Coming up on Radio 1 at
4017 Baby Sequencer Stripboard
Page 4 of 6 [128 Posts]
baudrate
PostPosted: Wed Apr 03, 2013 3:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
That 4017 works so that whatever voltage you power it with will be the same for the output. If your synth will only handle 5v and you're powering with 9v you could add 7805 to the gate out and add some pull down resistors to the CV out.
baudrate
PostPosted: Wed Apr 03, 2013 3:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here you go. Hexinverter did all the work. The 9v conversion is about half way down.
http://cv.hexinverter.net/?projects=sympleseq-5v-level-conversion
PostPosted: Wed Apr 03, 2013 3:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
those CV outputs could be affected by load though. I'd follow them with an op amp buffer. You could use a 100k pot voltage divider in place of the two resistors if you wanted to be able to vary the output for different synths.
Speedy RB
PostPosted: Fri Apr 05, 2013 10:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
-minus- wrote:
Excellent news! Very Happy I might have to do a stripboard diagram at some point for a trigger sequencer.
Yes, please!
Seriously, I built the sequencer based on your layout - great layout!
I've had no electronics training, just what I've learned by trying things out, so whenever I can find clear layouts for interesting projects I really appreciate it. In fact, part of the reason I joined these forums was to thank you for your design!
When I get around to taking some pics or a video of my finished 'baby', I'll post them.
Next up? The cacophonator, based on your layout, of course. And wow thumleft , you really outdid yourself on that one - love the vintage look!
And if you ever do get around to creating a stripboard layout for a 4017 trigger sequencer... Very Happy
PostPosted: Sat Apr 06, 2013 10:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Another modification that occurred to me tonight as I was looking over some old patch diagrams in Allen Strange's book...
I want to be able to clock this guy externally....
In the original schematic that would be cut the wire from 555 pin 3 to the clock and put a normal jack in the middle.
With the transistor inverter and such I've done, it's take that wire from the transistor collector to the run/stop switch and put the normal jack there.
I also think I want to take each of the individual gates to their own output jack, and that seems similarly simple (just pull from the far side of the trigger switches, probably use 1K output resistors).
-minus-
PostPosted: Tue Apr 09, 2013 6:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the compliments Speedy RB. I build everything onto stripboard but not everything gets to be a presentable illustration worth posting. Most of the circuits I have made are either hand drawn on paper or in a crude form drawn in Illustrator. I was thinking I should make time to post one a month this year but so far it hasn't happened. I have several circuits in a partial stage of being finished as artwork to post. I'll try and do something about getting them finished and posted.
Speedy RB
PostPosted: Tue Apr 09, 2013 10:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Best of intentions with unfinished projects? That sounds familiar... Smile
I'm sure whatever you post will be most appreciated (by me and others) - thanks again.
boundlessFX
PostPosted: Tue Jun 11, 2013 12:57 am    Post subject: Clock stop & momentary switches Reply with quote  Mark this post and the followings unread
I built this thing pretty quickly & easily and it definitely works interestingly with the only "synths" I've got that have inputs - a weirdly modded WSG and a circuit bent Synare 3. My only problem is; the switch that's supposed to stop the clock doesn't work correctly, and the momentary switch that's supposed to advance once step at a time doesn't work at all. When flipped, the clock stop switch freezes the clock for about a second and then it starts right up again and runs normally with the switch still flipped. Does anyone know what I can do to fix this?
boundlessFX
PostPosted: Tue Jun 11, 2013 1:31 am    Post subject: Whoops Reply with quote  Mark this post and the followings unread
Nevermind! Embarassed I tinkered with it a little more, fixed up a solder connection, and now it works perfectly. Cool
-minus-
PostPosted: Tue Jun 11, 2013 1:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah good to hear. The step advance isn't perfect. Perhaps the momentary switch could do with some de-bouncing circuitry or a de-bounce IC.
If you need to voltage control simple noisemakers, you can always use a home made vactrol:
http://ruinwesen.com/blog?id=1325
mubase
PostPosted: Mon Aug 19, 2013 10:36 am    Post subject: 4017seq @ beginnning of thread...rotary problems Reply with quote  Mark this post and the followings unread
The 4017 step sequencer at the beginning of this thread... Has ANYONE got it to work with a rotary switch.
I am going nuts trying to find out why mine isn't working.
The stripboard assembly and wiring is ALL CORRECT. I am connecting the middle lug of rotary to pin15.
Pin13 is grounded.
I am using 5 Volts.
When I try to change the step number with the rotary switch, It just carries on putting out 10 steps except for position 9 which seems to work....
PLEASE HELP SOMEONE....!!!!
There's a crack in everything...Thats how glue manufacturers make a living.
PostPosted: Mon Aug 19, 2013 11:56 am    Post subject: Reply with quote  Mark this post and the followings unread
I use a rotary (greyhill surplus). I have pin 15 pulled down with a 47K resistor as well as the connection to the rotary (and the reset switch).
feggster
PostPosted: Tue Aug 20, 2013 1:33 am    Post subject: Re: 4017seq @ beginnning of thread...rotary problems Reply with quote  Mark this post and the followings unread
Pin13 is grounded.
I am using 5 Volts.
did you omit the blue wire?
Snaper
PostPosted: Thu Dec 11, 2014 7:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Have somebody the schematic for this version?
I've found a lot over the net, but this seems the simplest...
Citezyne
PostPosted: Sat Feb 14, 2015 4:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Heya folks,
I have been doing a fair bit of research on the Baby 8 and found this thread in pure delight of past experience on this forum, with nicolas3141's Simple but fun Bleep machine.
Found here: http://electro-music.com/forum/viewtopic.php?highlight=bleep&t=61208
I have made a similar setup to this in the past called an 8 step APC i believe also featured in the forum somewhere. however that had the noise maker part built into the sequencer. i am building this one for the Simple but Fun Bleep Machine by Nicolas, and hope to use that as the noise part to this sequencer.
I have a bit of a silly question, am i correct to believe that A and B in the original schematic are the input for the sequencer?
-minus-
PostPosted: Sat Feb 14, 2015 6:03 am    Post subject: Reply with quote  Mark this post and the followings unread
The points A and B go to the legs of a 1M (b) potentiometer as shown in image 3. The sequencer has an inbuilt clock to control the rate. Smile
Citezyne
PostPosted: Sat Feb 14, 2015 7:06 am    Post subject: Reply with quote  Mark this post and the followings unread
OH i see now, pardon my ignorance but where would i feed the sound into?
varice
Audio files: 29
G2 patch files: 54
PostPosted: Sat Feb 14, 2015 2:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Citezyne wrote:
...pardon my ignorance but where would i feed the sound into?
This sequencer is not designed to accept audio input. It only produces control voltage (CV) outputs that are used to control the CV inputs of other synth modules, typically the pitch of VCOs.
To use this sequencer CV to control the pitch of your Bleepy Machine, do as Nicolas describes in his 4FEB post on page 2 of the Bleepy Machine thread that you linked above.
varice
seasonalfruits
PostPosted: Sat Mar 14, 2015 6:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I tried to build an 8 step sequencer days ago and it didn't work with this schematic. clock seems to work, but the sequencer pots don't.
I checked the soldering and wiring and everything seems fine.
I can't control my anxiety so I just dropped it, and now I want to try with this stripboard, but I want to make sure if the only fixes were:
-the 555 control voltage (pin 5) through a 10nf cap to ground.
-the 4017 reset (pin 15) through a 47k resistor to ground. pin 15 also goes to pin 9, right?
thanks in advance!
PostPosted: Wed Jun 17, 2015 1:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Did you "omit the green jumper" as noted in instruction #6? Basically you either 1) use a switch or 2) use the jumper (as shown) but not both.
Citezyne
PostPosted: Sat Sep 19, 2015 11:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey again folks.
Sorry for such a long delay between posts.
I have finally put this together and at first look it seemed to work fine. it looked as if it was stepping over each of the 8 steps and repeating. speed pot works and speeds the LED's up and down.
I decided to go with all extra options omitted blue and green wire.
However when i plug it into my mixer i hear something totally different, it doesn't matter what position i put the step pots in all i can hear is a the ticking on the steps, every now and again i will hear a stray beep, that seems to come from nowhere. if i plug this into my LFO bleep machine it creates some serious static sounds but no sequencing.
i have checked my solder and wiring, over and over, i cant see any issues.
Have i missed something?
will try to post some pics when i get back.
-minus-
PostPosted: Sun Sep 20, 2015 12:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for giving the sequencer a go. Sorry it's not working for you... yet.
When you say you are plugging it into a mixer, are you feeding the Control Voltages to a VCO first, and then to a mixer, or just feeding the output of the sequencer to the mixer? Just asking to see if this might be the issue...
-minus-
PostPosted: Sun Sep 20, 2015 1:08 am    Post subject: Reply with quote  Mark this post and the followings unread
....wait a sec....
I'm just looking at the original diagram now. I've got this sinking feeling there may be an error in there somewhere. Embarassed
Give me a moment and I'll see if I can figure this out. It's been ages since I have done anything electronic...
Citezyne
PostPosted: Sun Sep 20, 2015 1:23 am    Post subject: Reply with quote  Mark this post and the followings unread
All good,
I have tried both, minus feeding the sequencer into a mixer directly to see if its giving output for each step and I have also tried to feed this into a VCO/LFO the one that Nicolas designed. in both cases I get allot of static, and a random beep at any given step.
I will record a sound clip for you soon so you can have a listen, I will also try to get a video of it if you need it.
-minus-
PostPosted: Sun Sep 20, 2015 1:25 am    Post subject: Reply with quote  Mark this post and the followings unread
OK. The diagram looks to be correct. Very Happy
I must admit it looks a bit confusing. The font is not the most legible.Makes my eyes sore looking at it.
So, there is something wrong with your circuit somewhere. Let us know how you are hooking this up to your mixer. The problem might have a simple solution.
