apr 27, 2010 8:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Curtis Electromusic 3330 Dual VCA
View user's profile
The Bad Producer
PostPosted: Tue Apr 27, 2010 11:42 am    Post subject: Reply with quote  Mark this post and the followings unread
great stuff (again!) Teknik....
-minus-
PostPosted: Sat May 01, 2010 8:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Still without a camera, so the same crappy phone photography to be expected from me... Finally managed to get this TR808 Kick (with large 20MM LED) into a box and off my dining room table!
 Filesize:  224.77 KB
 Viewed:  427 Time(s)
hway23
PostPosted: Sat May 01, 2010 8:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great work on the kick! Where did you find the schematic?
-minus-
PostPosted: Sat May 01, 2010 8:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! It's an Eric Archer clone:
http://ericarcher.net/2009/07/18/808-clone-projects/
It was kindly converted to a stripboard layout by slacker. You can find it here on the EM forum:
http://electro-music.com/forum/topic-37646.html&postorder=asc
hway23
PostPosted: Sat May 01, 2010 10:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
I might just have to build all three of those now. Very Happy
Audio files: 19
PostPosted: Sun May 02, 2010 2:08 am    Post subject: Reply with quote  Mark this post and the followings unread
ACHTUNG!
TekniK
PostPosted: Sun May 02, 2010 2:43 am    Post subject: Reply with quote  Mark this post and the followings unread
nice!
View user's profile
rjd2
PostPosted: Sun May 02, 2010 2:45 am    Post subject: Reply with quote  Mark this post and the followings unread
sduck and j.dilisio:
how are you guys doing the screening on your panels? they look great. i need to find a way to do good screening on metal, and i have yet to find a technique i like the results of.
adambee7
PostPosted: Sun May 02, 2010 7:06 am    Post subject: Reply with quote  Mark this post and the followings unread
I have the proto board layout of these but as there is now a strip board layout building will commence after lunchtime beer. Very Happy Very Happy
j.dilisio
PostPosted: Sun May 02, 2010 2:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
My screening is far from perfect. Some thin lines and letters don't come out, but since you asked,.
I'm burning my screens with two 250Watt bulbs hung about 18in from the surface. The stencil is held down with a sheet of glass and books underneath for support.
It takes around 12-13 mins.
The other important thing is when spreading the emulsion, try to get it as thin as possible. I use a squeegee on both sides. Then you can just use a hairdryer for a few minutes until it's translucent and you're ready to burn.
As for getting the ink to stay on the metal, I'm using a coat of clear rustoleum. Otherwise it scratches off.
You could try the oil-based inks like they use on street signs but it's a real pain to clean.
DRONEGOAT
-minus-
PostPosted: Sun May 02, 2010 5:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
When coating screens, a screen printing coating trough is the way to go. They aren't that expensive and give a near perfect thin emulsion coverage. Makes a big difference when washing out the stencil. Well worth the outlay, particularly if you are making up a lot of screens.
I have used a 400 WATT High Pressure Sodium lamp used for hydroponics in the past. The sun is a good alternative to a light bulb, and it's free!
sduck
PostPosted: Sun May 02, 2010 8:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
I use Front Panel Express for panels
TekniK
PostPosted: Mon May 03, 2010 12:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Fonik attenuverter ,vco
View user's profile
forbin
PostPosted: Mon May 03, 2010 5:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Can't quite make out the logo on the bottom of the VCO -- what is it?
TekniK
PostPosted: Mon May 03, 2010 2:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
View user's profile
TekniK
PostPosted: Mon May 03, 2010 3:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Dual SEM VCF,The coreldraw conversion (needed for the laser) fucked up my oberlogo vectors that i spend sooo much time on it Sad
View user's profile
adambee7
PostPosted: Mon May 03, 2010 6:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Do you ever sleep Teknik. Great stuff as usual. Very Happy Very Happy
TekniK
PostPosted: Thu May 06, 2010 1:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is an Awesome Modcan module,dynamicaly it completely blows away an 227e channel lol.
View user's profile
TekniK
PostPosted: Fri May 07, 2010 11:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Not yet finished,this is a MFB SEQ-1 sequencer
View user's profile
