Question on Boolean Sequencer
Page 1 of 1 [13 Posts]
Draal
PostPosted: Wed Jun 16, 2010 6:01 am    Post subject: Question on Boolean Sequencer
Subject description: using 556 as clock and vco
Hi all,
I'm at the planning stages of building the Boolean Sequencer from the schematic found on the Absolute Beginner's thread. Could I get similar results by replacing the 40106 as vco with the other half of a 556 chip? The first half of the 556 would be the clock source going into the 4040.
I have a bunch of 556's salvaged from those electronic critter deterrents.
bool.pdf
Let's give credit to Les Hall
 Filename:  bool.pdf
 Filesize:  28.25 KB
 Downloaded:  899 Time(s)
tjookum
Audio files: 26
PostPosted: Wed Jun 16, 2010 8:35 am    Post subject: Reply with quote  Mark this post and the followings unread
I think any squarewave signal might work but Im not sure about the buffers, maybe inventor knows more about this.
Why not go with a 40106? you only need 2 and they are really cheap.
Hunter S. Thompson
movies
noise
Draal
PostPosted: Wed Jun 16, 2010 11:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Re: Just buying the 40106: The thing is, A. I'm too damn cheap, B. My Rat Shack doesn't have it and C. I have a number of 556's just staring at me Laughing .
And whenever I buy online, I'm always forgetting something key to the schematic...what a drag. Bottom line is, if a part can be substituted, then I can finish a project sooner as opposed to waiting for the package to arrive.
If I get some time I'll breadboard it and see if it produces a neato effect.
Thanks![/quote]
tjookum
Audio files: 26
PostPosted: Thu Jun 17, 2010 11:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Very Happy I like your way of thinking, hacking away at free stuff. Friends are a great resource, one of mine gave me a hallmark greetingcard and it has proven a very good ldr driver. Good electronic parts these days are everywhere, the internet, dumps, outlets, scavenged toys and aplliances, you name it.
This is one im really interested in, it's a fan controlled synth using leds and ldr:
synth fan a from Gijs on Vimeo.
Hunter S. Thompson
movies
noise
Draal
PostPosted: Thu Jun 17, 2010 4:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
That is the first time I've seen a fan synth - just blew my mind! Yeah, sometimes you can score some usable parts from the strangest places and devices. I'm currently taking some cmos chips out of a video converter box that took off the macrovision of my purchased vhs tapes back when they ruled the format land. No use for it now but to make strange sounds Laughing .
adambee7
PostPosted: Thu Jun 17, 2010 8:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
that's nuts. I wonder what larger fans would be like. What you were saying about hallmark cards, Unklekrunkus is experimenting with such an ic. He has got a thread in the forum about it. Very Happy Very Happy
Rykhaard
PostPosted: Fri Jun 18, 2010 4:31 am    Post subject: Reply with quote  Mark this post and the followings unread
K. Here's another angle:
The fan, is interupting the light flow between the LED and the unit that is receiving the LED's light. (Photo resistor; photo transistor; what have you; whatever Wink ).
Take that same idea, from a computer MOUSE! That, gives you X and Y movement control! Never mind the mouse's processing circuitry and all of that crap - hoping you've rushed down to the local supplier of CHEAP computer parts - rip all of the mouse's circuitry and out and wire up the internal LEDs with appropriate resistor values for the input voltage to them. (Or - check the internal circuit board, for the resistor value that's hooked up to the mouse's LEDs / light sensors)
Take your output from the light sensors that are on the other sides of the LEDs, and those are your X, Y triggers for the rest of your circuit.
Move the mouse around and there you are. Smile
If you're lucky - find yourself an RC4151 (or is it RC4152?) Frequency to Voltage converter chip (NOT the Voltage to Frequency chip) and there you have - the mouse moving around spitting out 2 voltage ranges.
If all that I just typed sounds too confusing - please blame my lack of sufficient coffee intake, thusfarly this morning. Surprised Laughing (And I could then re-explain.)
Inventor
Audio files: 270
PostPosted: Fri Jun 18, 2010 7:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi folks, just caught this thread and thanks for building my design and especially for being creative in modifying it. You can indeed use half of a 556 as the VCO. You could either starve the part as I did to create a cheezy VCO and / or use the control input to vary the frequency. I'd experiment with both options since you're breadboarding and thus you can do that. Best of luck and please report back with your results.
Les
p.s. fan synth - way cool!
Draal
PostPosted: Sat Jun 19, 2010 5:24 am    Post subject: Reply with quote  Mark this post and the followings unread
I tried out the other half of the 556 as a vco and it did offer some interesting noises and beats. But I then tried it as drawn on Inventor's schematic and I am even more pleased. More clearly defined sequences and even greater range in my bread boarding tests. I definitely need to solder this bad boy up but I may add a couple extra logic chips to see how that flies. (I'm a minimalist though, so don't hold your breath Laughing ).
Currently it has half a 556 clocking a 4040. 8 of the 4040's inputs are connected to a 4081 AND Quad 2 Input chip. The 4 outputs from the 4081 get summed out with resistors and then buffered into a 40106 vco as described in the schematic.
I'll try to post a sound file this weekend!
RE: mouse control: Thanks for the tip Rykhaard; I have 2 Apple Computer mice sitting pretty in my project (junk) box. Time to deconstruct Twisted Evil
Draal
PostPosted: Sat Jun 19, 2010 12:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's a quick n dirty sound sample of my Boolean Sequencer with no effects added and just some occasional knob twisting to vary the rate. I used a fixed resistor instead of a pot for the 40106 and the clock is using a 25k linear pot. The 0.047 cap was replaced with a .05 cap as well. Sorry if its a bit high on the pitch right now - that'll get tweaked:lol: .
Once I play around with some more resistor and cap values, I'm going to solder it up. Definitely a cool sound generator to contrast with the arp I built recently.
Bool.mp3
 Filesize:  1.96 MB
 Duration: 2:08
 Viewed:  2190 Time(s)
tjookum
Audio files: 26
PostPosted: Sat Jun 19, 2010 12:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
really impressed, especcially the middle part. sounds like a lot of fun Smile
Hunter S. Thompson
movies
noise
Inventor
Audio files: 270
PostPosted: Mon Jun 21, 2010 1:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes, i really like those long sequences that vary but stay loosely on a main theme. One of my better rediscoveries actually... Thanks Draal for building it and sharing your music.
Les
Draal
PostPosted: Mon Jun 21, 2010 1:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the schematic Inventor Very Happy . So far my lunetta project has an Arp and the Boolean Sequencer; this is starting to get addictive. I'm really liking these 4040's for pattern generation, and I'm happy I have a spare to experiment with.
