Audio files: 730
Posted: Sat May 31, 2014 2:45 pm Post subject:
magnetic stirrer |
a CPU fan, a HDD magnet and a PWM controller circuit from here (with some different values).
The fan is mounted on a thin piece of wood, slightly smaller then the box, which is attached using some double sided adhesive foamtape to reduce
vibrations. I tried to get everything centered but it was pretty hard to get the magnet right because of it's shape. It's not too bad though, it doesn't
'walk away' and at low speeds it works great. I riveted some clear plastic to the top of the box as protection.
| Description: |
| Filesize: |
61.34 KB |
| Viewed: |
779 Time(s) |
| Description: |
| Filesize: |
54.67 KB |
| Viewed: |
754 Time(s) |
| Description: |
| Filesize: |
69.52 KB |
| Viewed: |
708 Time(s) |
The Golden Shrimp Guild |
Former site admin
Audio files: 353
Posted: Sat May 31, 2014 4:12 pm Post subject:
Nice!
Hope it doesnt make too much noise? |
Audio files: 730
Posted: Sat May 31, 2014 4:48 pm Post subject:
As long as I don't turn up the speed very high it doesn't make much noise.
And the noise is coming from the stirbar, which is a decapitated nail right now, grinding on the glass.
I don't really have a good mic to record it but I was thinking that if I add a reed switch I should be able
to use it as an oscillator  _________________ "My perf, it's full of holes!"
Audio files: 373
analog_backlash
Joined: Sep 04, 2012 Posts: 393 Location: Aldershot, UK
Audio files: 21
Audio files: 730
Joined: Dec 11, 2010 Posts: 1029 Location: Toronto, Ontario - Canada
Audio files: 83
Posted: Mon Jun 02, 2014 11:37 am Post subject:
| You can get bioluminesent algae that glows when the water moves. No led's required and the glow will last for a long time (glow sticks only last for a few hours). |
analog_backlash
Audio files: 21
Posted: Mon Jun 02, 2014 4:15 pm Post subject:
| Cynosure wrote: | | You can get bioluminesent algae that glows when the water moves. No led's required and the glow will last for a long time (glow sticks only last for a few hours). |
True and it's a 'greener' alternative (as long as you don't resort to grow lights) but you can wear them out and they stop glowing (albeit temporarily). Your right about the glow sticks - once the chemicals are exhausted they stop glowing.
Don't know what the algae rights people will think about it . |
Audio files: 730
Posted: Mon Jun 02, 2014 4:26 pm Post subject:
bioluminesent algae, interesting
I think I've actually seen that as a kid, didn't know it was algae though.
| Quote: | Don't know what the algae rights people will think about it . |
I could always use bioluminescent bacteria instead, do bacteria have rights ? they probably do,. right ? _________________ "My perf, it's full of holes!"
Joined: Jan 07, 2009 Posts: 1231 Location: Scottish Borders
Audio files: 163
Posted: Tue Jun 03, 2014 9:55 am Post subject:
cool phobos , , now , how about warm ferric chloride for some speed etching heheheh , hmmmm , it would probably strip it bare including the resist areas
Dave. |
Audio files: 730
Audio files: 163
Posted: Tue Jun 03, 2014 10:05 am Post subject:
Joined: Jan 15, 2011 Posts: 431 Location: Montreal, Canada
Posted: Mon Jan 05, 2015 1:12 pm Post subject:
| PHOBoS wrote: | I was thinking that if I add a reed switch I should be able
to use it as an oscillator  |
Magnetic oscillator sounds like a cool idea! A stiroscillator!
-- James |
