Posted: Sat Oct 04, 2014 9:00 am Post subject:
Korg DL-50 VCF clone - works but... Subject description: Building a clone of the Korg Delta VCF
Hey all,
I've just built a clone of the VCF found in the Korg Delta Synth section - otherwise known as the DL-50 Strings Synth - but in a twist I've tried to add VC Resonance!
The Bandpass works really well, but the Lowpass section stops passing anything below a certain cutoff frequency, above the frequency of the input.
Anyone have any ideas why this might be the case?
BP_Sweep_1.wav
Here is the juicy Bandpass sweep, with full resonance.
Filesize:
874.47 KB
Duration:
0:10
Viewed:
1439 Time(s)
LP_Sweep_1.wav
Here is the Lowpss sweep with full resonance. Notice how it gives up at a certain cutoff frequency, way above the fundamental of the input.
Filesize:
755.06 KB
Duration:
0:09
Viewed:
1447 Time(s)
Here is the schematic...
Filesize:
46.15 KB
Viewed:
948 Time(s)
As noticed you could try to bypass your VC-Resonance section like original schematics and check if it works. Once done you could check IC3b inverting input values and comparing them with your added VC-Res section.
Are you experimenting the issue with incoming voltage in the VC-RES but working OK with no added section?
Posted: Wed Oct 08, 2014 3:02 am Post subject:
Answers -
Yes, it stops passing input regardless of resonance setting.
No, this is just with the resonance knob.
Signal in - 5Vpp sawtooth.
But..
I tried bypassing the reonance section and wiring the resonance pot just as-per the original circuit, and now it doesn't work at all. Putting it back to how it was - still no joy! I must have given my board one kludge too many.
Well, I think I'll try to make an exact copy of the DL-50 filter next, without the VC Resonance section, but with extra holes so I can breadboard that separately and plug it in.
One thing I notice looking at your resonance CV to current converter (which doesn't look quite like a classic "expo converter", no servo op-amp), won't the reference current through Q1 be a bit high? Isn't it usual to put a lerger (100k - 1M) between the collector and Vss?
