Coming up on Radio 1 at
Modulator ESP on Adventures In Sound
Most simple VCF on earth
Page 2 of 2 [50 Posts]
Goto page: Previous 1, 2
2kohm
PostPosted: Mon Mar 25, 2013 11:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
hope to hear and see it ´Smile
Shop
Videos
Stromakustik.de
umschmitt
PostPosted: Thu Mar 28, 2013 12:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sounds nice !
Do you have a schemo with the values you used for this filter ?
(apart from the blue abstract picture you posted)
::U::N::S::C::H::N::E::L::L::
2kohm
PostPosted: Fri Mar 29, 2013 12:48 am    Post subject: Reply with quote  Mark this post and the followings unread
THX,
I used the schematic from Page 1 Off this Topic.
And the Second Breadboard schematic.
P.s ich komme aus München Wink
Shop
Videos
Stromakustik.de
2kohm
PostPosted: Wed Apr 10, 2013 6:04 am    Post subject: sound demo Reply with quote  Mark this post and the followings unread
here is my version of the filter
9V-VCF_TEST.wav
9v powered super simple vcf
 Filesize:  8.41 MB
 Duration: 0:50
 Viewed:  4637 Time(s)
Shop
Videos
Stromakustik.de
Infrablue
PostPosted: Sun Apr 14, 2013 1:00 am    Post subject: Reply with quote  Mark this post and the followings unread
For simple filters, I really think this one may take the prize.
I think I want to make an outboard version of this to route synths through for live performance.
www.youtube.com/watch?v=qecPQ0FB-64
beep
PostPosted: Sun May 05, 2013 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
if I would put two of this in series, calibrating the cutoffs and using a stereo pot for resonances, will I have 24db/oct or will the cutoff cvs respond
too differently? should I build 200 and then select a matched pair? :DDD
reflex
PostPosted: Mon May 06, 2013 12:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've got a version of this circuit running with a couple of 0.01uF caps and a 220k resistor across the op-amp. The cutoff works beautifully, but adjusting the resonance knob only alters the sound for the last 1/8th of the knob travel (it's a 10k pot). I've attached a sample of my filter in action.
Does anyone have hints or tips for scaling the resonance range?
twin-t bass.mp3
Twin-t LPF driven be dual digital oscillators (PWM).
 Filesize:  1.46 MB
 Duration: 0:38
 Viewed:  4148 Time(s)
the19thbear
PostPosted: Tue May 07, 2013 2:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Way cool!
reflex
PostPosted: Fri May 10, 2013 10:55 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, here's what I've discovered after some experimentation:
My version of the circuit has 0.01uF poly caps and a 272K resistor around the op-amp, running on a 9V power supply. There is a slight but audible difference between the poly caps and cheap ceramic ones.
The choice of op-amp makes a significant difference in audio quality.
LM324 (quad): Nice filter cutoff throughout the filter range, the resonance knob will self-oscillate if turned past about 90%, below that the resonance is a bit thin. There's a bit of unfiltered "sparkle" in the high end. Will operate at 5V, but I hear significant distortion/clipping.
LM358 (dual): Sounds the same as the LM324 (not really a surprise). Self-oscillates when resonance is turned up full.
TL074CN (quad): Resonance knob doesn't self oscillate when cranked, sounds similar to the audio sample I posted. HOWEVER, the cutoff has an audible bump as it's turned all the way down. This was a showstopper for me.
TL071CP: The winner. Similar resonance response to the 074, but the cutoff is much smoother throughout the full range. Not sure why there's such an audible difference between the 071 and the 074, given the similar chip specs.
I've breadboarded a little voltage doubler circuit that scales 0-5V cv from my microcontroller's DAC to 0-9V to allow full range control of the filter cutoff.
PostPosted: Fri May 10, 2013 11:52 am    Post subject: Reply with quote  Mark this post and the followings unread
That is VERY interesting.
I have a Thomas Henry VCF from AS21C which is supposed to self-oscillate, but does not. Tried a bunch of ideas from Dave Dixon on improvements to the circuit, still does not self-oscillate.
Guess which Op Amps I used? Smile
I wonder whether there is even variation across batches, since the original specs TL074's....
reflex
PostPosted: Fri May 10, 2013 12:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I'm deeply suspicious of differences across batches and between the various production runs.
Have you tried LM324s in your TH VCF? It would be really interesting to see how it compares (might be awful, might be gold).
PostPosted: Fri May 10, 2013 1:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well that's pretty much exactly what I'm getting at. I hadn't tried, but I plan to. Either 324's or any of a number of other quad op amps with compatible pinouts (LF444 comes to mind, though I only have 1 left).
PostPosted: Fri May 10, 2013 10:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, both the LM324 and the LF444 made it quite a bit more aggressive, but the high end of the pot (past about 3 o'clock) breaks up and sounds like crap, and it still doesn't really self-oscillate in any manner that tracks the frequency knob.
Of course along the way, one of the sockets on my cheap leaf-spring socket gave up the ghost, and I had to troubleshoot that too. Nothing like stuff you built before you realized particular pitfalls Smile.
But in the end the TL074, while not as aggressive, has the best range with the pot, and since none of the options self oscillate, I've gone back to it.
jackdamery
PostPosted: Wed May 29, 2013 5:23 am    Post subject: Reply with quote  Mark this post and the followings unread
What is the function of the diode in the OP's circuit?
reflex
PostPosted: Wed May 29, 2013 1:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
The diode works as a voltage controlled resistor.
See richardc64's comment here: http://electro-music.com/forum/post-348389.html#348389
beep
PostPosted: Thu May 30, 2013 12:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Breadboarded it. It's a very nice filter. Had a few problems in the beginning,
cause I used LM741 instead of TL071. Changed a resistor.
If I connect a LM386 Little Gem amplifier, it oscillates. the more gain, the more oscillation. connected to soundcard input, there was no oscillation. Is this because of the load of the 386 amp?
Tried to buffer the output with a simple voltage follower,
but that didn't help.
Had a lot of fun with it. two videos. first one with little gem speaker output,
second one with soundcard input, but little gem still connected.
controlled by lfos, sample&hold and simple envelopes.
Simple Saw VCO as input.
Is the future obsolete?
Ray_Ketamu
PostPosted: Thu Aug 13, 2015 7:03 am    Post subject:   Reply with quote  Mark this post and the followings unread
hi!
i know this post seems very dead! but i made a stripboard version of the vcf for a microcontroller based application and i want to hear your feedback. Any mistakes?
i am pretty new and not very into electronics. only getting started Smile
 Filesize:  292.97 KB
 Viewed:  2175 Time(s)
Sound: https://soundcloud.com/stream Art: http://ketamuworld.blogspot.de/
wackelpeter
Audio files: 10
PostPosted: Thu Aug 13, 2015 9:41 am    Post subject: Reply with quote  Mark this post and the followings unread
i think it would be better to post schematics instead of a layout as most of us (especially myself) are a bit lazy...
schematics are better to look at and see to see if something looks suspect..
first of all i would add in Input resistors for all external Inputs... and then i'm not sure if a 741 will run on 9V... i think it's supposed to be run on a + and - supply... the LM3900 or LM324 can be run on single supplies i know...
but maybe i'm talking nonsense and the 741 will do the job... well as i said i'm not sure...
Ray_Ketamu
PostPosted: Thu Aug 13, 2015 10:09 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for the reply. its the conversion of the picture of breadboard on bottom first page of this thread.
resistor to input. check.
i will check the ic issue.
samsam
PostPosted: Mon Jun 19, 2017 9:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi everyone,
I'am trying to breadboard this vcf and i'm having some difficulties as my oscillator (made from cd40106 chip) seems to be sending some signal to the vcf even when the output of my oscillator is not wired to the input of the vcf.
Have you experienced this problem or do you have any workaround or explanation ?
Thank you.
J-chot
PostPosted: Mon Oct 01, 2018 12:58 pm    Post subject: voltage Reply with quote  Mark this post and the followings unread
is there any reason why this wouldn't work off of +/- 12v?
2kohm
PostPosted: Mon Oct 01, 2018 2:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
absolutely not, the lm741 can handel up to 18V supply rails
Maybe you Need to switch some other resistor values
Shop
Videos
Stromakustik.de
J-chot
PostPosted: Tue Oct 02, 2018 2:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
which values do you think I should change?
Stephenm67
PostPosted: Sun Jan 31, 2021 2:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
I’ve made this today and everything seems to work fine except the cv in, I’ve tried modulating it with my Crave’s LFO but there is a pulsing sound that I can’t get rid of. Can any one help, please ? I’ve included a video with the annoying sound.
trim.1E11207E-011E-4066-9DC9-F88E84182074.MOV
 Filesize:  1.39 MB
 Duration: 0:16
 Viewed:  577 Time(s)
LeoSteps
PostPosted: Tue Oct 06, 2026 7:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm also having the same issue with pulsating sound—featuring continuous, uninterrupted clicks—involving an LFO. Did you manage to solve the problem?
