Brief maintenance shutdown at 10:00 PM EST - 0400 UTC
Now live on Radio 1
Euclidean rhythms
Page 1 of 1 [8 Posts]
Former site admin
Audio files: 353
PostPosted: Sat Nov 10, 2012 6:05 pm    Post subject: Euclidean rhythms Reply with quote  Mark this post and the followings unread
The patch notes read :
Euclidean rhythms
See articles:
http://ruinwesen.com/blog?id=216
http://www.hisschemoller.com/2011/euclidean-rhythms/
and paper :
http://cgm.cs.mcgill.ca/~godfried/publications/banff.pdf
Set an Euclidean rhythm with the module labeled X-1, and Y-1. To set E(5,7) set X-1to 4 and Y-1 to 6 - so always one less than the values in E(X,Y)
X should always be less than Y.
This patch uses the partial generators to to make a derived rate from a basic rate ., for E(X,Y) the derived rate is X / Y times the basic rate, this then samples the basic rate to make the rhythm.
I think I got the math right ... but it does some nice stuff anyway Wink
The idea started in the chatroom .. some earlier attempts were in http://electro-music.com/forum/topic-55545.html
This patch will run in the demo software.
An interesting variation can be made by inserting several X-1 modules set to different values that then get selected by a multiplexer module.
euclidean_rhythm_01.pch2
Euclidean rhythm generator, see forum post or patch notes for more info.
 Filename:  euclidean_rhythm_01.pch2
 Filesize:  2.19 KB
 Downloaded:  4661 Time(s)
Audio files: 373
PostPosted: Sun Nov 11, 2012 3:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice and very compact! This can be useful.
iPassenger
G2 patch files: 78
PostPosted: Wed Nov 14, 2012 1:57 am    Post subject: Reply with quote  Mark this post and the followings unread
This patch is great, not sure i totally get it but I love the way it uses the partial gens to get the ratios.
My question:
Do you have any ideas about how we might be able to get to work with synced clock signals.. so that it could be used in ideas driven by midi clock rather than an lfo?
I tried using my clock multiplier patch to get the lfo speed from the clock output using the pitch detection module but it wasn't very smooth..
Any other ideas?
Still its a great tool for getting rhythm into drone weird modular patches.. will definitely be using it.
iP (Ross)
Former site admin
Audio files: 353
PostPosted: Wed Nov 14, 2012 9:58 am    Post subject: Reply with quote  Mark this post and the followings unread
I guess you could set the LFOs to [BPM] mode? I'm not sure there I hardly ever use MIDI sync, and am not sure how the modulation then works ... if it works you then might want to connect the resets to a clock module instead of the constant 64 they are tied to now .. the other signals connected to that 64 module should stay connected though. Or maybe even the clock multiplication rate, [CLK] mode that would be.
iPassenger
G2 patch files: 78
PostPosted: Thu Nov 15, 2012 5:26 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, i'll have another mess and see what comes.
iP (Ross)
iPassenger
G2 patch files: 78
PostPosted: Sat Dec 01, 2012 10:01 am    Post subject: Reply with quote  Mark this post and the followings unread
A synced one.
EuC.pch2
 Filename:  EuC.pch2
 Filesize:  2.03 KB
 Downloaded:  4989 Time(s)
iP (Ross)
Former site admin
Audio files: 353
PostPosted: Sat Dec 01, 2012 12:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool
Former site admin
Audio files: 353
PostPosted: Sun Jun 29, 2014 3:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
For some more info see here
Turns out that its related to Bresenham's line drawing algorithm, which makes an algorithmic implementation a lot easier for some programming languages (easier than in the original paper).
And maybe even a G2 implementation could be made out of that ...
