Coming up on Radio 1 at
Modulator ESP on Adventures In Sound
Echo base dual delay module
Page 1 of 1 [11 Posts]
Audio files: 163
PostPosted: Sun Dec 19, 2010 5:15 pm    Post subject: Echo base dual delay module
Subject description: 2 PT2399 pcb's with mods & cv input / lfo mix
Hi Smile
Just finished designing the panel for my 2 ECHO BASE pcb's.
I've got 1 board populated and have added the clean kill / lfo kill / lfo wave shape pot / run away feedback / cv input .
for the cv input i was experimenting where & how and got a good result with an attenuated cv connected to the wiper of the lfo shape pot mod .
My feedback pot is very tame at maximum , i'll try to get a bit more soon.
initial tests were overloading the fx when connected to my modular ...so... i built a vero board CGS stopbox adapter... works a treat now , one more to build up & get the panel done (lazer printed vinyl sticker) , should have it all running during the Xmas holidays Smile
The wide space on the main controls is allow mounting the pots on the reverse side of the pcb to get the vertical layout i wanted Smile
 Filesize:  55.46 KB
 Viewed:  802 Time(s)
slacker
PostPosted: Mon Dec 20, 2010 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very cool, look forward to seeing the real thing.
Out of interest what voltage are you running it off?
Audio files: 163
PostPosted: Mon Dec 27, 2010 5:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Slacker Smile
i made a small vero board circuit with 12v +/- incomer to supply the CGS stompbox adaptor then through a +9v reg to supply the echobase Smile.
alu panel drilled & stickered , slight colour banding on the blue print on the panel but i'm glad just to get them done Smile .
i've been trying some things for my weak feed back and realised the run away F/B mod i done cuts the 20K out the circuit till i switch the run away on , so.... tracing the connections i've used a SPDT switch with the other pole connected via a 100K res. to the old 20K board thru hole , see diagram below , now i get either controlled feedback at 70% pot travel or max feedback , fab Very Happy Very Happy Very Happy, all will be built up over the next few days.
 Filesize:  45.19 KB
 Viewed:  29799 Time(s)
 Filesize:  24.89 KB
 Viewed:  879 Time(s)
Audio files: 163
PostPosted: Thu Dec 30, 2010 4:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Finished ....Smile Smile....
i'm really happy with these delays , they work great with the usual sequency stuff i do for my music.
Also great for FX whooshes & zaps with a high pitch S&H controlled VCO run through them Smile.
My bypass led's were dim with a 50K load res , better with a 10K but with a 2K the internal Lfo stopped working so back to 10K .
I had breadboarded another type of PT2399 delay design a few years ago with not very good results , these , however , hooked up with Ken Stones stompbox adapter circuit work well with my diy modular ( and free up my 19" rack delays for the Juno's Smile ).
after reading previously about pots wired back to front i double checked with a continuity meter the minimum or ground legs of the pot connections and yes the pots get soldered to the track (back) side of the pcb .
listen to Epicyclus on the New Years Eve electro-music concert , Friday 19:30 GMT to hear them , i'll post some short sounds here after the weekend , thanks for having a look.
Dave W.
Epicyclus & Orchard.
 Filesize:  120.07 KB
 Viewed:  781 Time(s)
 Filesize:  126.56 KB
 Viewed:  828 Time(s)
Audio files: 163
PostPosted: Mon Jan 10, 2011 12:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
sounds.......
Hooked a vco to a h/pass filter thru a vca with lfo's & a sequencer c.v. controlling delay time later in the mp3, Smile
vco's + lfo's thru Echobase.mp3
 Filesize:  2.48 MB
 Duration: 2:42
 Viewed:  2390 Time(s)
Taylor
PostPosted: Tue Jan 18, 2011 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sounds and looks awesome Dave! Really pleased to see the boards in a modular environment. Slacker's circuit is so versatile that I find new fun things it can do all the time.
How have you done the CV for time mod? Just sending your CV to the base of the modulation transistor?
musicpcb.com
strategy
PostPosted: Tue Jan 18, 2011 10:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, do tell - would like to add an input to the standalone version I intend to build!
community-library.net/strategyhome.htm
sneakthief
PostPosted: Wed Mar 16, 2011 11:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Skrog Productions: do tell how you implemented your cv control Smile
Sneak-Thief - raw electrofunk
Audio files: 163
PostPosted: Sun Mar 20, 2011 3:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi , i added the cv in via an attenuator to the wiper of the lfo amount pot , best results if you kill the internal lfo with the lfo kill switch mod to run the external cv on it's own , you may need a resistor in series with the attenuator ground pin (something like a 10K) as the lfo amount wiper connection didn't like the internal lfo getting grounded by the cv pot when set at lowest , counter clockwise .
experiment a little to get results you like Smile
cheers.
philoop
PostPosted: Mon Nov 28, 2011 5:10 pm    Post subject: echobase delay
Subject description: cv
i see your extension board
any schematics?
and how to make feedback cv controlable
and a crossfeed?
Deploying dual-wavelength fNIRS, we interrogate 16 locations in the forehead when eight able-bodied adults perform deception and truth-telling scenarios separately.
sneakthief
PostPosted: Tue Feb 14, 2012 2:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Re. stereo Echo Base crossfeed:
Success!
I took the feedback output (CW pin of the feedback pot) of the Left delay pcb, sending it to a non-inverting opamp buffer which then goes to a 20KA pot, and finally to a 20k mixing resistor that goes in the connection between the 4n7 capacitor and the 20k resistor that's on the pcb. (And the same for the other side.)
I used this buffer schematic and biased the input with the 5V output. I also put a 100n cap after the 10uF (very important!):
Posted Image
http://www.muzique.com/lab/buffers.htm
Also, the CV-input works well. I put a diode between the cv-input jack and the ground to remove all negative CV voltages. I connected it directly to the base of the BC560/2N5087 with a 20k resistor.
Please note: the Echo Base will invert your audio signal because it uses one inverting opamp and a non-inverting opamp.
