nerdware
Posted: Fri Mar 04, 2011 4:27 am Post subject:
| ryktnk wrote: | | Sorry for the confusion. |
No problem!
| Quote: | | The portamento switch option, could be installed on any OS version, as it just takes a signal from the POTS bus to some Portamento switches. |
Aha! I really should check the docs for V2.0.
| Quote: | | The V2.1 OS has a software programmable portamento, so can be used without Portamento switches. |
As I have, or will soon have, a panel with holes for the switches, I may use the switches anyway. Thanks!
It does. Thanks!  _________________ http://soundcloud.com/nerdware/
"render unto digital what is due to digital, render unto analogue what is due to analogue" |
emdot_ambient
Joined: Nov 22, 2009 Posts: 667 Location: Frederick, MD
Posted: Fri Mar 04, 2011 10:41 am Post subject:
Yes, thanks, that does clarify things. I figured that was the answer. After looking at the port daughterboards, I couldn't see any reason the switches wouldn't work with V2.1 _________________ Looking for a certain ratio since 1978 |
nerdware
Posted: Fri Mar 04, 2011 11:58 am Post subject:
My panel came today!
The switches I got with the PCB and PIC fit perfectly, but I now need to source all the other panel components. None of the LEDs, push buttons, or 2-position toggle switches I have already fit the holes. Nevermind, that's all part of DIY.
Thanks, everyone! _________________ http://soundcloud.com/nerdware/
oozitron
Posted: Sat Mar 05, 2011 2:43 pm Post subject:
I am going to connect both the CV slider and the portamento switch to the "POT" connection(s) on the PCB. Would problems result if I was to connect an additional CV pot/slider so I could have *two* variable CVs for each step? (one for pitch, one for the VCF)
Drew, really wanting to get this beast done  |
julian
Posted: Sun Mar 06, 2011 5:17 pm Post subject:
| nerdware wrote: | My panel came today!
The switches I got with the PCB and PIC fit perfectly |
Of course they do : ) That was one of the things that i did not like about the .fpd file that was floating about. Im not suggesting that you do, but, if you were to read back through the thread, youll notice that i aqquired some cutters especially to optomise the slide switch holes, to make the panel as neat as possible.
| nerdware wrote: | ...but I now need to source all the other panel components. None of the LEDs, push buttons, or 2-position toggle switches I have already fit the holes. Nevermind, that's all part of DIY.
The LED holes should be cut for 3mm leds to push into tightly. Or you can drill to 5mm, using the 3mm hole as a pilot.
The pots holes are cut for ALPHA Tiwan pots (as used on most of the eurorack systems) but, again, can be opened up for other pots. If youre in the UK (which, of course, you are) then Rapid sell them cheaply. Mouser carries them in the states, as do many others.
The switch holes are cut for SCI push button. A brand that i hoped woud, again, be availible world wide. The part number is listed somewhere in this thread. Again, Rapid, and loads of other distributors will sell you these.
The panels were designed and cut with both attention to layout and with ease of sourcing components in mind : ) _________________
For custom cnc engraved panels see - http://www.thebeast.co.uk/cnc/
julian
Posted: Sun Mar 06, 2011 5:20 pm Post subject:
ps.
It looks like i got further than i thought with the rotary switch panel layout, so, if anyone is keen on these, if they want to let me know, ill see if i cant finish off the panel. _________________
nerdware
Posted: Mon Mar 07, 2011 3:19 am Post subject:
| julian wrote: | | The LED holes should be cut for 3mm leds to push into tightly. Or you can drill to 5mm, using the 3mm hole as a pilot. |
Thanks for the size info. It confirms that I have 5mm LEDs and I need 3mm. That'll help.
| Quote: | | The pots holes are cut for ALPHA Tiwan pots (as used on most of the eurorack systems) but, again, can be opened up for other pots. If youre in the UK (which, of course, you are) then Rapid sell them cheaply. Mouser carries them in the states, as do many others. |
I tried the 16mm BI Alphas I have for another project, and the threaded part of the shaft doesn't quite fit. Maybe my dad can fix that.
| Quote: | | The switch holes are cut for SCI push button. A brand that i hoped woud, again, be availible world wide. The part number is listed somewhere in this thread. Again, Rapid, and loads of other distributors will sell you these. |
Again, thanks. That's very helpful.
| Quote: | | The panels were designed and cut with both attention to layout and with ease of sourcing components in mind : ) |
Thanks.  _________________ http://soundcloud.com/nerdware/
ryktnk
Posted: Mon Mar 07, 2011 10:02 am Post subject:
| oozitron wrote: | I am going to connect both the CV slider and the portamento switch to the "POT" connection(s) on the PCB. Would problems result if I was to connect an additional CV pot/slider so I could have *two* variable CVs for each step? (one for pitch, one for the VCF)
Hello
Sorry,it is not so easy to add a 2nd CV without an additional output stage.
Thisconsists of the S&H, and omp-amp buffer circuit of T15 and IC4.
-ryk |
emdot_ambient
Posted: Mon Mar 21, 2011 6:32 pm Post subject:
Dunno...is this a crazy idea for a dual M-185?
Each of the stage CVs is a Push/Pull switching potentiometer and instead of SP8T rotary switches, it's using these tiny little DP4T rotaries. The with the CV pot switch pushed in, it sets the 4 positions to only the even numbers of pulses per stage and pulled out to the odd ones....so, when one's pushed in the Stage Count Control can only select 2, 4, 6 or 8 pulses per stage. Pulled out, only 1, 3, 5 and 7 pulses are available.
I've got enough sliding switches for like 1.5 modules, but I want to do a 19" wide, 3U high, dual sequencer (with 1/4" jacks)...and the switches are impossible to find. I don't like the idea of just using pots for the Stage Count Control or Gate Mode functions, and all the SP8T rotary switches I've seen are way too big or way too expensive.
Oh...these also use 2 Barton Music Circuits Simple Quantizers with custom scales on them. You can see them in the bottom right of each sequencer. The CV out automatically goes through the quantizer. You can turn quantization off, but you can't use it for other modules as there is no CV In (and I don't have panel space for adding it).
| M.Synths Dual M-185 Sequencer |
112.61 KB |
| Viewed: |
481 Time(s) |
emdot_ambient
Posted: Tue Mar 22, 2011 6:43 am Post subject:
Well....did some measurements and took a second look at the FPD and I think I can actually fit the larger SP8T switches in place of the DP4T Stage Count Control switches. It's a tight fit on the back panel, but doable. That will also free up some vertical space and will allow me to add text to the Stage Count Control (I'm just calling it # Pulses) and Gate Mode functions, as well as using the DPDT pot switches to turn on/off portamento. _________________ Looking for a certain ratio since 1978 |
emdot_ambient
patchdub
Posted: Fri Apr 01, 2011 11:44 pm Post subject:
| julian wrote: | ps.
It looks like i got further than i thought with the rotary switch panel layout, so, if anyone is keen on these, if they want to let me know, ill see if i cant finish off the panel. |
i would love to get a rotary panel if you get one done.
i have a version 2 board. _________________ www.patchdub.com |
dnigrin
Posted: Sat Apr 02, 2011 8:13 am Post subject:
Just a quick note to be sure that those following this thread also saw my post about my software recreation of Ryk's awesome sequencer:
http://electro-music.com/forum/topic-46930.html
Many thanks to Ryk who helped guide me through its creation, testing, etc..!
Dan _________________ Dan Nigrin - Defective Records
CycliC, M185 & Klee Sequencers / MC-202, MC-4 & DSX Hacks / Audio Plugin & General MIDI Players
http://defectiverecords.com |
oozitron
Posted: Wed May 04, 2011 8:57 pm Post subject:
sorry (deleted) Last edited by oozitron on Sat May 07, 2011 4:20 pm; edited 3 times in total |
emdot_ambient
Posted: Thu May 05, 2011 8:51 am Post subject:
I don't have a lot of experience building/debugging...so aside from making sure that the power is connected correctly, and that all the ICs are seated in the correct direction...dunno. Hopefully someone will chime in with real advice  _________________ Looking for a certain ratio since 1978 |
oozitron
Posted: Thu May 05, 2011 10:15 am Post subject:
sorry (deleted) Last edited by oozitron on Sat May 07, 2011 4:19 pm; edited 3 times in total |
sduck
Posted: Fri May 06, 2011 1:20 pm Post subject:
You should probably ask in a different thread. Start another one. I'm pretty sure you don't mean to hijack this thread - that sort of thing is frowned upon.
Edit - Oozitron, I wasn't referring to your posts. Actually, now that the off-topic post has been removed, my post (this one) can be removed too...? Last edited by sduck on Sun May 08, 2011 8:53 pm; edited 1 time in total |
Former site admin
Joined: Apr 03, 2004 Posts: 24863 Location: The Netherlands, Enschede
Audio files: 353
Posted: Fri May 06, 2011 1:34 pm Post subject:
| And it is a duplicate post too .. which is frowned upon as well ... will delete it. |
modularplanner
Posted: Sun May 08, 2011 4:26 pm Post subject:
Just trying to debug my build here. This thing was more confusing than the Klee I built to wire up
CV output is working fine.
Sequencer is running.
Start/Stop doesnt work, always 5V on IC3 pin 1, D4 is correct orientation.
Reset works
next/prev works.
Gate Mode is acting odd. If Stage 1 is set to Gate Off it still plays, the rest of the Stages work ok on this setting.
Step Count seems to be repeating for the correct amount of time but doesnt seem to be sending the actual Gate outputs to my ADSR Gate In. it only sends the first gate of the stage. I have set the Mode to position2 [multiple gate]. E.g if I set the stage count to 3 it will just send a continuous high gate for the duration. IC2 is a HCF4069UBE
Only thing I know for sure I've ballsed up is the LED ground, I didnt connect the cathode to the LED GND but instead the regular ground. So i know the LED is not dimming for the extra gates per stage.
What should I be checking to fix the step counts? _________________ Eurorack Modular Planner |
oozitron
Posted: Sun May 08, 2011 7:05 pm Post subject:
Aren't the HCF chips the +/- 5v versions of the regular (+/- 15v) chips?
Don't know what voltage is sent to that chip... might want to check (?)
Drew |
modularplanner
Posted: Mon May 09, 2011 12:29 am Post subject:
Edit: Fixed it, stupid moron wiring issue wired the stage one mode "ground" wire to MD, didnt even have an MD cable . All working now, awesome sequencer Ryk
I'm getting 5V on pin 14 of the 4069
comparing the datasheets of HCF4069UB and CD4069UB I cant see any differences apart from the HCF version being listed as "intermediate temperature range". _________________ Eurorack Modular Planner |
emdot_ambient
Posted: Mon May 09, 2011 7:50 am Post subject:
Watching this thread is both anxiety causing and elating.
Anxiety causing because of the people posting build difficulties, and making statements like: "This thing was more confusing than the Klee I built to wire up!"
I've avoided even looking at the Klee sequencer threads because it seems like a huge project (but a cool one).
Elating, though, because it almost always seems like the problems turn out to be wiring issues. And the inevitable "it's working!" posts also confirm these are great sequencers.
I'm slowly getting my boards all stuffed. Have a few more components on the way, then it'll only be a matter of ordering the panel and having the time to work on it.  _________________ Looking for a certain ratio since 1978 |
modularplanner
Posted: Mon May 09, 2011 10:11 am Post subject:
It's worth effort, I only think the Klee was easier because it was so well documented for newbie builders like myself. This was the first time I had to interpret a wiring diagram. It's not "that" bad, I think it was worst for me because I built the whole thing into a 42HP eurorack blank, very tight for space.
If you need picture of the wiring just let me know, my work is a right mess but it might help someone
The only thing I need to fix at the moment is the start/stop not stopping when pressed, that's not too bad because I use an external clock source most of the time anyway. _________________ Eurorack Modular Planner |
whomper
Posted: Mon May 09, 2011 11:21 am Post subject:
If you ever get the play feature to stop upon pressing the button, do let me know. It is the last thing that is still left to do for me for my two sequencers. Haven't gotten around to fix it although have tried...
Great sequencers! Wished they had the ability to extend one another to get 16 steps. _________________ Erez Yaary
Home Page: http://www.yaary.com
Buy my CDs at http://www.mellowjet.de |
emdot_ambient
Posted: Mon May 09, 2011 12:38 pm Post subject:
| whomper wrote: | | ...Wished they had the ability to extend one another to get 16 steps. |
Yeah, that would make them totally awesome, especially since I'm doing 2 into one panel. _________________ Looking for a certain ratio since 1978 |
