Dadooronron Ron
G2 patch files: 21
Rix
Joined: Aug 08, 2004 Posts: 83 Location: Breda, the Netherlands
G2 patch files: 25
Posted: Sun Feb 06, 2005 2:21 am Post subject:
Re: Piano for the masses |
Not bad at all!
So far I think it is the best synthesized piano patch I heard on the Nord.
Knowing how difficult it is to synthesize a piano sound, and being spoiled with Rolans stereo sampled grand cards...
It is a bit nosy though, so if you would suppress the mid range and enhace the low and high, it would even be better.
Richard |
Zebulon
Posted: Sun Feb 06, 2005 2:25 am Post subject:
Cool
It sounds like a lo-fi, baby piano...Thanks, I like it very much ! |
Dadooronron Ron
G2 patch files: 21
Posted: Sun Feb 06, 2005 8:41 am Post subject:
Thanks for looking at it. It does sound a bit nosy, doesn't it?
Also, I can't seem to get rid of the buzzy "no-piano-at-all"sound in the lower regions. Very frustrating. So please improve. I'm sure that many of you will have great ideas that I will never think of.
By the way, did you notice the reverb module just before the output? It should be on. (Duh...) |
Joined: Jan 31, 2003 Posts: 18553 Location: Durham, NC
Audio files: 267
Posted: Sun Feb 06, 2005 12:52 pm Post subject:
Quite an interesting patch. Pretty simple but in the mid an upper registers it really does sound like a piano. I was expecting an electric piano, not an acoustinc. The lower registers sound s big like a bassoon, though. Still, mixed in with a bunch of other sounds in an ensemble, this would be pretty convincing. Thanks... _________________ --Howard
my music and other stuff |
Zebulon
Dadooronron Ron
G2 patch files: 21
jamos
Joined: Jun 01, 2004 Posts: 517 Location: Eugene, Oregon, USA
G2 patch files: 44
Posted: Sun Feb 13, 2005 11:35 am Post subject:
This is undoubtedly the best piano that I've heard on the G2, but it still n.eeds work. I especially like the way you've implemented the sustain pedal
My tin ears tell me that this sounds like a real piano covered by a blanket.. which makes me think that judicious EQ would solve a lot of the problem; but I'm not good enough with EQ to be able to fix it. So far. And the nasty string oscillator noise is hard to tame.
So in other words, good job! |
jamos
G2 patch files: 44
Dadooronron Ron
G2 patch files: 21
Posted: Mon Feb 14, 2005 1:56 pm Post subject:
Zebulon, I finally listened to you chorussed version and I must admit that ,although it's very much not "au naturelle", it does sound a lot better.
Especially this dreaded lower region benefits from the chorus. So far, I think your piano is the most useable.
Jamos, you're right. The hammer pulse has a great effect on the sound.
In one of my "lab-testing-versions" I've also tried some more elegant string-damping (instead of the envelope thingie) but it ate too many voices.
I do feel the key thing to a decent piano sound is the wet filter (as described in J.Clark's Nord Modular Book) which gives this patch it's woody feel. Unfortunately the sound coming out of it is a bit dull.
But we keep working on it, don't we?
Thanks guys,
Ron. |
