Audio files: 730
Joined: Dec 11, 2010 Posts: 1029 Location: Toronto, Ontario - Canada
Audio files: 83
Posted: Tue May 12, 2015 7:01 pm Post subject:
Nice Skrog inspired blue  _________________ JacobWatters.com |
Audio files: 730
Posted: Wed May 13, 2015 2:10 am Post subject:
I used the exact same shade of blue as the Super Sequencer panel layout he posted here.
Of course it's not done with the same printer so it might be slightly of but it's the idea that counts. _________________ "My perf, it's full of holes!"
The Golden Shrimp Guild |
Joined: Jan 07, 2009 Posts: 1231 Location: Scottish Borders
Audio files: 163
Posted: Wed May 13, 2015 10:58 am Post subject:
WoW , Amazing , fantastic panel , I like the 2 celtic pipers and what a lovely shade of blue, good choice .
Looking forward to hearing it when it's all wired up .
Excellent work & great use for the chips & slide switches too, Phobos .
This is inspiring me to build another module  |
Audio files: 730
Audio files: 163
Posted: Wed May 13, 2015 12:28 pm Post subject:
That's a great way to mount the switches , saves having to source 2mm thread screws for the switch tabs, good stuff Phobos.
Dave. |
Audio files: 163
Posted: Wed May 13, 2015 12:30 pm Post subject:
hehehe , yes , haggis pic would look too greasy , so would a pic of flat square sausage  |
Audio files: 730
Posted: Fri May 29, 2015 8:05 am Post subject:
I wired it up about 2 weeks ago,. but I have problem. Apparently making an oscillator out of a 4069 inverter
followed by a 4025 NOR doesn't work . However when I touch the input of the inverter it does. I experimented
a bit on a breadboard to see if I could get it working but whatever worked on the breadboard didn't work when used
in the actual circuit. So I'm a bit stuck, easiest way is probably to just add another NOR chip and replace the 4069 inverters.
(and I need a 3.5 mm socket with a switch contact and some wood for a case) _________________ "My perf, it's full of holes!"
Audio files: 730
Posted: Sun Jul 19, 2015 11:21 am Post subject:
| PHOBoS wrote: | | ... easiest way is probably to just add another NOR chip and replace the 4069 inverters. |
So that's what I did. It feels a bit like cheating since dave didn't send me that one, but I already added an extra opamp too anyway.
(and I fried the original 555, but don't tell Dave)
I used some stained wood for the case this time instead of the usual MDF. And I wanted to record a demo but when I started playing
around with it yesterday I also added some other stuff (as usual). You can find some excerpts of that Skrogging session posted here.
And you can also here it at the beginning (and throughout) Phytoplankton.
| Description: |
| Filesize: |
100.06 KB |
| Viewed: |
1172 Time(s) |
| Description: |
| Filesize: |
90.51 KB |
| Viewed: |
1127 Time(s) |
| Description: |
| Filesize: |
108.59 KB |
| Viewed: |
1012 Time(s) |
| Description: |
| Filesize: |
87.42 KB |
| Viewed: |
992 Time(s) |
Former site admin
Audio files: 353
Posted: Sun Jul 19, 2015 11:43 am Post subject:
| PHOBoS wrote: | | You can find some excerpts |
Heard it live last night, and it was very nice .. did the harsh almost (heavily distorted) guitar like sounds (reminding me on Velvet Underground) come from the Skrogger? |
Audio files: 730
Posted: Sun Jul 19, 2015 12:42 pm Post subject:
Nope, that was the Chromatic Melody Generator (CMG) fed into a CD4046 Pitch Tracker/VCO, which was then fed into a divider (swing generator).
And all these signals where mixed together. I also had the SAW output from the CMG going into an ADC with the outputs controlling the notes
of the CMG. So it was somewhat playing (with) itself
Some of the sounds the Skrogger was making are the ones with the somewhat slow attack, you can hear it best in Excerpt 1. _________________ "My perf, it's full of holes!"
Audio files: 163
Posted: Mon Jul 20, 2015 12:09 pm Post subject:
Looks & Sounds Fantastic
I see the red square push for env , just like I use for my adsrs , cool
Does the Skrogger have it's own power supply or is it run from your Raw DC supply ?
The wood case completes the build Excellent construction Phobos , would it be ok to upload you some yellow drum synth patterns I will programme up , for you to multi track / jam some skrogger sounds along with ? .
Dave  |
Audio files: 730
Posted: Tue Jul 21, 2015 11:57 am Post subject:
Thanks Dave ,
Since it's just a simple lunetta synth it works on a DC wallwart and yes I had one of those push buttons I see you using al the time
so I had to put it in the skrogger. It's actually an on/off switch not a momentary but I noticed you can use it as such. So I can
use it as a trigger or just turn it on which basically disables the envelope generator.
Sure go ahead, upload some skrogbeats I jam to it. I can't promise I can stick to just using the skrogger though
And it might take some time before I get to it. I'm currrently working on 2 albums: the Captain Collider one and the
next AcidTrasH album.  _________________ "My perf, it's full of holes!"
Audio files: 163
Audio files: 730
Audio files: 730
Posted: Mon Dec 07, 2015 8:09 am Post subject:
Haggis in yer Coupon! Subject description: Sheep Shaggin' on a Sunday |
I finished the track and uploaded it here
I did add some other sounds to it as well besides the Skrogger. _________________ "My perf, it's full of holes!"
Audio files: 163
Posted: Tue Dec 08, 2015 10:25 am Post subject:
Thanks Phobos , sounds great , love the bleating samples & diy synth sounds, nice one
Dave. |
