Coming up on Radio 1 at
Modulator ESP on Adventures In Sound
Wren latest version - 2025.4.10.0
Page 4 of 11 [263 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, ..., 9, 10, 11 Next
Former site admin
Audio files: 353
PostPosted: Sun Jul 12, 2015 2:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
2015.7.12.0
http://bluehell.electro-music.com/wren/forums.html#changes
Also a new source code release for this version.
edit : url update.
Former site admin
Audio files: 353
PostPosted: Fri Aug 21, 2015 4:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
2015.8.21.0
Added .. lemme see . .granulator stuff ... MIDI CC support on controls, OSC control, but that that was tested badly .. OSC modules, badly tested too, a new mixer, some changes in the user interface, a new envelope curve type, poetry module of course .. stuff like that .. couple of bug fixes ... thats about it.
Let me know where it fails please Rolling Eyes
edit : url update.
Former site admin
Audio files: 353
PostPosted: Tue Aug 25, 2015 5:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
2015.8.26.0
There was a bit of a nasty bug when trying to use the unusable Friemels module (it is just a little user interface experiment really, but it would prevent Wren from quitting after having been used).
Some other minor fixes too, also I have inverted the internal coding for the 'rec' button of the Granulator modules .. which means .. when you saved them in an old Wren and reload them in this one they will be off when they were on.
A couple of new modules too, ClockedDelay16, NoteQuantizer and a lookup table thingie.
The main thing is that finally the Scala module seems to work properly Cool
I used it on some odd scalings and verified the output against what the Scala software produces for it. I did test the keyboard mappings a bit less well, but did test a regular one and an odd one.
What I did not test were keyboard mappings with holes in them. Wren can not really have holes in the mapping anyway, what Wren is supposed to do with it is that for a hole it uses the value from the step defined before.
(as the module implements a lookup table it has to give 'some' output for all possible input values. You could make the Scala files in such a way that it would output some 'special' value which could be detected with a comparator module for instance and then do some special stuff with that, like prevent an envelope to be triggered).
You can get scales and keyboard mappings from http://www.huygens-fokker.org/scala/ but also there is the Scala program itself on that site which can make such files to your own liking .. it will also tell you how to hand-craft such files.
edit : url update.
Former site admin
Audio files: 353
PostPosted: Wed Sep 02, 2015 2:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
2015.9.2.0
Added a couple of filterbank thingies, like
Posted Image
Posted Image
Posted Image
Added search functionality to the module selector - I'm starting to loose track on what modules are on which page ...
Added presets which can act on the patch as a whole or on any module selection.
Former site admin
Audio files: 353
PostPosted: Fri Oct 02, 2015 4:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
2015.10.2.0
Too many changes to mention ... in looks ... in processing .. couple of new modules too. This may have introduced some bugs too of course ... anyway .. have fun :-)
Please see http://bluehell.electro-music.com/wren/forums.html#changes
edit : url update.
Former site admin
Audio files: 353
PostPosted: Wed Nov 04, 2015 3:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
2015.11.4.0
Mainly a looks thing (a lot of user interface stuff is user configurable now), some bug fixes (knobs were not working properly everywhere, there was a MIDI issue and an OSC issue), and two new modules.
Gabe, known as LfoHead here, was kind enough to make a complete set of icons for the gabe looks, thanks Gabe, they are great Exclamation
The gabe look:
Posted Image
The default look:
Posted Image
But you can customize it all to your own likings, the configuration screen:
Posted Image
Also in the looks folder you will find examples for the bitmaps that can be changed.
edit : url update.
Former site admin
Audio files: 353
PostPosted: Tue Dec 15, 2015 5:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've just released version 2015.12.15.0 - for info check http://bluehell.electro-music.com/wren/forums.html#changes
A couple of bug fixes, a couple of new modules and some internal cleanup stuff.
Posted Image
Posted Image
Posted Image
Posted Image
Added a lil noodle thingie I did with the latest Wren, that is a patch and a recording (see attachments below)(lower ... Laughing ). To get the real thing you should play the patch of course.
listening to a recording of a noodle is like watching a photograph of a waterfal.
The recording is published under a Creative Commons CC-BY-NC-ND
The patch looks like:
Posted Image
edit : url update.
2015-12-15--Blue Hell--2015-12-15 - a wren noodle.mp3
2015-12-15 - a Wren noodle, for the patch see the forum where this track was posted. Published under a CC-BY-NC-ND creative commons license.
 Filesize:  25.53 MB
 Duration: 27:53
 Viewed:  3732 Time(s)
2015-12-12-01.wren
2015-12-1501 - a Wren noodle
 Filename:  2015-12-12-01.wren
 Filesize:  61.03 KB
 Downloaded:  949 Time(s)
hrastprogrammer
Audio files: 67
PostPosted: Mon Dec 28, 2015 4:54 am    Post subject: Reply with quote  Mark this post and the followings unread
This synth is like a Borg - it will assimilate all synthesizers and modules out there Very Happy
Former site admin
Audio files: 353
PostPosted: Mon Dec 28, 2015 5:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Heh, don't think so Hrast ... but it turns out that modular is not so modular in a way and that for trying some new ideas I often need to make a new module somehow Shocked
But this was the idea .. to have some platform of my own that I can easily try ideas in.
Anyway, once one is in I might as well just publish it. Laughing
Ideas from other's are welcome as well BTW, but I do have limited knowledge, and can not realize all ideas or suggestions.
hrastprogrammer
Audio files: 67
PostPosted: Mon Dec 28, 2015 5:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, this is really great - to have your own platform where you can test various things.
And once you start doing this it is hard to stop - I know it perfectly well Very Happy
Former site admin
Audio files: 353
PostPosted: Sun Jan 24, 2016 4:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
2016.1.24.0
A couple of bug fixes, some new modules, some new modes for existing modules. Summary:
- bug in sample rate switching fixed
- bug in the monadic module fixed
- bug in multi filters fixed
- made module import work properly
- patch folder and template folder remembered over sessions now
- added RMS mode to compressor
- added some fading curves for Pan and XFade modules
- added a stereo widener module
- added a smaller mono mixer
- added a volume control module
- added four voice paraphony by implementing a new MIDI in module
- added an RMS calculator module
- added a value displaying module
- added a cubic clipper module
See http://bluehell.electro-music.com/wren/forums.html#changes for details.
edit : url update.
Former site admin
Audio files: 353
PostPosted: Sun Feb 14, 2016 11:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Just released version 2016.2.14.0, also updated the source code release.
Some bugfixes maninly, for details see : http://bluehell.electro-music.com/wren/forums.html#changes
edit : url update.
marioisaac
PostPosted: Thu Feb 18, 2016 3:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey tried using this release but had permanent dropouts.
By just connecting a single Oscillator to the output module, instead of acontinuous signal, it was an intermitent sound with dropouts.
I tried running it at 44.1k and 96k sample rate, but it did not solve the issue.
I installed back the previous verison, and the problem was solved Razz
Former site admin
Audio files: 353
PostPosted: Thu Feb 18, 2016 4:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
You didnt keep the logfile by any chance?
marioisaac
PostPosted: Thu Feb 18, 2016 7:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, After restarting my PC now it seems to be working.
Also the Modules icons on the Modules Tab, don't show properly. This is a aestethic issue, it happens on this version, and the previous version as well.
I took a screen shot of that.
Thank you
Former site admin
Audio files: 353
PostPosted: Fri Feb 19, 2016 3:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I do not agree to the terms and conditions of wetransfer, sorry.
The forum has an attachment mechanism, could you please use that?
marioisaac
PostPosted: Fri Feb 19, 2016 9:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Sure, I most prefer attaching files directly. Did not know this forum had that feautre. Thanks for letting me know.
WREN.rar
 Filename:  WREN.rar
 Filesize:  8.19 KB
 Downloaded:  709 Time(s)
Former site admin
Audio files: 353
PostPosted: Fri Feb 19, 2016 10:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Not much to see in the logs - they are not from runs that failed? (a new log is started each time Wren starts up)
And the text does not fit I see, did you set the windows font to something larger than usual?
I see I have style elements on for the module selector (and a lot of other places as well), that could be it .. you have issues with non-fitting text in other plasces too? (like in the settings screen, some text there is a bit of a tight fit too).
marioisaac
PostPosted: Fri Feb 19, 2016 3:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
The logs are from runs that failed. Don't know what could have caused the problem.
I don't have issues in places other than the Modules Tab. I also have not changed the fonts size.
I just tried different visual themes, and the problem is solved.
The Windows theme is the only one with the text-fitting issues and only in the Modules Tab.
Former site admin
Audio files: 353
PostPosted: Fri Feb 19, 2016 4:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, thank you.
I will think about it.
Former site admin
Audio files: 353
PostPosted: Sun Mar 06, 2016 4:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
A new release .. 2016.3.5.0
I've changed something for the font size issue, not sure if this solves the problem though.
Added two new module types.
See: http://bluehell.electro-music.com/wren/forums.html#changes
edit : url update.
Former site admin
Audio files: 353
PostPosted: Wed Apr 27, 2016 5:56 am    Post subject: Reply with quote  Mark this post and the followings unread
And another new one : 2016.4.27
See: http://bluehell.electro-music.com/wren/forums.html#changes or http://bluehell.electro-music.com/wren/modules.html for details.
Also made a fresh source code release.
Fixed bugs :
* Selectors did not work properly
* Range setting for MixMM16to1 was not working properly.
* Stereo RMS calculation for the compressor was wrong.
* Changed some stuff for the built in help, lots of typos, some extra information, some errors got fixed.
Changed modules:
Posted Image
Some changes for the integration mode.
Posted Image
Added RMS mode.
Posted Image
Added a saw mode.
Posted Image
Added pulse modes to some logic modules.
Posted Image
Added output type selections for some logic modules.
Posted Image
Added hysteresis to the CubicClipper.
Posted Image
Added all-pass interpolation to the KS module.
Posted Image
Added some ranges for the value display module.
Posted Image
Added Q modulation to the SVF module.
New modules :
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Tap module example patch:
Posted Image
SawMill example output:
Posted Image
edit : url update.
sergio_frias_23
PostPosted: Tue May 17, 2016 6:11 am    Post subject: Reply with quote  Mark this post and the followings unread
"portaudio version: not detected or not properly initialized"
Cannot get any audio
I'm using win 10 X64,does anyone have the same problem?
Former site admin
Audio files: 353
PostPosted: Tue May 17, 2016 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
hi sergio_frias_23, welcome.
I'm not using win10 myself, but found some info : https://lists.columbia.edu/pipermail/portaudio/2015-September/000058.html
Maybe that gives some hints and maybe there is some other pre-compiled version.
Former site admin
Audio files: 353
PostPosted: Sun May 29, 2016 2:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Another new version 2016.5.29.0
See http://bluehell.electro-music.com/wren/forums.html#changes for details, the summary is:
The bug fixes are (for):
- CubicClip could make denormal values at some settings.
- Normalize function filters out NaNs and infinities too now
- Text changes did not mark the patch to be changed
- The 1 kHz fader for the third filter bank was wrongly named and hence that band was not working at all.
- Some bad resource locking fixed
- Sped up patch execution by around 7%
- Error in MIDI running state processing.
The new modules are:
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
edit : url update.
