Joined: Aug 15, 2007 Posts: 8 Location: Ontario Canada
Posted: Sun Nov 29, 2009 9:47 pm Post subject:
I do belive there was a fix mentioned on page four of this thread. I think the work on that pdf. was owsome and I want to try the project myself. I hope someone will get into this thread and breath some life into this interesting project.
Joined: Feb 16, 2007 Posts: 347 Location: Manchester UK
Audio files: 6
Posted: Thu Apr 23, 2015 10:28 am Post subject:
I've almost completed the Okita build, just some hardware wiring and I should be good to go.
I'm afraid I think I may have found another error on the lower right of goodrevdoc's PCB... Cut the trace as shown below (I think this may be why the Op-Amp was getting hot)
The output of pin 1 (IC29) shouldn't be linked to the Instrument gain pot via the jumper... Maybe this is also causing the indicator problems - I'll find out tomorrow, when I can start testing the boards.
Filesize:
60.92 KB
Viewed:
39502 Time(s)
Filesize:
1.91 MB
Viewed:
1201 Time(s)
Audio files: 6
Posted: Sat Apr 25, 2015 11:34 am Post subject:
OK, so breaking the track (above) fixes the indicator problem and no hot Op-Amps.
BUT... I've also found another major error on goodrevdoc's component layout - all the 4.7uf and 10uf tant caps around the NE570/571 are the wrong way round.
I'm just about to replace them, so I'll see if that fixes things. _________________ Kronos 2-88, Kronos 61, Studiologic Sledge V2/SL, Broadwave ARP 2600EX, Broadwave 18U ARP based Eurorack Modular, Broadwave Minimoog Clone, GEM S2 Turbo.
Audio files: 6
Posted: Sun Apr 26, 2015 11:41 pm Post subject:
Built, tested & finally working
I had to revert to Okita's original schematic, along with the additional 470k resistor modification on pins 1 & 16 to ground of the companders - sorry, but there's just too many errors on goodrevdoc's version
Intelligibility is ok-ish, maybe not quite as good as the SVC-350 which it's based on, but still pretty usable, although I can detect a definite formant shift... maybe I should have used better quality capacitors
You need to be careful of both input levels, otherwise it will distort! I found that it helps to roll off the bass end on both input signals. I've got an old chorus pedal somewhere, which I'll install at some point, but the good news is that substituting NE570's with NE571's works fine, and you can get them from Futurlec for a reasonable price.
For this quick test I used a Behringer C1 condenser mic, via my DI Box and Studiologic Sledge (Basic sawtooth, 3 oscillators, 1 octave apart, no detuning or filtering). Recorded directly from the Multimix 16 USB2 with a touch of reverb.
Just random mumblings.wav
Filesize:
6.42 MB
Duration:
0:38
Viewed:
3352 Time(s)
Filesize:
1.72 MB
Viewed:
870 Time(s)
Filesize:
1.85 MB
Viewed:
910 Time(s)
Filesize:
1.73 MB
Viewed:
899 Time(s)
Congratulations on a beautiful build. It sounds quite good in your demo. I use the Nord Modular G2 for vocodeing. I like the unintelligible quality of vocoders. Sometimes, though, I want the voice to be understandable.
A little trick you can use is to mix in the direct voice in with the output of the vocoder. I process the direct voice with a high-pass filter as I have found that all you need to add for intelligibility are the sibilances, just the high frequencies. This is ironic (I love irony) because most audio engineering writings are all about how to reduce sibilance.
I have two extra controls on the vocoder patch: one control is for a cross fader between the direct voice and the vocoder output, and one control is for the frequency of the high-pass filter on the direct signal. You thus get a lot more control. _________________ --Howard
Audio files: 6
Posted: Thu May 28, 2015 8:27 pm Post subject:
I wouldn't worry too much about those caps, the standard 0.047 & 0.0047 values work fine - it's only a *tiny* shift in the frequency response, and I doubt if you would even notice it _________________ Kronos 2-88, Kronos 61, Studiologic Sledge V2/SL, Broadwave ARP 2600EX, Broadwave 18U ARP based Eurorack Modular, Broadwave Minimoog Clone, GEM S2 Turbo.
there is an other trap with akita vocoder.
I wanted to used the original Transistor but i don't see that the design has been changed for using the europeans transistor. So if you want to used the japanese transistor like me you need tu swap Base and collector Pin and also put the transistor in the other way.
I have also some trouble with the signal indicator and i have try to change the 4558 by some TL072 and it seem to be better ..
thank you AndyR1960
I want also to built the ETI (powertran, ELRAD) vocoder, i m starting to rebuilt the typon for the big PCB ...
Zephyrin, your Okita vocoder is fantastic! I'd love to hear how you made that beautiful and professional looking front panel, but actually I'm posting here because I'm in the process of building an ETI/Powertran vocoder
All my PCBs are finished actually, but I need to redo the smaller ones (internal excitation, input amps, output amp etc.) as they were made really cheaply and of low quality at the time. Since I don't have the equipment (or any suitable place) for etching my own PCBs from the magazine article I've started to redesign the boards in Eagle (free electronics CAD software) and will have them done professionaly for very low cost instead.
However, I want to redesign the input amps to incorporate a compressor/limiter (I have owned a Roland VP-330 vocoder and remember how easily the mic input distorted). I've been suggested a dedicated IC for this (That's 4301) so it shouldn't be too hard, but as I don't have the necessary skills to redesign this myself so some help would be great to realize this project!
I could also use some help in finalizing the schematic/PCB layout I've done in Eagle so far. Although I know the basics of the software there's a little work left where a more experienced user could be of help.
In addition to the above, ordering several PCBs at once would make them even cheaper, which is why I'm looking for others interested in building the same vocoder. Interested?
It would also be great to include an "Ensemble" effect at the output stage (I really loved this in my VP-330) but haven't had any success so far in finding any suitable schematics. There is the Oakley sound SE330, but it takes up a whole 1U rack on its own. I was hoping for something smaller which would fit inside the same 19" rack enclosure as the vocoder.
In return for any help I can supply fully retouched, scanned PCB layouts from the magazine article and all the relevant info for building it.
Wow! Having built two vocoders already and on your way to build the ETI you must really like vocoders
As mentioned earlier I'd really like an ensemble effect (similar to the Roland VP-330 vocoder and other Roland devices) at the output stage of my ETI vocoder, and having download a PDF of the Okita vocoder I noticed that it mentions an "Option stereo chorus print circuit board space" (page 61 in the PDF) but there's no schematic or PCB layout for this (as far as I can see).
Does anyone know anything more about this specific section?
Thanks -I hadn't heard about those Roland chorus clones before.
I believe the "ensemble" effect I loved when I had my Roland VP-330 is basically a "chorus on steroids" type effect with several BBD chips all doing their own thing, hence the wider, more lush and "fat" sound without the pitch modulation of a basic chorus unit, right?
Having discussed the subject before and understanding how hard it is to clone the VP-330 ensemble (or other similar Roland keyboards with a similar ensemble) or another DIY ensemble effect which is relatively inexpensive and fits inside the vocoder enclosure I'm wondering if it might just be easier to rip out the PCB of some kind of enseble effect pedal.
I've been suggested Behringer's CC-300 which is supposed to be a clone of the (rather expensive) Boss DC-2 Dimension-C (which in turn is a cut-down pedal version of the (even more expensive) Roland SDD-320 Dimension-D.
Alas I hear it's a poor substitute for the Boss DC-2, apparently being digital (some people claim it's analog but then again that might just be the input stage). Besides I hear it's tricky to make it work with a line signal (i.e. the vocoder), so I'll have to look elsewhere.
There's another ensemble called the Boss CE-5 Chorus Ensemble which I see is based on BBD chips (earlier versions at least) and doesn't seem to sell at such inflated prices as the DC-2.
How does it compare to the DC-2 Dimension C (and more importantly, the Roland VP-330 ensemble), and will it accept (or can easily be modified for) line-level signals?
Joined: Feb 15, 2011 Posts: 363 Location: Null and void
Posted: Wed Sep 23, 2015 4:14 am Post subject:
FWIW the ensemble part is only half a rack - theres also the 'human voice module' which combine to form a 1u rack.
I stand corrected! You're quite right about the Oakley SE330 not occupying a full 19" rack and it could probably fit inside the vocoder.
Can someone tell me approx how much it'll cost to build? I see the PCB will soon be available, but not a complete kit.
That indeed seems to be a very nice one, and with features not even available on the original!
Has anyone designed a PCB for it?
I see the prototypes were built using a stripboard which seems quite complex.
Also, what is the approx total cost for it?
Posted: Mon Sep 28, 2015 3:50 am Post subject:
I dont know about costs, but Oakley's uses only easy to get parts, nothing old and rare. The ensemble is back in stock now fwiw.
As its a fully supported PCB i would imagine its much easier than scott's. Ive built a few oakley bits and they all worked first time, and sound great.
Getting pots and ICs from Tayda is a good way to save costs.
i am following this since years and after debugging here and there i found a way that solve distortion and signal/peak detector problems.
On the image attached you can find all the details.
Yellow: 500k to 100k already mentioned in this topic.
Orange: cut trace already mentioned in this topic.
Red: it should be 10k referring to okita schematics.
Green: from 47k to 10k reduce the gain sensibility so there is more space before reaching distortion
Blue: put the 1M resistor away and replace it with a 100ohm trimpot,
at the beginning i was quite surprised of that but now the signal led is working perfectly.
I still have 2 problems, maybe somebody can help me:
1: the 4053 is getting really hot (already fried one), at the moment i replace it with 3 spdt to get signal thru.
2: on the voice board the 356 has a strange behaviour, if i put it away all bands work perfectly if i put it in band 2,4,6,8,10 are "eating" the signal away, like they were inverted in phase.
Filesize:
516.19 KB
Viewed:
664 Time(s)
Are you sure for the value ? 100ohm is very different than 1M !
